Crush washers need to be re-torqued
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willtill, Jan 2, 2023.
  1. Jan 4, 2023 at 11:15 AM
    #101
    scocar
    scocar Patron of the Farts
    OMG NO! DO YOU HAVE A DEATHWISH?
    syswalla, 23Skidoo and b_r_o[QUOTED] like this.
  2. Jan 4, 2023 at 11:16 AM
    #102
    eurowner
    eurowner Duke Sky
    Scoty
    b_r_o likes this.
  3. Jan 4, 2023 at 11:19 AM
    #103
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    This has already been figured out after 6 pages, I’m assuming, but those Amazon washers are garbage. Read through the reviews a bit and you will read some bad stories. I bought my crush washers from Rockauto. Not EOM but seem to be similar enough. No issues thus far.
    ejl923 likes this.
  4. Jan 4, 2023 at 11:22 AM
    #104
    scocar
    So what should I be torquing my oil filter to?
    willtill[OP] likes this.
  5. Jan 4, 2023 at 11:23 AM
    #105
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    No shit! I weld mine on, then use a grinder to get the plug off to change my oil. Btw, I change my oil once a week, every 350 miles.
    syswalla likes this.
  6. Jan 4, 2023 at 11:37 AM
    #106
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    for those that are torqueing the drain plug... being that the drain plug/hole is wet are you recalibrating the 30lb torque value?
  7. Jan 4, 2023 at 2:23 PM
    #107
    pyankura
    pyankura Well-Known Member
    17 TRD SPORT QUICKSAND
    Interesting, would that make it not stay tight or lose its torque?
  8. Jan 4, 2023 at 2:39 PM
    #108
    willtill
    willtill [OP] Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Torqueing to 30ft lbs per the manual; per Toyota's recommendation. I'm sure they took into account the presence of oil during this sequence.
    MR E30 and MGMoverland like this.
  9. Jan 4, 2023 at 4:03 PM
    #109
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    I know this is overlill but coming from drag racing bikes i always safety wired things.
    On el diablo taco i safety wire the drain plug and filter cover
    Nuts i kno
    GilbertOz likes this.
  10. Jan 4, 2023 at 4:07 PM
    #110
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
  11. Jan 4, 2023 at 5:38 PM
    #111
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    A vital sealing gasket for the most important fluid in the vehicle, sold under a fake brand name, from a third party seller on Scamazon?
    Engines are so expensive, man. The OEM crush washer does not behave like this. I swear it gets tighter when I go to remove it. I use a small torque wrench at 25ft-lb.
    good thing you caught it before you lost the oil!
    OffroadToy likes this.
  12. Jan 5, 2023 at 4:44 AM
    #112
    pyankura
    Not trying to hijack dudes thread but I am using what a Toyota dealer is giving me and it does act like this. To sum up, I didn’t torque them at first, then they gave me an aluminum ones that worked, then back to the fiber one and same issue but started torquing and it did not hold torque. (70k @ 5k oci)
    I don’t really care, I was just adding to this thread for information purposes. Retorquing works for me so that’s what I do.
    barber, you may proceed…..
  13. Jan 5, 2023 at 5:25 AM
    #113
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    My dealer sells them for a whopping .88 each. I plan on buying those and doing the TRD Pro oil filters for my oil change intervals which will be every 5k or less. Invest this much money in a vehicle just seems silly not to use OEM maintenance products.
  14. Jan 5, 2023 at 7:47 AM
    #114
    willtill
    Maryland
    The two Toyota dealers I have near me would charge $3.00 for a drain plug crush washer. I chit you not.
  15. Aug 21, 2023 at 8:23 AM
    #115
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    i would like to amend my previously statement. Went to do an oil change yesterday and found my oil drain plug loose enough to maybe undo by hand. Same gaskets I've been using. I doubt i forgot to torque these, change was done 6000 miles ago with no leaks. Im actually surprised i havent seen a drip it was so loose.
  16. Jan 4, 2024 at 8:40 AM
    #116
    lj4028aim
    lj4028aim Member
    MP, WA
    2021 Cement Tacoma Off-road LB
    Reading through your experience, I want to share a bit of mine. It's not about my taco but for a Subaru Forester. I purchased such crush washer from big auto store for the oil change (I don't want to throw out their name here, but they are nation wide). The next time when I was under the vehicle, I found class 2 leakage. The drain plug was quite loose which you can barely use two fingers taking it off. I am sure I snug tight the drain bolt last time. After doing a little research online, some people has exactly same issue as me which is from such crusher washer. It is made by material like fiber. Since then, I changed back to metal crusher washer. Not sure why such fiber crush washer is popular nowadays.
  17. Jan 4, 2024 at 9:19 AM
    #117
    ejl923
    Eric
    Western Mass
    unfortunately for me it was the metal washers getting crushed too much. I just changed my oil after having to retorque and the washer was almost flat. Never happened that way before. I just bought new washers so we'll see if it was supply chain issues and very soft aluminum.
