Cruisin down the street in my 64...and it just died!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TucsonAZ, Jul 1, 2021.
  1. Jul 1, 2021 at 7:20 PM
    TucsonAZ
    TucsonAZ [OP] Well-Known Member
    2006 Crew Cab TRD
    ARB Bumper
    Sorry for the title, the song happened to be in my head. Anyway, it's actually a 2006 DCSB with 160k miles on it. I was just driving at 50mph and poof the engine stalls out. It's showing no fault codes however, the check engine light was on.
    I cleaned the MAF, redid all the battery terminals (needed doing anyway) and that didn't help so I'm thinking fuel pump? What do you all think?
    I ordered the Aeromotive 11542 and the WIX 33296 fuel filter to put outside the tank. I'm honestly just starting with the easiest stuff but figured I'd ask what you all thought the likelihood was it would be the fuel pump.
    igno1tus and Superdave1.0 like this.
  2. Jul 1, 2021 at 7:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  3. Jul 1, 2021 at 7:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    See if it runs on starting fluid
    Jimmyh likes this.
  4. Jul 1, 2021 at 7:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Does it have gas in the tank?
    Just asking because it happened before...
    Abject4x4 likes this.
  5. Jul 1, 2021 at 7:39 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    Oh no, I totally understand the question. Yeah, I normally fill at 1/4 tank, in this case I was at 1/8th of a tank and headed to fuel up when it died.
    Just doing deferred maintenance so I don't mind dropping $100 to replace and upgrade the fuel pump, the 3 hours it will take me I would rather avoid but mostly because I hate the smell of gasoline.
  6. Jul 1, 2021 at 7:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    So did you actually put any gasoline in it since it died. The accuracy of the gauge could be off.
    Sharpish and Markcal like this.
  7. Jul 1, 2021 at 8:09 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    No, there's fuel in the tank, that isn't currently the issue but I'll drill a small hole in the bottom of the tank to confirm. That's a joke, I'll just rock the trunk and make sure I hear it sloshing around. Side note, onetime my ex wife called me, car wasn't running, just died on her. Anyway, I go to help and see a black skid mark all the way down the road to our car. Half the brake pad broke off and lodged itself between the rotor and the other half of the pad. Thankfully she ran out of gas within about a mile of that happening or she's have likely dragged that poor tire all the way home.
    Superdave1.0 and Jimmyh[QUOTED] like this.
  8. Jul 1, 2021 at 8:12 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Did it die suddenly or choke and sputter?
  9. Jul 1, 2021 at 8:14 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Aggghhh 47 min to Friday :annoyed:
    Alexely999 and Superdave1.0 like this.
  10. Jul 1, 2021 at 8:15 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    Poof...dead, like magic, like my grampa. Doing fine one moment then nothing a second later.
    Alexely999 likes this.
  11. Jul 1, 2021 at 9:42 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I would dump a gallon of gas in it before I did anything else.
    racerX969 and Jimmyh like this.
  12. Jul 1, 2021 at 9:43 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    If it was me I'd think MAF sensor but I'd probably start by verifying spark and fuel pressure first.
  13. Jul 1, 2021 at 9:45 PM
    tcjacado
    tcjacado Well-Known Member
  14. Jul 1, 2021 at 10:47 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Maybe crankshaft position sensor (ckp).
  15. Jul 2, 2021 at 3:20 PM
    Mastiffsrule
    Scott
    Which, the truck or grampa?
    No disrespect intended. it’s Friday
  16. Jul 2, 2021 at 6:00 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    He mostly ran on alcohol and died with a full tank of it.
  17. Jul 2, 2021 at 10:49 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    I was out of gas!? Talk about a moment! I always fill at 1/4 of a tank but in this case I started a drive and figured I'd fill at the end of it since I was passing the station then (I live rural). I still had 1/8th of a tank as I was keeping an eye on it and headed to the station when it died. Anyway, I did get the Aeromotive 11542 series 340 pump on an Amazon warehouse deal for $60 so I'll put together the new unit and drop it in one of these days.
    I do wish I had tried to start it before adding 1.5 gallons of fuel just in case it was another issue but I'll call it good enough for now.
    Jimmyh likes this.
  18. Jul 2, 2021 at 10:55 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    why not just put some bright pink yarn on that fuel pump and wear it around your neck as a reminder..?
    Jimmyh and b_r_o like this.
  19. Jul 2, 2021 at 11:02 PM
    TucsonAZ
    2006 Crew Cab TRD
    ARB Bumper
    To be fair, I was getting to confirming fuel, I just wanted to get some feedback before I dug in too deep. With 160k I would like to get in there anyway and redo the fuel pump I'm just happy it isn't a rush anymore.
  20. Jul 2, 2021 at 11:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Complaint - Truck shut off suddenly.
    Diagnosis: Tested fuel pump. -Found fuel pump sucking air.
    Recommendation: New fuel pump.
    :spending:
    Just kidding OP. Good to hear or was an easy fix.
    Jimmyh likes this.
