Cruise control
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dayno, Jan 21, 2016.
  1. Jan 21, 2016 at 9:31 AM
    Dayno
    Dayno [OP] Gr8Dane
    Driving with my cruise control on stopped and started driving again and now I have no cruise control still lights up in the dash everything else works radio lights brake light just no cruise is there a fuse or am I missing something
  2. Jan 21, 2016 at 9:54 AM
    DiggerDan
    DiggerDan Well-Known Member
    You should check the vacuum lines for a leak. Cruise control works as such.
    Dayno[OP] likes this.
  3. Jan 21, 2016 at 12:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The cruise control does not use a vacuum control, it is all electronic.
    The usual suspects and causes are either the Brake Switch or the Clutch Switch for the manual transmission.
    Check to see if the brake lights are stuck on or if a manual transmission if you can start it with the clutch Not Depressed.
    Brake lights on is a stuck brake switch.
    Start with the clutch not depressed is a stuck clutch switch.
    Here check these:
    6. Manual Cancel Mechanism
    If any of the following signals is input during cruise control travelling, the cruise control is cancelled.
    The stop lamp SW is turned on.
    ∗ The CANCEL SW is turned on.
    ∗ The main SW is turned off.
    ∗ Gear is shifted from D position to other positions than D (A/T).
    Clutch pedal depresed (M/T).
    7. Auto Cancel Function
    If any of the following conditions is encountered, the cruise control is automatically cancelled.
    The stop lamp SW wiring is faulty or short–circuited.
    ∗ The vehicle speed signal is faulty.
    ∗ The electronically controlled throttle malfunctions.
    ∗ The actual vehicle speed becomes –16 km/h slower than the set speed.
    ∗ The actual vehicle speed becomes slower than the minimum speed limit.
    MQQSE likes this.
  4. Jan 21, 2016 at 2:35 PM
    DiggerDan
    @Jimmyh well this is news to me, thanks!
    **fades into background**
  5. Jan 21, 2016 at 2:56 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    You must be an old guy, like me :) This new-newfangled stuff blows my mind.
  6. Jan 21, 2016 at 3:06 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Jimmy ain't no Spring chicken, but he is very knowledgeable. ;)
    Good luck getting it sorted Op. :cool:
    Jimmyh likes this.
  7. Jan 21, 2016 at 3:10 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Hell, if Jimmy can remember what he had for breakfast he's got me beat. ;)
    Jimmyh and MQQSE[QUOTED] like this.
  8. Jan 24, 2016 at 6:53 PM
    Dayno
    Dayno [OP] Gr8Dane
    Thanks definatly going attempt it this week
