cruise control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trurotacoma, May 22, 2012.
  1. May 22, 2012 at 4:31 PM
    Trurotacoma
    Trurotacoma [OP] Member
    Wade
    Nova Scotia, Canada
    05 base 4x4
    I am trying to install power wire for cruise control, how do you "unlock" or open the pin connectors so that you can get the pins all the way in?
  2. May 23, 2012 at 4:57 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There is a special tool to remove pins from a connector. You may be able to use a paper clip to unlock it, but it's easy to mess up the connector or your fingers. There is a factory harness you can get. It made my install quick and painless.
