Crunchy Taco? - 1st gen on 35s BS
Discussion in '1st Gen. Builds (1995-2004)' started by Wulf, Jul 29, 2015.
  1. Apr 25, 2020 at 7:14 AM
    #641
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    The fact RCV only warranties the 19 spline to a 35” tire says a LOT. Stock toyota axle shafts are about the same as stock Dana 60 shafts and super safe to 37’s. Chromos are good to 40’s.
    Wulf[QUOTED][OP] likes this.
  2. Apr 25, 2020 at 7:26 AM
    #642
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    My vote is go back down to 33’s and enjoy wheeling for now. I know internet cred is awesomer on 35’s and IFS but the reality is that shit starts breaking with some regularity at that point.
    It won’t kill you to keep your eyes open for a deal on a complete rig either. Picking up somebody else’s project is always more economical than building new. The upside to a good set of axles/tires/wheels is that they can go under anything and are an investment long term.
    It’s part of why I’m considering an 4.3 LV3 swap on my Tacoma now that I’ve got another 3RZ on its way out. Yeah, it’s a $6500 upfront cost for the engine/trans/atlas but it’d be the last drivetrain I’d ever need.
  3. Apr 25, 2020 at 7:39 AM
    #643
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The are not many trails in Colorado that 33's coupled with lockers can't handle. Sure you can't do the hardest lines but at that point you should probably have a cage and zero fucks about body damage.
    Arctic Taco and Wulf[OP] like this.
  4. Apr 25, 2020 at 9:19 AM
    #644
    Wulf
    Wulf [OP] no brain just damage
    rock raisin
    Yeah, I definitely fucked up there; I was so excited to jump on this axle for the FF setup and disk brakes that I didn't consider the chromos being a step down...because chromo. It was all supposed to be a big improvement from stock in terms of brakes, housing strength, maintenance, etc :homer:
    I sold a factory e locker housing and shafts for $150 and I'm wishing that I hadn't. Transfer my third back into it and sell this setup from under the truck. The fact that it had 2+ previous owners should have been a clue, right? :homer:
    The spare shaft I have is already starting to twist at the splines so now I'm wondering when I'm gonna be doing the same spindle, wheel hub, bearings, rotor job again. I don't want to keep feeding $400 shafts and $200 in spindle and wheel hub parts into this axle with every failure so I'm keeping an eye out for other options.
  5. Apr 25, 2020 at 9:20 AM
    #645
    Wulf
    rock raisin
    The reality is that I'm still, for the most part, running the same trails that I was on 31s and 33s just with more ground clearance and altered lines.
    m3bassman and Reh5108[QUOTED] like this.
  6. Apr 25, 2020 at 9:28 AM
    #646
    Wulf
    rock raisin
    I agree somewhat. As for "wheeling hard" a lot of these failures have been on easy trails and dirt roads but I won't argue that the parts were probably compromised beforehand.
    Hard to believe that on tons and 37s I'd be going through u joints, axle shafts, steering parts, etc.
    I carry 2 spare CVs and 2 spare hubs because they are easy enough to change...except when you break the splined end of the CV off inside the axle tube. Likewise, I carried a spare rear shaft but you can't change it when the shaft grenades the spindle with it
    slander likes this.
  7. Apr 25, 2020 at 10:04 AM
    #647
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Just go buy a Chrysler as a daily and you’ll feel better knowing you have something that breaks when you look at it
    Reh5108 and slander like this.
  8. Apr 25, 2020 at 10:59 AM
    #648
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    The easy trails are usually where you break. The only cv I ever broke was on a basketball sized rock, on a trail exit. 400ft earlier I was idling with the front end about 4ft off the ground and the bed dug into a rock face that I was leaning into. I blew the trans up leaving a stop light on the way to a grocery store and stripped a tcase input leaving work, my trucks more reliable crawling LOL!!!
    I agree with the others, drop the tires down to 33s and save up for some real axles and 37s.
    Wulf[OP] likes this.
  9. Apr 27, 2020 at 3:59 PM
    #649
    Wulf
    rock raisin
    GF talked me into taking the truck out this weekend since I've been cranky staying at home. We ran Hackett which is pretty much all dirt and loose gravel. It did well enough and I didn't break anything :)
  10. Apr 27, 2020 at 4:06 PM
    #650
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Glad to hear you got the truck back on the dirt! Even if it isn’t super technical wheeling, it’s gotta feel good making it out and back without any drama.
  11. Apr 27, 2020 at 4:39 PM
    #651
    Wulf
    rock raisin
    Yeah, it was good. Not sure if the PS pump is better than the last one or the improved hose routing and lack of a filter is making for less resistance but it doesn't whine at full lock like the last one did immediately after installing. Hope it lasts longer than the last one :D
    The trails were a shit show, so much reckless driving and impatience with people cutting loose and then some. Had a moto almost dump his bike into the side of my truck trying to pass without giving me a chance to get over. We also got stuck because of a SXS roll over because they were driving too quickly
    jubei[QUOTED] and slander like this.
  12. Apr 28, 2020 at 5:07 AM
    #652
    cynicalrider
    cynicalrider #NFG
    Jersey
    You are making me nervous about my filter now lol.
  13. Apr 28, 2020 at 8:23 AM
    #653
    Wulf
    rock raisin
    I don't think the filter really was the issue; it shouldn't add that much resistance at all.
    In order to put the filter in I had some janky hose routing and I think I had a bend that was getting pulled too tight
  14. Apr 28, 2020 at 8:31 AM
    #654
    cynicalrider
    cynicalrider #NFG
    Jersey
    Makes sense, I tried my best to keep smooth curves on mine. Also solid avatar.
  15. Apr 28, 2020 at 8:58 AM
    #655
    Wulf
    rock raisin
    Yeah, I believe I tried to follow the 3" radius rule that the hose MFG imposed... I think the line going out the core support to the cooler was getting restriction where it met with the hardline and pulled the hose partially closed
    I am planning on getting magnets to stick on the reservoir to collect any glitter that I create without needing the inline filter.
    jubei likes this.
  16. Apr 28, 2020 at 5:41 PM
    #656
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
    Wait....there's a GF??? Thought you were in quarantine???
  17. Apr 29, 2020 at 12:38 AM
    #657
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    I was under the premise that he still thought that girls were gross :confused:
    jubei and Wulf[OP] like this.
  18. Apr 29, 2020 at 1:11 AM
    #658
    Empty_Lord
    Dan
    I thought he was a she!
  19. Apr 29, 2020 at 6:34 AM
    #659
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    There is something to be said for matching your tire size to the axles and drivetrain. IFS and 33's, Toyota axles and 37's, tons and 40's all pair well together and you generally don't have to worry about breaking them. I have way more fun wheeling than I do internet bragging rights to having the biggest tires. Breaking and trying to fix yourself on the trail sucks, and even sucks more if it ruins a long wheeling trip.
    In 6 years of wheeling my current setup, I've broken one inner axle shaft when I was bound up in rocks as big as my truck. Other than that I've never cut a trip short or had a major failure. Just PM every winter and good to go again.
  20. May 7, 2020 at 9:03 PM
    #660
    Wulf
    rock raisin
    Tow rig tech counts, right?
    The factory cold side intercooler pipe on my 6.7l PSD is plastic. After a lot of hemming and hawing I decided $300 now is better than a $300+ tow when I blow out the factory plastic one while towing in an inconvenient location.
    95k miles of CCV gunk and EGR soot. Gross. Charge air pipe was an easy install. I'll get on it more tomorrow to make sure it's not leaking
    jubei likes this.
