cruise control
Discussion in '1st Gen. Tacomas (1995-2004)' started by yeti15, Apr 18, 2010.
  1. Apr 18, 2010 at 1:11 PM
    yeti15
    yeti15 [OP] New Member
    Newport, Or.
    03 SR5
    K&N Cold Air Intake 2.5" Rough Country Suspention Lift
    I was wondering if anybody has had problems with their cruise control. I just went on a trip to california and was using my cruise control most of the way but it kept shuting itself off or something and I was wondering if anybody else had the same problem or not. Thanks
  2. Apr 18, 2010 at 1:15 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I used to have that problem on an 86 Pontiac I had. It turned out to be the break light switch. It was coming on when I would hit a big bump and it would shut off the cruise. I was able to adjust it and then it worked fine.
    Not sure if this is your problem or not, but the cruise does turn off when the break is pressed (or, in my case, my car "thought" it was being pressed).
    Cheers and welcome to the forum!!
  3. Apr 18, 2010 at 1:17 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    the towing package wiring harness on toyotas have been known to cause issues with the cruise control if they go bad. if you have the towing set up try disconnecting the wires and see if the c/c issue goes away
  4. Apr 26, 2010 at 4:34 PM
    yeti15
    Newport, Or.
    03 SR5
    ok ill look at it thanks for the advise.
