Cruise Control
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco, Sep 8, 2009.
  1. Sep 8, 2009 at 1:26 PM
    El Taco
    El Taco [OP] Well-Known Member
    STP MN
    Need help on cruise control issue.
    Truck: 2001 Taco Pre V6 Auto, no cruise.
    Went to the local junker and got the cruise control actuator, cruise control ECU, and a stalk/switch from a Camry (it fits though).
    My truck already has the harnesses for the ECU and the actuator, so that was plug-n-play. Also plug-n-play for the stalk to on the steering wheel as well.
    But, when I turn the ignition to ON, there is no "cruise control" light so the unit isn't working. Tried driving it and nothing too. I also checked for resistance on the stalk, actuator, and ECU and it has resistance. Did a test on the actuator and it works.
    What am I missing or am I missing anything???
    thanks in advance.
  2. Sep 8, 2009 at 1:30 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Are first gens drive by wire? where there are no cc parts under the hood? If, so then bad stalk has been issue for some, even new ones. Mine is 2nd gen so I'm not sure if 1st gens same easy hookup where ecu does all the controlling. All I added was clutch switch, wire for st wheel, stalk & side cover for steering wheel.
  3. Sep 8, 2009 at 1:52 PM
    El Taco
    STP MN
    had NOTHING under the hood, no actuator, nothing but the harness to connect to the actuator.
    any other suggestions...?
  4. Sep 9, 2009 at 5:02 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No way to tell, without seeing exactly how you've got it wired up ...
    ... And exactly how did you install the actuator?
  5. Sep 9, 2009 at 8:53 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  6. Sep 9, 2009 at 9:59 AM
    El Taco
    STP MN
    Enola, installing the actuator was a simple bolt app on because i just took it off the junker truck.
    I guess what i'm really asking is....
    what all is there to get cruise control???
    like the ECU, actuator, and stalk/switch (which i have all of these), is there anything else or is this it???
    thanks.
  7. Sep 9, 2009 at 10:05 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    If you have a manual transmission, you'll also need a clutch switch.
  8. Sep 9, 2009 at 10:06 AM
    drew02a
    San Antonio, TX
    BTW, according to the tracking info, the Locker Controller should arrive today!:woot:
  9. Sep 9, 2009 at 10:07 AM
    El Taco
    STP MN
    drew, thanks bro.
    and no, i have an auto and the truck i took it off of was an auto as well....
  10. Sep 9, 2009 at 10:07 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    He has an auto Drew, and the cruise control is from a Camry.
  11. Sep 9, 2009 at 3:09 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    OK - now I'm more confused ...
    Which part(s) did you get off a truck, and which part(s) did you get off a Camry?
    And what are the details on both vehicles (years, etc.)?
  12. Sep 9, 2009 at 3:25 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    did you put a fuse in the fuse panel? is there a fuse for the cc? i'm just throwing ideas out i have no clue lol
  13. Sep 9, 2009 at 5:25 PM
    El Taco
    STP MN
    alright, to clear things up a bit...
    what i took off the junker (2001 tacoma prerunner trd):
    cruise ECU
    what i took off the camry (not sure what year but maybe a 93-97):
    cruise stalk
    my truck came with none of these
    but the harnesses were on my truck already so all i did was plugged them all onto whatever...
    i've checked all the fuses as well (should've posted that one the first post). all the fuses are there, but maybe i'm missing a fuse somewhere???
    i dunno.......any other ideas gents???
    what i'm thinking is that the stalk is f****cked up, or the wiring on it is wrong.>>>>>>>>>another trip to the junker...:mad:
