Cruise indicator light
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco57, May 10, 2017.
  1. May 10, 2017 at 9:18 AM
    taco57
    taco57 [OP] Well-Known Member
    Jeff
    Columbus Ohio
    2003 Tacoma SR5 4X4 2.7 5 speed
    My cruise on indicator light is out all of a sudden, cruise still works.
    Can this bulb be accessed from underneath after removing the lower panel and duct work? Or do I have to remove the entire cluster?
  2. May 10, 2017 at 9:28 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    You'll have to remove the entire cluster. It's fairly easy though. There are some good write-ups and some youtube videos that explain where things are located and best method of removal. Bulb is located behind the cluster and will have to be pulled and replaced with new.
    robssol likes this.
  3. May 10, 2017 at 10:27 AM
    taco57
    Jeff
    Columbus Ohio
    Ok. Maybe while I am in there I will replace all the others.
    Any experience with LED's? Do they cast a smooth light as the factory bulbs do?
  4. May 10, 2017 at 10:49 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I found that if you use excessively bright LED's they will bleed through the coating (especially bad with the climate control) it depends on which bulbs you use.
    Xbeaus likes this.
  5. May 10, 2017 at 11:33 AM
    Xbeaus
    Beau
    I just used the standard bulbs. You can get different colored caps to change the light color. No experience with the LED. I have done them on my motorcycle though and I needed to run a resistor in there to.
  6. May 11, 2017 at 3:33 AM
    taco57
    Jeff
    Columbus Ohio
    That is what I am thinking too, just go with a standard bulb. I am not interested in changing colors. Cruise light is green, will stay that way. Stands to reason, at least for me, the cruise light burnt out first, I am on the highway most of the time with my truck using cruise. hummmm, maybe I should put a longer lasting LED in the cruise light?
  7. May 11, 2017 at 3:40 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    My cruise lite is still good after 115K miles. Almost always on. If/when it burns out I'll just let it be.
  8. May 11, 2017 at 3:56 AM
    taco57
    Jeff
    Columbus Ohio
    217K on mine when it went. No big deal I suppose, but my OCD keeps taking over...................
