Crush Washer....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, May 29, 2011.
  1. May 29, 2011 at 7:03 AM
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Did the drain and fill on my '05 automatic transmission the other day, and lost my crush washer on the drain plug. Noticed this morning that ATF is starting to weep around the drain plug due to said washer missing.
    My dealer prolly won't have this in stock, and I don't want to wait a week for it.
    Anyone have any idea what size the crush washer is on the V6 auto drain plug?
  2. May 29, 2011 at 1:46 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The dealer normally has the crush washers in stock. Or, you can use a copper brake banjo crush washer. Just measure carefully.
  3. May 29, 2011 at 3:12 PM
    Fortech
    CANADA
    I've been to my dealer in the past looking for crush washers - the normally don't stock anything other than the ones for the engine oil pan. I'll get a quart of ATF WS tomorrow anyways, and if in a pinch will use the washer from the engine oil pan as a temp fix.
  4. May 29, 2011 at 6:39 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    One dealer in your area should be smart enough to carry those washers. You're not the only guy who changes trans fluid. Call around.
  5. May 29, 2011 at 7:42 PM
    Fortech
    CANADA
    Will let everyone know how it turns out.
    Only one dealer in this town. The next closest is a 6 hour return trip.
    If I wasn't stuck for a replacement, I wouldn't have bothered to post. None of the automotive stores that are open on Sunday had anything of value either.
