Crush washers for the auto tranny pan and oil pan the same?
Discussion in '1st Gen. Tacomas (1995-2004)' started by OldBoysToys, Aug 14, 2015.
  1. Aug 14, 2015 at 10:49 AM
    OldBoysToys
    OldBoysToys [OP] Active Member
    Jim
    1997 Black extracab tacoma - 2002 Imperila jade extracab TRD Tacoma
    Bilstien shocks toy tec lift Brush guard / Helwig 1250 Helpers
    didn't do an oil change yet on my newly acquired 2002 3.4L Tacoma .but need to know are the crush washers for the auto tranny pan and oil pan the same? . there's non on my tranny plug and it's like weeping a bit ,Went to the lacal auto parts store ,he told me it don't have drain plug. and hence could not help me.i ordered some on line. ~~OBTs~~
  2. Aug 14, 2015 at 7:42 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    They are a little different however I went to get one for transmission drain plug at the dealership and they were out so they gave me 10 oilplug washers for free and said that's what they use sometimes.
  3. Aug 14, 2015 at 8:13 PM
    OldBoysToys
    Jim
    Thanks that's what I'm gonna use they are both 12mm .got 10 for $5 online--and I'm not running 50 mi round trip to the dealership and paying $2 ea ~~OBTs~~
  4. Aug 15, 2015 at 11:40 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    when you need a washer for the oil or tranny drain plug cut cut one out of a cardboard oil filter box lid, if you want it to look pretty draw a pattern of it using a regular flat washer fist. just drill the hole first then cut out the outer edge. I just drill the hole, stick the bolt through it, then cut the excess off around the flange with a scissors. everytime you change oil you have an oil filter box your throwing away anyway so there is your gasket material.
    when I make these gaskets they have never fallen apart or needed replacement yet but I suppose over a few years you might need to remake it again at some point down the line. I don't think it matters but I put the ink side out and the cardboard side towards the pan.
  5. Aug 15, 2015 at 1:25 PM
    OldBoysToys
    Jim
    Yrs ago they were made from copper and lasted forever .Back on my 87 Extra Cab I had found some scrap copper flashing and made one .Had that truck 15 1/2 yrs and never had to replace it. If can find a heavy ga. pc of copper this would be your last washer you should need. ~~OBTs~~
