Crush washers need to be re-torqued
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willtill, Jan 2, 2023.
  1. Jan 3, 2023 at 7:56 AM
    #41
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    The only bullshit is someone claiming they torque everything every time. You wouldn’t last very long in the real world as a mechanic
  2. Jan 3, 2023 at 8:03 AM
    #42
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    stop buying maintenance items on Amazon. or at least buy GENUINE Toyota products, that are REAL Toyota products. how hard is it? what did you save? now ask yourself that, when you have to pay to have a new engine or trans put in, due to your failure, in replacement parts sources. Ski
    VB25 and GilbertOz like this.
  3. Jan 3, 2023 at 8:05 AM
    #43
    eurowner
    eurowner Duke Sky
    Scoty
    I paint-marked it though.......
  4. Jan 3, 2023 at 8:09 AM
    #44
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    What are the odds of that happening once let alone twice- wow!
  5. Jan 3, 2023 at 8:09 AM
    #45
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    likewise I paint mark everything
    They couldnt afford us anyway :)
    Literally every bolt is torqued to spec and painted from the oilpan to the valve cover.
    Taco X and cryptolime like this.
  6. Jan 3, 2023 at 8:10 AM
    #46
    mquibble
    Michael
    2021 TacomaTRD Pro
    Not me. I’ve got a Fumoto. Sorry, couldn’t help myself.
  7. Jan 3, 2023 at 8:15 AM
    #47
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Every quick-lube drain plug that I've found loose was paint marked.
    TnShooter likes this.
  8. Jan 3, 2023 at 8:19 AM
    #48
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    A paint mark means absolutely nothing if you're installing a different washer than the one you paint marked.
    cryptolime likes this.
  9. Jan 3, 2023 at 8:26 AM
    #49
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    I bought a torque wrench years ago; my father (a mechanic his entire life) gave me a really weird look when I whipped it out one day working on something. While there's validity in the importance of proper specs, I think its also safe to say that "most" vehicle components have a fairly large margin of error. Experience goes a long way for people who have done it their entire life, and they know without a doubt when something "feels" too loose or too tight. Its not rocket science (where I assume precise specs are a little more important). That being said, I bought a torque wrench because I was NOT experienced. I use it on every lug nut; but only after I've installed them with some ugga duggas and driven for a few days. I think for some applications, its necessary; for most, its just for peace of mind, and being a few ft/lbs off surely has less of an impact than some of these tire and suspension mods we see here daily.
  10. Jan 3, 2023 at 8:26 AM
    #50
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I don’t use a torque wrench on everything, least of all the lonely oil drain plug.
    I do use the torque wrench for multiple fasteners, that require a tightening sequence such as tires. I don’t have to, or need to, but the majority of vibration and shudder complaints are due to shops and their exclusive use of power impact wrenches, with excessive torque.
    Moreover, there are some mistakes, confusion or miss prints on TOYOTA SM in regards to torque specifications. I remember when the leaking rear diff came out as an example and there are others so it’s always best to rely on your skills first, and verify with a machinist bolt torque chart.
    This is (oil plug) critical to be sure, and you need to get it right so attention is required, but rocket science is not.
  11. Jan 3, 2023 at 8:57 AM
    #51
    rageman
    rageman Well-Known Member
    Keith
    2018 Barcelona Red Tacoma TRD Off-Road
    I've assembled several engines, too. Still don't use a torque wrench on oil drain plug.
    auskip07 and MGMoverland like this.
  12. Jan 3, 2023 at 9:01 AM
    #52
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Wow. Now we not only have a million oil threads, we even have oil drain crush washer threads lol :rolleyes:
    GilbertOz and ToyoTaco25 like this.
  13. Jan 3, 2023 at 9:13 AM
    #53
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    i would buy them from rockauto. you really never know what you are getting with Amazon. they got a 25 pack for $13.75.
  14. Jan 3, 2023 at 9:14 AM
    #54
    JoeCOVA
    Joe
    Colorado Springs
    Ya lots of people build engines. Lots of those engines fail after a few thousand miles too. The point is someone said it’s bullshit that someone says they torque every bolt every time, I simply proved that wrong.
    What’s funny, google stripped oil drain plug. It’s probably the most common and most consistent bolt to be stripped across all brands, Ford, Chevy, Yamaha, Harley. It’s kinda comical.
    timclark82 and The hammer like this.
