Crunch, Clunk and Crank when Turning Slow at Full Steering Lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vasmastr, Mar 22, 2022.
  1. Mar 22, 2022 at 1:51 PM
    Vasmastr
    Vasmastr [OP] Have Tacoma, Will Travel...
    North County San Diego
    2016 Tacoma V6 3.5L TRD Sport
    I hit a Ridge at 40ish-mph on the passenger side, which set off my driver and passenger side airbags.. Didn't need coffee that morning....
    Took it to Toyota (1st mistake), they changed the lower control arm, turned the rotors a bit and did an alignment. (their alignment has to much much camber, but is wearing even on the inside of each front wheel)
    First they said they couldn't get it to align, so I gave them the spec sheet given to me by ORW after they added new front and rear shocks. ORW had it lined up perfect...
    Not surprisingly, she pulls to the right... I'm ready for new tires and an alignment, BUT....
    Since then I've been hearing what's described in the Header...
    What's bent that Toyota didn't find ?
  2. Mar 22, 2022 at 2:15 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Axle shaft, UCA, spindle, frame horn, wheel...plenty of other things to bend hitting an anchored object at 40ish mph. Is the tire hitting anything? Nowhere near enough information to go off of here.
  3. Mar 22, 2022 at 2:32 PM
    Vasmastr
    Nope, The tire isn't hitting anything. I've got a 1.5" lift and 1.25" wheel spacers..
    I know there are are a lot of possible "can be wrongs". What does your gut say ?
  4. Mar 22, 2022 at 3:46 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I would have taken it to a collision/bodywork shop to get an estimate and then likely turned it over to my insurance company.
    whatstcp likes this.
  5. Mar 22, 2022 at 4:43 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    Your bags popped, call insurance. If they didn’t replace entire coil over with top hat, that is the problem, along with possible other stuff
