Cruise control works intermittently
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gmitchellgbm, Apr 25, 2023.
  1. Apr 25, 2023 at 3:03 PM
    gmitchellgbm
    gmitchellgbm [OP] New Member
    Gary
    2006 Toyota tacoma
    Does a 2006 Toyota Tacoma have a fuse for cruise control? If so I don’t see it on the diagram. It works intermittently and seems to be getting worse.
    buckhuntin-tacoma likes this.
  2. Apr 25, 2023 at 3:17 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Kinda vague description, What is it doing specifically? CC Light but no engage? Standard or auto transmission? Or CC light but not engaging? No CC light? CC light engages then hits a bump and disengages?
  3. Apr 25, 2023 at 3:36 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  4. Apr 25, 2023 at 8:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    There is no fuse for the cruise, it is all handled by the PCM.
    The main inputs for the cruise are the Cruise Control Switch, brake light switch, Cruise Control Clutch Switch (M/T), Transmission Range Switch (A/T), and Vehicle Speed
    The clockspring is a common failure point but if you can turn the cruise light on and off with the switch normally then that's likely fine.
  5. Apr 26, 2023 at 3:56 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    It could be the clock spring starting to fail...
  6. Apr 26, 2023 at 8:45 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Clock spring
  7. Apr 26, 2023 at 12:57 PM
    jeminyned
    jeminyned Well-Known Member
    Jerry
    2013 4 Dr Black Tacoma TRD Offroad
    Seat Covers and just getting started!
    My 2013 doesn't always connect the first couple of times I try it by pushing the stick all the way down like you're supposed to, so I push it all the way up to increase speed and it kicks in. Found out by trial & error.
