Crummy Gas Mileage
Discussion in '1st Gen. Tacomas (1995-2004)' started by ScottyB, Dec 22, 2009.
  1. Dec 22, 2009 at 1:46 PM
    ScottyB
    ScottyB [OP] Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Hey guys, getting crummy gas mileage here. Something like 14mpg on a V6. Granted I'm not doing freeway miles here, and living on an island there's plenty of hill climb, but 14 mpg seems ridiculous. My uncle gets 14mpg on his El Camino 454SS. The engine doesn't feel like its running badly, in fact it feels pretty good, but I'm wondering if it could be something funky like maybe the oxygen sensors. Is it possible they'd need replacing without throwing a code? Other things getting done are stuff like changing the fuel filter, air filter and points/plugs.
  2. Dec 22, 2009 at 2:09 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    ScottyB, there is a lot of different factors that can cause this, some of which you have already thought of. But A big factor is winter gas mixtures get worse MPG's than summer gas. This could be a partial cause of your situation. But since you live on an island, I don't think they have winter gas so it may not be a problem, and should be fine on that.
    1.) I would highly suggest switching out for new spark plugs, 2.) New air filter, 3.) Clean the MAF, Throttle body, Air intake, 4.) Add Sea Foam, etc.
    There is many other things you can do to improve MPG's, you can change the fuel filter (which could help), alignment, tire balance, transmission oil, rear differential oil, etc
    I don't know if the oxygen sensors will always throw a code if they go bad, but could be a possibility. Hopefully someone can chime in on that.
    I hope this helps somewhat. Good luck.
  3. Dec 22, 2009 at 2:25 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    How long have you had the vehicle? Is this a newly purchased vehicle or have you owned it for a while? In other words....what was the gas mileage prior to now?
    You live in Hawaii? So, I'm guessing....you don't get the winter gas mixtures over there since you don't need it for proper combustion. So I would guess, that isn't the issue.
    What tire pressure are you running? Are you still on stock tires/suspension? What octane do you run?
  4. Dec 23, 2009 at 4:32 AM
    ScottyB
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Regular Octane, everything is oem spec, parts are oem or oem replacement. Only modification to the truck as of yet are a set of bilstein 5100's to replace the oem toyota bilsteins which were dying/dead (especially the rears). Haven't had the truck very long. Just bought it last month. It gets driven regularly but not for a lot of miles, but the previous owner used it as a delivery truck so it used to. Air filter and Oil/filter was changed recently. I have a set of plugs and wires waiting for the weekend. Changed the fuel filter last weekend. Will be changing the tranny and diff fluid soon.
    The truck has 175k miles on it but still runs like a champ. The previous owner took it to the dealer for the maintenance for alot of years, and then to reputable shops for it more recently so I know it's been taken care of. All the records were in the glove box.
    The oxygen sensors will obviously be last due to their price and not being a regular maintenance type item. Mostly I was just wondering if that was a big deal. I've seen a bad O2 sensor totally bork some other fuel injection cars' mileage and then on other cars only really come into play when cruising at freeway speed on low revs.
  5. Dec 23, 2009 at 4:41 AM
    paulm09tacoma
    paulm09tacoma Well-Known Member
    paul
    connecticut
    09 access cab trd
    i agree with all the above. check the "usual suspects" and tire pressure. if under warrenty i would take it to the dealer. good luck
  6. Jul 8, 2010 at 8:19 PM
    BREAK
    BREAK Well-Known Member
    Washington
    2016 TRDOR LB
    BFG KO2 265/75R16 Icon Dynamics 2.0 Front Coilovers and rear shocks. Rear AAL Borla Catback exhaust Afe momentum CAI
    can having your alignment done really help gas mileage?
  7. Jul 8, 2010 at 8:34 PM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    I'm only getting about 15 mpg. My air fuel ratio sensor is bad :(
  8. Jul 8, 2010 at 8:56 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Yes
  9. Jul 8, 2010 at 9:03 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Whoever said tire pressure I can agree with that. Ill add an extra 5-10 psi for city driving and ill add another 30+ miles to my tank easily!!
    Also I have noticed after a good alignment ill get a little better mileage so there is something to that
  10. Jul 8, 2010 at 11:06 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    I get about 16mpg 60/40 city/hwy (A/C on all the time), I was expecting worse since my truck is lifted and I got bigger tires. I used to get about 17mpg when I was stock but I always use 92 octane and I drive with a lead foot a lot. There will be a lot of naysayers but on most fuel injected vehicles, using a higher octane does increase power and mpg slightly(its been proven). Also, most of the time the better mpg with higher octane overrides the slightly higher price of the gas. I would recheck your mpg after your tune-up as it should get better. But don't expect crazy gains, its hard to get good gas mileage in Hawaii because its so hot and humid (bad for combustion efficiency) and SO much stop and go.
  11. Jul 9, 2010 at 4:08 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    The octane rating of gasoline is a measure of how much you can compress the gasoline before it ignites, not how “good” it is.
