Crunch noise front right
Discussion in 'Suspension' started by Sb_Bob_E10, Mar 14, 2011.
  1. Mar 14, 2011 at 6:26 PM
    Sb_Bob_E10
    Sb_Bob_E10 [OP] Well-Known Member
    Bobby
    Goleta/Santa Barbara,Ca.
    10 Tacoma 4x4 Sport LB
    Icon's Extended C/O's, 285/70r17 Duratracs on Eagle 063's Raven Black, Weathertech floor mats,AFE Drop In, 1" block in rear for now w/ billie 5100's.
    I'm getting a crunching metal sound from my lower control arm. The noise happens when I turn the wheel to the left, over a bump, and or in reverse as well as when applying the break at under 5mph. (even louder when 4x4 is enaged)
    I had my good ole mom turn the wheel left, right, left, right, left, right, for a while until I clearly felt it coming from the back side of the passenger lower control arm but not felt on the front side of the arm.
    Does anyone know what this can be? noise was a little present when I got my allignment done, I always thought it was brake pad play but it's gotten louder and louder....
    I searched and searched all I was able to find was sway bar noises, which i previousley had but with a sway bar relocater bracket fixed that.......
  2. Mar 15, 2011 at 7:40 AM
    Sb_Bob_E10
    Bobby
    Does anyone know what the lower control arm torque specs are, and does anyone know if I'll throw my aligment off while re-torquing (cams)?? I'm almost thinking this my be the problem, I now recall my truck screaming some horrid noises the last time they did my alignment......
    Thanks.
  3. Mar 15, 2011 at 12:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The lower ball joint attachment is torqued to 118#, and the cam adjusting bolts are toqued to 100#'s. You may want to have the dealer look at it if your under warranty.
  4. Mar 15, 2011 at 3:30 PM
    Sb_Bob_E10
    Bobby
    Thank You for taking the time to look at my post.
    I will do just that. I'm only at 13k any suggestions or just let them know i have an effn bad crunch? I just don't get the runaround anr or them say- thats it! That is caused by your lift, its on you! ( I got Icon's Extended, UCA's Camburg, 285's) sorry for sounding in anyway ignorant. Still consider myself a noob:D
  5. Mar 15, 2011 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worrys :)
  6. Mar 16, 2011 at 6:27 PM
    Sb_Bob_E10
    Bobby
    :)Fixed! Bottom LCA bolts were loose.
