Cruise control Wouldn't stop!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02TuRDTACO, Oct 19, 2016.
  1. Oct 19, 2016 at 11:43 PM
    02TuRDTACO
    02TuRDTACO [OP] Member
    2002 Red Tacoma TRD
    Tow package w/Airbags
    so I was driving on the highway in my 2002 5spd Tacoma TRD SR5 3.4L in cruise control. I was doing 65 and went to accelerate (using the cc lever) to about 70mph. I figured I held the lever to long when I got to 75mph so I went to tap the brake to slow down... nothing. I hit the button on the cc lever to turn it off... nothing. After messing with the brake and the lever for about 2 minutes and panicking I figured it wasn't gonna turn off. I eventually had to turn my hazards on and ride the breaks to a complete stop to get the car to stall out and die. I didnt use the cc the whole rest of the drive home in fear of it not stopping again and the wear it did on my truck having to break like that. I have no idea what happened and can't find anything on the web. I'm afraid too use my cruise control again, Anyone have experience with this?
  2. Oct 19, 2016 at 11:53 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Next time just put it in neutral and start coming to a stop. Or shut it off in neutral and restart in neutral.
    You probably need to replace the cruise control switch. Easy job.
  3. Oct 19, 2016 at 11:55 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Geez. Thats pretty scary.
    I'm not even sure if its vacuum or cable assist. You might bump this up in the afternoon where more people will see it.
    Be carefull, for sure.
    DustStorm4x4 likes this.
  4. Oct 20, 2016 at 12:00 AM
    Matic
    Tricky Dick
    Easley, SC
    There should be 3 failsafes with the manual trans. 2 on the brake pedal and one on the clutch starter switch. Did you try and push the clutch in to disengage the cruise control?
  5. Oct 20, 2016 at 12:02 AM
    02TuRDTACO
    2002 Red Tacoma TRD
    Yeah when pressing the clutch, the engine just revved up like the throttle was stuck or something
  6. Oct 20, 2016 at 12:05 AM
    Matic
    Tricky Dick
    Easley, SC
    Weird. It shouldnt have revved passed the rpm you were already in.
    You might looks at the safety switch in the clutch as well. It should have cancelled out the cc. But so should the brakes and the actual switch itself.
  7. Oct 20, 2016 at 12:49 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Glad I never used these devices my Tacoma does not seem to have it.
    Not sure why you did just not shut the ignition off and pull over but stalled the the truck with the Brakes
  8. Oct 20, 2016 at 8:57 AM
    02TuRDTACO
    2002 Red Tacoma TRD
    I felt like turning the power off to the truck at 75 was just as scketchy
  9. Oct 20, 2016 at 9:26 AM
    02TuRDTACO
    2002 Red Tacoma TRD
    **update**
    Tried the CC out again today but at a much slower speed (35mph) and couldn't replicate the issue. The break and the clutch both cancelled the cc. Maybe I'll just avoid speeding up with the lever and contact a dealer until then
