CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Mar 20, 2018 at 5:57 PM
    #181
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Yep...narrowed it down to the fan or radiator. When we check/test the fan, it seems to be working fine, though.
  2. Mar 20, 2018 at 6:04 PM
    #182
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    Since we are on the subject of cooling and crappy fan clutches has any one ever looked into modifying the factory fan clutch? I know wits'end modifies 80 series clutches by using heavier oil along with a larger volume. Sure it will rob the engine of a few ponies but I would rather have a cool motor with consistent power than a detonating time bomb...
  3. Mar 20, 2018 at 7:01 PM
    #183
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    So...maybe its just me...but I have a 06 2.7l manual...Even in Oklahoma during the summer with temps well in excess of 100 degrees (I've had over 60 days straight of 110+ temps) and I have had no issue even with a full bed of firewood in the summer time. Is the 2.7l manual trans somehow that much easier to cool or am I just lucky?
    Roostfactor[OP] and loginfailed like this.
  4. Mar 20, 2018 at 7:23 PM
    #184
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I can’t answer that, but I’m my case it’s an automatic and there’s a big supercharger cooler in front of the radiator. So a bigger all aluminum radiator should help.
    Norton and trekker like this.
  5. Mar 20, 2018 at 7:25 PM
    #185
    ThomasMore66
    Dallas/Fort Worth & Durango
    Drove home from work 30 miles. Managed to drive between 80 and 90 part of the way. Stock radiator and 180 thermostat in 65 degF weather. Ran 185-190. Thought it would be lower.
    loginfailed likes this.
  6. Mar 20, 2018 at 7:26 PM
    #186
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Besides the illusion of everyone's truck being equal, there are many differences behind the screens, of each owner's truck.
    4.0L > 2.7L. Same radiator, but larger engine.
    OEM grill. Aftermarket grill.
    Auto trans or manual.
    Grill obstructions of any kind.
    Dirt saturation of cooling fins.
    Lack of ducting that the 4Runner has.
    No diverter panel.
    Etc., etc....
    Roostfactor[OP] and PapaBear like this.
  7. Mar 20, 2018 at 7:27 PM
    #187
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Is your truck supercharged?
  8. Mar 20, 2018 at 7:28 PM
    #188
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh: :cookiemonster:
  9. Mar 20, 2018 at 7:29 PM
    #189
    dnpbakon
    Kevin
    Lol re-read his post. That my bad :rofl:
  10. Mar 20, 2018 at 7:30 PM
    #190
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All good.
  11. Mar 20, 2018 at 7:38 PM
    #191
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Get ductile iron sleeves. Larger radiator instantly jumps to front of the line of all mods....
  12. Mar 20, 2018 at 7:39 PM
    #192
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Maybe next week. :rofl:
    Roostfactor[OP] and GT7 like this.
  13. Mar 20, 2018 at 7:40 PM
    #193
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rasta:
    GT7 likes this.
  14. Mar 20, 2018 at 7:40 PM
    #194
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Mar 20, 2018 at 7:54 PM
    #195
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    CSF said they should ship by the end of the week but please post when you guys get confirmation. Im sure we are all curious.
    Murphinator[QUOTED] likes this.
  16. Mar 20, 2018 at 7:57 PM
    #196
    Roostfactor
    TX panhandle
    We had 10 degree temps in North Texas this winter while I had the CSF radiator and 160 thermostat. 168.8°F is what my low temp was.
    Norton and JuanitoBonito[QUOTED] like this.
  17. Mar 20, 2018 at 8:02 PM
    #197
    Roostfactor
    TX panhandle
    It's not a fan problem if it's happening at highway speeds.
    blu92in99 likes this.
  18. Mar 20, 2018 at 8:10 PM
    #198
    Roostfactor
    TX panhandle
    You also have no hot trans fluid going through the radiator heating up your coolant even more.
  19. Mar 20, 2018 at 8:12 PM
    #199
    Roostfactor
    TX panhandle
    Same temps I had with stock AND 170 thermostat. Me likely 160 much better.
  20. Mar 20, 2018 at 8:23 PM
    #200
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Sigh...
    Yet another thing to add to the list.