  15. Jan 3, 2023 at 9:15 AM
    #55
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    one of the reviews confirms your experience:
    Reviewed in the United States on March 2, 2022
    Color: 25PcsVerified Purchase
    Great price for “crush” washers. The fiber does most of the sealing, I think. Swapped out the original GM plug for a magnet plug, this fits great. The outside diameter is a little smaller than the flange on the plug but that’s ok. I used the Votex “Made in Wisconsin” plugs sold on here, flange is same size as stock GM plug, and this washer is the same size as the original rubber washer. Torqued to factory specs (25 Nm) was no leakage when first installed. Just finished a 300 mile trip, no leaks, no drips, it’s holding up! I will drill it out a little for the 1/2” plug I have.
    1st pic is this crush washer over a copper one, second is copper over the OEM plug to show coverage. The aluminum washer at the bottom is what comes with the Votex plug. You can see the copper washer is a (very) tiny bit larger.
    Edit: Drilling it out isn't as easy as I thought, a 1/2" bit just digs in and snags the aluminum, so I started with a 15/32" bit and reamed it while holding it cupped in my fingers. Use the 1/2" bit to determine the finished size. A 31/64" bit is a snug fit in the original hole, but my 15/32" bit worked better, i think it was sharper.
    Edit 8/23/22: I just did an oil change on the second vehicle, and the drain plug was loose! I could take it off by hand!! Both vehicles had this issue, I thought the first one might be a fluke, but the second confirms the issue. I tightened both to factory specs with torque wrench 25 n/m (18ft/lb). There is some kind of brown fiber pieces around the edge of the gasket, both had that. It wasn't leaking, and I'm amazed it had't fallen out. The one vehicle went 5,700 miles, the other 3000. I am using the Votex Stainless Steel Plug with this, so not sure if this is a gasket issue, or a plug issue, but I would assume the gasket.
    I reused the plug with a new gasket, this time torquing to 40n/m (30ft/lbs). I think I felt the gasket crush, so hopefully it stays tight. I will check back in next oil change which will be in November.
    Edit 10/12/22: After torquing one new gasket to 40N/M it was loose again after only 15miles. The plug was hand tight. The other vehicle I torqued tighter also was loose. Apparently these do not have enough friction to keep the plug from loosening. See the two pics I added, the glue that holds the fiber onto the aluminum melts with heat, the fiber wafer easily peels off of the surface. Maybe the glue has failed and allows the plug to turn, I can't verify the cause, but I do know that the plug loosens up after a very short time. I DO NOT RECOMMEND THIS PRODUCT.
    and another:
    Reviewed in the United States on August 29, 2022
    Bought these several times, and they seemed to work great until one day one of my customer’s car came back on a tow truck. What happened was the plastic got softened, thinner and drain plug got loose. Every time my customers came back for an oil change, we replaced drain plug gasket with a new aluminum. washer. NEVER BUY THIS AGAIN!"
    eurowner likes this.
  16. Jan 3, 2023 at 9:26 AM
    #56
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    I think everyone has their own take on what is right or wrong for tightness of a drain plug. To discount a veteran technician on weather he/she uses a torque wrench on a drain plug is ridiculous. When I assemble a engine everything gets torqued. When I am changing oil for the millionth time I generally know what it should feel like when it is tight. I now work in aerospace where everything is not only torqued but also witnessed. You want to talk torque specifics? :thumbsup:
  17. Jan 3, 2023 at 9:26 AM
    #57
    willtill
    willtill [OP] Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    I will keep my eye on it. Hopefully the second torqueing I did on it will not have to be repeated. Or I will have to drain the oil and put an aluminum crush washer on. And then put the drained oil back into the engine. I'm not tossing motor oil with less that a couple hundred miles on it.
    I do not think I'll use these again for the next oil change.
    JoeCOVA and The hammer like this.
  18. Jan 3, 2023 at 9:27 AM
    #58
    The hammer
    Yeah, most of the stripped plugs are done at the quick lube places, where only speed matters.
    The poor owner gets most of the blame after he decides to DIY because the oil was over/under filled and the filter was tightened by King Kong lol!
    JoeCOVA[QUOTED] likes this.
  19. Jan 3, 2023 at 9:28 AM
    #59
    rageman
    Keith
    I would agree that it's not BS to torque everything, I'd just say to each his own.
    To make your point for you, I repaired several other technicians mistakes in this area...whether it be drain pan plugs or over-tightened lug nuts. Some people don't have "it" upstairs.
  20. Jan 3, 2023 at 9:30 AM
    #60
    The hammer
    Or you could use new oil and call it an engine flush, and call it a day