  12. Jul 9, 2010 at 4:12 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    There percentage of cars that require or benefit from high-octane gas is relatively small and these cars have engines that are specifically designed to benefit from higher-octane gasoline. Keep in mind that just because a gasoline is labeled “high-octane” and costs more does not necessarily mean it is better for your car. Buying high-octane gas is not going to give you better gas mileage which is a common misconception and if your car wasn’t made to operate on high-octane gasoline, there’s really no reason for you to fork over the extra cash for it.
  13. Jul 9, 2010 at 8:47 PM
    Gwest1967
    Gwest1967 Active Member
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    16 inch tires/wheels
    I changed the o2/fuel oxy sensor and didn't get any better.. I am getting 16-18.. Neighbor gets 23 with her 2000 4x4 automatic.. I am in the same boat as you.. 2001 v6 4x4 manual..
  14. Jul 9, 2010 at 8:50 PM
    Gwest1967
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    I just changed the o2/fuel ratio sensor and it didn't help much.. I bought it on ebay, it was an original denso part.. It was 1/2 price of the Toyota dealer part.
  15. Jul 9, 2010 at 8:53 PM
    Gwest1967
    Gregg
    S.E. Kansas
    SR5 V6 4x4 Ext Cab
    I guess I need to change plugs.. I owned the truck about 8 months, and put 7k miles on it.. It sucked going up hills in south Mo.. I cleaned the MAF sensor, and the throttle body was spotless.. I guess new plugs, and air cleaner are next.. I am still not getting what I want.. I want at least 20 mpg.. Is that too much to ask for??
  16. Jul 9, 2010 at 10:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Good luck on seeing 20. Thats pretty high expectations. Especially since it was rated new at 16-19. Maybe if you drive only below 50 mph without any stop and go, then you may see 20+. But how realistic is that for all use.
  17. Jul 9, 2010 at 10:26 PM
    JohnnyTRD
    JohnnyTRD New Member
    Seattle
    10 PreRunner SR5
    My first post but given the topic and my personal interest I thought I'd chime in. I've got a new 2010 PreRunner, its about to turn 1800 miles, not even broke in yet. I've checked a few tank fulls and have been surprised at the limited variation between "highway" and "City" MPG. That said based on this thread I can't complain one bit. She got 21.5 MPG "highway" only (a run up to Vancouver, BC and back via I5, most time between 60-75 MPH) and 19.3 MPG in and around the Eastside (city traffic). My point isn't to brag but to suggest that the truck and the V6 (auto trans) is capable of more. They're great trucks and your effort should pay off!
  18. Jul 10, 2010 at 12:42 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Based on my Scangauge, I see an avg of 20-25 mpg at freeway speeds (65ish). On the other hand, just maintaining a steady speed at 35, my mpg is pretty steady at 16 mpg on a long straight road. Thats just the way the truck is. I'd be really surprised if you see much better than that with a v6 auto.
    A lot will also depend on how much you have to stop and go, as the first gear is really terrible for mpg, as is the case with all vehicles. (a made up example (actual figures vary on driving style, etc): the engine is working just as hard going 10 mph as it does going 60, but your only covering 1/6th the distance)
  19. Jul 10, 2010 at 1:41 AM
    kumaWRX
    Jase
    Oahu, Hawaii
    I didn't say that octane was a measurement of how "good" a fuel is. Octane is a gasoline's resistance to detonation. Gasoline by itself is about a 55 octane rating and pure octane is 100 if I'm not mistaken. The less "knock" events that the ECM picks up, the more it can advance ignition timing, etc which does increase power.
    I read about a test using 87 and 93 octane in a 2nd gen Tacoma. It was the same truck on a loaded dyno and using 93, it gained about 10 horsepower at the crank. Because the ECM could advance the timing more or retard it less, either way, more power was made with the higher octane.
    On the contrary, a common misconception is that using a higher octane(in a car that doesn't require it) will NEVER gain you extra mpg. Whenever I fuel up I always calculate my mpg and I always wondered if I should use 87 since everyone say that there is NO benefit from a higher octane in our Tacomas. So I did my own testing, I was already using only 92 octane from Shell so I already had my avg mpg which was consistent throughout. I then did 3 tanks of 87 octane also from Shell and I had a drop in mpg in all 3 tanks of 87 and I drove the same routes more or less and my driving habits stayed the same. The drop in mpg wasn't much, about 1 mpg, but if you do the math, to go the exact same distance on 87 vs. 92 the 87 actually was a hair more! Also, Shell V-Power has 5x the govt. minimum amount of additives whereas their Reg and Plus have about 2x the minimum. Also I just like the peace of mind that I know my valves and ports, etc are probably spotless. I also like the peace of mind that I can floor it when I want and not have to worry about pinging.
    In summary, I don't care what ignorant people say or do. These are my own facts/opinions/preferences, nobody has to agree with them. I'm merely showing a non-mainstream perspective on things to show that not everything is "black and white" and no one knows everything.
  20. Jul 10, 2010 at 7:06 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Hm... I have 01 V6 manual with a lift and 32s and I am getting around 20. On the highway to Cape Cod and back I got 23ish.
