Cs144 swap Q&A's
Discussion in '1st Gen. Tacomas (1995-2004)' started by Yotacoma92, Mar 12, 2013.
  1. Mar 12, 2013 at 11:01 PM
    Yotacoma92
    Yotacoma92 [OP] TacoLover
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    Westin brush guard, smitty built nerf bars, roll bar, K&N air filter, Helo 17" Rims with 285-65-17 BFG KM2's, OME 2in lift springs, 0-2.5 lift Bilstein 5100 struts, OME 3in lift leaf springs, 5125 bilstein rear shocks, Projector HID headlights, Blacked corner lamps.
    I am about to do the cs144 gm alternator swap and ive already upgraded the wiring to 4 gauge. my question is do i need to replace the stock 80 amp fuse that is between the alternator and the battery? i know the alternator will be putting out roughly 140 amps and i dont want to blow the fuse and run off battery power until my truck dies in the middle of no where. also do i need to replace the engine to chassis ground with 4 gauge as well? im going to be pulling 33 amps for the electric fan im swapping in, bout 15 amps for HID's, etc. with system, 5000 watt monoblock amp. thanks ahead of time for the help.
  2. Mar 12, 2013 at 11:08 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I've been considering this mod also. Sub'd for information.
  3. Mar 12, 2013 at 11:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    He man.
    I just did this and have done tons of research.
    There are several people out there that have done this that actually have sucessfully run the CS144 off the stock wiring...very sketchy though if you ask me.
    I would up grade yes. Im using an actualy breaker. You can get them at most auto stores. Its rated at 150amps and if it does pop..no need to carry extras. Worth it to me.
    I also had to get a much larger belt then all the posts i read. Most guys that have done this you will find have the SC. So thier belt works great. Others found that if you just got a Power steering belt for the alternator it would work. Well..didn't for me. I had to get still a larger belt.
    I have the part number and length. Just haven't uploaded the picture but i will for you tomorrow.
    i have many many threads with info book markted. Also i am going to put together a write up as i wired mine for use with the CS144 but you can switch back to the stock on the trail if your CS144 blows out on an expedition or whatever. Also my build will have it all in there.
    Any other questions im more then happy to anwser.
    oh and forgot about the grounds..
    Yes, very good idea to run a 4ga wire to the body and the frame to help with current flow. Its all part of the Big Three upgrade and does help especially if your going to be running lots of stuff....which i am..a LOT. So i am doing this as well.
  4. Mar 13, 2013 at 1:16 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  5. Mar 13, 2013 at 12:42 PM
    Yotacoma92
    Zack
    lima, ohio
    99 Tacoma SR5 4x4
    what about the routing of the wire? the stock wiring goes from the alternator to fuse block, then fuse block to battery. do i jus need to run a wire from alternator to battery then battery to fuse block and ground the fuse block to the battery?
  6. Mar 13, 2013 at 1:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I am just use the stock wire that goes to the battery from the fuse box to send it power. There is no ground on the fuse box. All the grounds are else where in the the truck.
    However if you do that like i am. You have to disconnect the old stock wire that came from the alternator. Very easy to do its just in the fuse box.
  7. Mar 13, 2013 at 3:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :woot:
    Finished mine officially just now. Started right up.
    Ill do a write later today
