CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Mar 16, 2018 at 11:37 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am pretty sure the 4.0/2.7 uses the same mounting holes, you could probably make it work but it may take some trial and error at first.
    Roostfactor[OP] likes this.
  2. Mar 16, 2018 at 11:40 AM
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I have no idea on that one. You will have to do the research and see if your radiator has the same dimensions as the 4.0.
  3. Mar 16, 2018 at 11:43 AM
    Roostfactor
    TX panhandle
    Good question. I told Ken at CSF that they might want to ensure they have a good supply of these since I had a pretty good idea when my post went live people would jump on it. You really cant beat the price for what you get with this!
    loginfailed and 04TacoRunner like this.
  4. Mar 16, 2018 at 11:45 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    GT7 and Roostfactor[QUOTED][OP] like this.
  5. Mar 16, 2018 at 11:46 AM
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    100% you can use this in a 2.7l
    Jcyr, loginfailed and Roostfactor[OP] like this.
  6. Mar 16, 2018 at 11:47 AM
    Roostfactor
    TX panhandle
    Thank you for the confirmation!
    MrCrowntown[QUOTED] likes this.
  7. Mar 16, 2018 at 11:51 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Yes
    Use the code :forummember
    I got mine for $331
  8. Mar 16, 2018 at 11:56 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Damn I didn’t think that code worked still. Oh well what’s $14 other than a couple beers.
    loginfailed likes this.
  9. Mar 16, 2018 at 1:47 PM
    Roostfactor
    TX panhandle
    Has anyone else ordered? So far I have the following that have already bought one:
    Loginfailed (First)
    Murphinator
    GT7
    Lucario Runner
    jojotoo
    JuanitoBunito (pending)
    I am curious of the demand on these so I am keeping track to see how many sell.
  10. Mar 16, 2018 at 1:59 PM
    MrCrowntown
    Alyn
    Ky
    Got some stuff to hock, and then im in!
  11. Mar 16, 2018 at 2:18 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I'm new to Taco's so what the pretty standard engine temp. (80 series is ~192-194)?
    Normal tranny temp.?
    Are y'all using UltraGauge type devices to monitor eng./tranny temp.?
    On 80 series the A/C shuts off @ 226°. Does the Taco have a built in protection & if so what temp. does it cut off @?
  12. Mar 16, 2018 at 2:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lucario Runner.
  13. Mar 16, 2018 at 2:48 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Tor,
    How does this compare to the ron davis?
  14. Mar 16, 2018 at 3:05 PM
    Roostfactor
    TX panhandle
    What is 80 series? Normal temp is around 185. I saw the same temps with URD's 170 thermostat so I tried the 160 that @Torspd spearheaded. Keep in mind that you need to have URD's thermostat kit in order to fit the colder one.
    I use an obd2 adapter and the Torque app to check my temps.
    Tranny temps vary greatly but around 180 in the summer just cruising on the freeway with no load.
  15. Mar 16, 2018 at 3:12 PM
    #35
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    80 series is 1991-1997 Land Cruisers/ LX450's.
  16. Mar 16, 2018 at 3:35 PM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Smaller overall. Still a very nice piece.
  17. Mar 16, 2018 at 4:42 PM
    #37
    Roostfactor
    TX panhandle
    Stop talking about my anatomy!
  18. Mar 16, 2018 at 5:12 PM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  19. Mar 16, 2018 at 5:22 PM
    #39
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Did this lower temps @ all, from the 185° you saw w/factory t-stat & 170° t-stat?
  20. Mar 16, 2018 at 5:59 PM
    #40
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Any possibility the fj shroud would work in the taco?
    Norton and loginfailed like this.
