cruise drive
Discussion in 'Technical Chat' started by mitiko, Sep 13, 2008.
  1. Sep 13, 2008 at 2:41 AM
    mitiko
    mitiko [OP] Well-Known Member
    lax
    05 prerunner trd
    Hi I try several time to use my cruise driver but never work some body can help me.:confused:
  2. Sep 13, 2008 at 5:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Cruise Control:
    Turn on the cruise
    When you reach your desired speed, hit the "set" button.
  3. Sep 13, 2008 at 10:04 AM
    mitiko
    lax
    05 prerunner trd
    I do and the light is on but I loss speed.
  4. Sep 13, 2008 at 4:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That same lever that you turned the cruise ON..... look at the stalk, it'll show you how to SET the speed using the stalk itself.
    Drive to the speed you want.... PUSH the stalk downward (atleast a second) to SET the cruise speed.
    To Accelerate - Push stalk upward and hold (until you get results)
    To coast - push stalk downward and hold (until you get results)
    To Resume - push stalk upward
    To cancel - pull stalk towards you (or step on brakes)
    I've discovered (atleast on my truck) that when you move the stalk upward or downward, you have to give it a second....before you get results. You can't just flip it up quick...
  5. Sep 13, 2008 at 4:40 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    I dislike the cruise on mine bc every hill it has to shift down. Even small hills. I wish I had a way to lock it in Overdrive!
  6. Sep 13, 2008 at 4:49 PM
    tdm156
    tdm156 Well-Known Member
    San Antonio, TX
    2009 DC 4x4 SR5**Sold
    I have found that mine will shift down on the hills too and then speed way up past my set speed
  7. Sep 13, 2008 at 4:53 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Same here mine speeds up way too much and runs way to high on the RPMs. When trying to conserve fuel I turn the cruise off when I reach an overpass.
  8. Sep 13, 2008 at 6:18 PM
    Taco's for All
    Taco's for All Well-Known Member
    Lake George, NY
    2019 Tacoma TRD Off Road Double Cab
    Nothing at the moment
    I just bought a 2009 and I like the cruise control better with this truck than with my old Dodge. I have a rather steep hill on my way to work and I used to need a running start to make it halfway up before downshifting and then hitting 5K RPM's to hold 55-60mph. The salesman that I had at the Toyota Dealership was somewhat knowledgable and said that the new 2009 motor has variable valve timing or something so it automatically adjusts the air/fuel flow (I began ignoring him at this point as I knew this was exactly the truck that I wanted to leave there with).
    Anyways, my truck hasn't downshifted on this hill since I've bought it and I've tried it at different speeds in the 50-75 range.
  9. Sep 13, 2008 at 6:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    All the 1GR-FE's are VVT-i
  10. Sep 13, 2008 at 11:25 PM
    311offroad
    Milledgeville, GA
    Yeah exactly. It definatly does not stay anywhere near the set speed when going up and down hills. A little change in speed isn't bad but I'm talking 8 or so MPH range. Im not used to that after all my manual cars.
