Cruise to work under 25 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stormblast08, Jun 3, 2010.
  1. Jun 3, 2010 at 10:30 AM
    stormblast08
    stormblast08 [OP] Member
    Gerald
    Washinton, NC
    2010 Tacoma & 1987 4X4 4cyl. 5sp
    Carbon Adsorber Removal Modification,scagauge II,full insulation in airbox etc.. airbox trim
    Anyone know how to mod cruise to work under 25 mph and default on when ignition is turned?
  2. Jun 3, 2010 at 10:35 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I have no idea but that's interesting that you want to set cc at 25...
  3. Jun 3, 2010 at 10:37 AM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    i don't know how to do that sort of stuff, but there is a reason they don't come that way from the factory, fwiw.
  4. Jun 3, 2010 at 10:57 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    So you want the truck to instantly speed up when you turn it on?
  5. Jun 3, 2010 at 2:23 PM
    JKD
    JKD Well-Known Member
    I can see, sort of, the utility of cruise at under 25. Maybe you have a long commute on a deserted road with road construction...
    I can't imagine any reason why you want it to default "on" when you turn the vehicle on. My finger has to move about, what, three inches to hit the on button? Is there a purpose I'm not seeing here?
  6. Jun 3, 2010 at 4:13 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
    That, and it would instantly turn off the moment you hit the breaks coming out of the driveway anyway.
    Edit: Actually, most people start the truck with their foot on the break, so it would likely turn off the moment you started the engine..
  7. Jun 3, 2010 at 4:15 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Auto's don't.
  8. Jun 3, 2010 at 4:15 PM
    stormblast08
    Gerald
    Washinton, NC
    I live in a rural area and cruise dirt roads at 5-20 mph. I would like it to default on as Honda's do, you just hit speed set and your done.
  9. Jun 4, 2010 at 2:40 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    U can use the brick mod!!:D
  10. Jun 4, 2010 at 3:46 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I to find it annoying that we have to turn cruise on everytime we start the truck. We also have a Honda were the cruise stays on and I just hit the set at whatever speed I want ( not sure what the minimum is).
    I always hit set in my Tacoma, then realize the cruise is not on.
    Shawn
  11. Jun 4, 2010 at 4:03 AM
    82dmc12
    82dmc12 Member
    Ed
    Florida
    07 TRD Tacoma
    There is one way to do this. The VSS signal goes to the ecu, speedo and the cruise control module. If you get a VSS adapter and splice it between the signal going to the CCM you can trick the CCM to thinking you are going faster than you are. The CCM just looks at the signal pulse frequency. The faster you go, the higher the freq so if you turn up the freq a bit the CCM will think you are above 25MPH and turn on.
  12. Jun 4, 2010 at 4:10 AM
    kris77
    kris77 Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I mean are we really getting so lazy that we cant take 1/2 a second to push the big button on the side of the cruise lever to turn it on? You have to move that lever down anyways to set it...So your hand is going to be RIGHT THERE anyways...
    Come on guys.
  13. Oct 12, 2010 at 10:07 PM
    adavis22
    adavis22 Member
    Allen
    Texas
    TRD Sport 4X4
  14. Oct 12, 2010 at 10:17 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This thread was last posted in , in June , maybe he got over it .
  15. Oct 12, 2010 at 10:44 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    maybe he is still cruising down that long road.
  16. Oct 12, 2010 at 10:47 PM
    OZ-T
    Peter North
    British Columbia
    :D haha
  17. Oct 13, 2010 at 5:20 AM
    stormblast08
    Gerald
    Washinton, NC
    No. Im still not over it, I still want to get my cruise control to work under 25 mph. I still want it to be on like Honda does theirs. Still searching.
  18. Oct 13, 2010 at 7:28 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    i had no idea holding your foot down on the gas pedal would be so difficult...
  19. Oct 13, 2010 at 7:56 AM
    Nd4Spd86
    Nd4Spd86 Turdarado extractor
    Crystal River, FL
    '10 trd off-road 4x4
    some crappy dealer installed lift , 285's, trail pin striping, and a grill full of lights.
    X2!!!!!!
  20. Oct 13, 2010 at 8:06 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    I do it all the time driving through residental area .... 25 mph speed limit.
