Cruise control woes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Aug 9, 2011.
  1. Aug 9, 2011 at 4:52 AM
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Anyone have any issues with their cruise control? It seems 95% of the time I can't get the system to turn on at highway speed (no green light will illuminate). Not sure if its spiral cable related, or the switch on the steering wheel stalk. Anyone out there have any similar problems?
    No air bag light, horn still works - all indications are spiral cable is fine. However from time to time if you turn the wheels from lock to lock while pushing the cruise button, the green light will illuminate - making me believe the poor connection is in the spiral cable.
    Thoughts ?
  2. Jun 18, 2012 at 3:57 PM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    This is the exact problem I'm having with my 2000 Taco 3.4L. I've been searching and searching, and all cruise control problems seem to be "not engaging, but light still illuminates;" whereas, our problem is CC not engaging and no light illuminating! Totally different problem...?
    I've gone thru and checked all fuses, which all are still good, and now I'm temped into checking the relay, wires and the switch itself.
    Anybody know of anything else before I go thru a bunch of crap???
  3. Jun 18, 2012 at 6:36 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Have you had the spiral cable replaced under the recall yet, if your truck qualifies? If not, see what happens after that. Pretty easy to test the switch stalk resistances as well, maybe someone with the FSM can post the resistance specs for each switch function.
    Edit: Whoa, old post. Did you resolve it yet?
  4. Jun 18, 2012 at 6:41 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Try the first gen section, but I'd be testing the switch resistances and spiral cable resistance first. Totally different system as yours isn't drive by wire throttle.
