CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Mar 29, 2018 at 11:55 AM
    #241
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Very true. Most of my packages come in 1 day :anonymous:
  2. Mar 29, 2018 at 3:44 PM
    #242
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I tried calling again today but only got voicemail. He maybe on vacation or a business trip?
    I just want to get some kind of status to relay to you guys!
    JuanitoBonito likes this.
  3. Mar 29, 2018 at 3:47 PM
    #243
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ask about the upgraded intercooler and tell him there is interest
  4. Mar 29, 2018 at 3:50 PM
    #244
    Roostfactor
    TX panhandle
    Are you talking about the one in front of the truck or in the sc?
  5. Mar 29, 2018 at 4:17 PM
    #245
    GT7
    Grant
    Phoenix
    2013 DCLB
    In front?
  6. Mar 29, 2018 at 4:30 PM
    #246
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Ken emailed me today and once I reiterated I was talking about the trd/magnusom supercharger intercooler it doesn’t sound like it’s a very high priority for them. To be exact he said:
    “Your input is greatly appreciated. I will let you know if that’s a project
    that we will consider looking into. I’m sure you’ll see in the forums if
    we do.”
    Kind of bummed about that, but maybe the one gadget is having made will work with our setup too? Time will tell I guess.
  7. Mar 29, 2018 at 4:43 PM
    #247
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    They will sell. Just need a motivated manufacture entity.
  8. Mar 29, 2018 at 4:49 PM
    #248
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yup. I bet Ron Davis would do it, but probably would be a little too expensive for most people to justify.
  9. Mar 29, 2018 at 4:51 PM
    #249
    Jesse
    Poulsbo
    15' DCSB OR S/C
    What do you think would be most benificial? The heat exchanger inside s/c or out front y'all?
  10. Mar 29, 2018 at 4:56 PM
    #250
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    The way it’s setup, we cannot really do anything with the heat exchanger inside the supercharger. Just is not enough room. With an exterior one, more volume would be good so the coolant stays cooler longer, which if paired with a faster pump will help keep the temps down a lot.
  11. Mar 29, 2018 at 5:01 PM
    #251
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Ahh. At one time i found a better pump on here. Just forget where. Mercedes part i think.
  12. Mar 29, 2018 at 5:07 PM
    #252
    ThomasMore66
    Dallas/Fort Worth & Durango
    Page 1.
  13. Mar 29, 2018 at 5:09 PM
    #253
    Jesse
    Poulsbo
    15' DCSB OR S/C
  14. Mar 29, 2018 at 5:32 PM
    #254
    Roostfactor
    TX panhandle
    Why do you guys think we need a bigger fmic? Mine has never been been more than slightly warm after running. Agreed larger coolant capacity from a larger fmic would help keep temps in check if you are having problems with the coolant temp not cooling off sufficiently at fmic outlet but I haven't had a problem.
    If you are running in the dunes I could see a problem due to being in boost a lot and low speeds so low airflow through the fmic, but for normal duty I don't see a need for it.
  15. Mar 29, 2018 at 5:38 PM
    #255
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    The more boost you run the hotter your intake temps as you know, but after a few hard runs back to back its going to be pulling heaps of timing. This is what ovtune told me when he dyno’d my truck. On the 3rd or 4th pull on the dyno the truck was getting lazy because the intercooler could not keep up.
  16. Mar 29, 2018 at 5:38 PM
    #256
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I over think things i guess. Problem solve all day at work. Same mindset with my truck. I forget toyota pays guys 6 figures a year to engineer these things.
    Roostfactor[OP] likes this.
  17. Mar 29, 2018 at 6:48 PM
    #257
    Roostfactor
    TX panhandle
    I remember seeing that in his thread and he did say that he had fans running for cooling, I just haven't seen any hard data that would justify the need. Someone needs to put a thermostat on the fmic outlet to monitor temps. I do have intercooler inlet and outlet temp probes.20170910_120428.jpg
    SonnyBones likes this.
  18. Mar 29, 2018 at 6:58 PM
    #258
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Do you notice much difference after doing some long wide open throttle pulls? 20 degrees? More maybe?
    Edit: whats the hottest you’ve seen on the before intercooler side?
  19. Mar 29, 2018 at 7:17 PM
    #259
    Roostfactor
    TX panhandle
    Normally cruising on the freeway outlet is 20ish below inlet. On a wot run I have seen 45+ temp differential.
    I don't remember off hand the highest I've seen on the inlet side. 175 maybe? Remind me in the heat of summer and I'll check.
    llibrm and Murphinator like this.
  20. Mar 29, 2018 at 8:53 PM
    #260
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I will try to remember, it’s hard since in my neck of the woods it’s already getting hot out again. If it’s hitting 175 and cooling it to 130 then that is good news. I believe you want the air going into the motor to not be over 135 or the computer starts pulling timing. Atleast on other cars that’s how it works. I’m not sure how it works on our trucks sincd I think the only intake temp sensor is the crappy one that is built info tbe maf sensor.
