CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Apr 24, 2018 at 10:56 AM
    #501
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Awesome. Thanks Greg. I’ll give that a read later for sure :thumbsup:
    ToyRyd04[QUOTED] and Murphinator like this.
  2. Apr 24, 2018 at 11:04 AM
    #502
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The trans fluid reservoir is quite a bit larger.
  3. Apr 24, 2018 at 11:12 AM
    #503
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Good to know. I have atleast 1 QT of new WS fluid, might pick up one more incase I need it for when I swap over the rad. I know WS fluid gets a bad rep in here but I don’t plan on switching yet.
  4. Apr 24, 2018 at 11:58 AM
    #504
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Not a problem, seems like your looking into the electric fan for the same reasons I am. :plane:
  5. Apr 24, 2018 at 11:59 AM
    #505
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is a VERY GOOD fluid. I know a guy.....
  6. Apr 24, 2018 at 12:06 PM
    #506
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Pulling the Rockies on the trip to Moab?
    ToyRyd04[QUOTED] likes this.
  7. Apr 24, 2018 at 12:11 PM
    #507
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Pulling the Rockies on the trip to Rubicon! Marlin Crawler Roundup in Sept.
  8. Apr 24, 2018 at 12:14 PM
    #508
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Nice!
  9. Apr 24, 2018 at 12:24 PM
    #509
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I figured as much, but you know how misinformation spreads lol. Judging by my 10,000 change blackstone analysis, the oil held up pretty damn good. Also my work truck has same trans, fluid has never been changed in 351,000 miles :eek:
    Torspd[QUOTED] likes this.
  10. Apr 24, 2018 at 12:38 PM
    #510
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Although...
    Rock Therapy is in October. No reason I can see that you can’t make both :D
  11. Apr 24, 2018 at 1:26 PM
    #511
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Not sure if Fecetious or for realz
    Poll:
    WS > Maxlife
    Maxlife > WS
    WS = Maxlife
    Something else? > All
  12. Apr 24, 2018 at 1:38 PM
    #512
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    When I did the IPT valve body, I asked the owner (forget his name now) what ATF to upgrade to.
    He told me that he’s the first to upgrade anything, but OEM is the best for our transmissions. So, that’s what I put back in.
    He also told me to put an extra quart in when I filled it back up. Especially since we do a lot of off camber stuff. Says there’s a lot of room in there before you have to worry about foaming.
    Biscuits, Torspd and loginfailed like this.
  13. Apr 24, 2018 at 1:43 PM
    #513
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I did and I spoke to the same guy that @Roostfactor did they said they should be making a Tacoma specific radiator by the end of the year. I suggest that if anyone else wants one specifically for the Tacoma to call them and inquire
  14. Apr 24, 2018 at 1:46 PM
    #514
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I’m assuming that you cannot buy directly from CSF though?
  15. Apr 24, 2018 at 1:56 PM
    #515
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’d rather have the FJ / T4R radiator than a Tacoma specific one. Bigger.
  16. Apr 24, 2018 at 2:08 PM
    #516
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    Not sure. Even if you can't it's still good to call them and let them know so they can keep track of the demand!
  17. Apr 24, 2018 at 2:11 PM
    #517
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
    It's more than twice the thickness so even at the same height and length it's still double the size. I'd rather have one the correct size so I don't have to bend the lines and also not have to worry about the RAD hitting the RAD support while it's flexing.
  18. Apr 24, 2018 at 2:25 PM
    #518
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Truthful.
    Biscuits and loginfailed[QUOTED] like this.
  19. Apr 24, 2018 at 2:30 PM
    #519
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Oh, I ordered the FJ rad today. With the FJ shroud and coolant reservoir, it already is bolt in and larger.
    That’s how I see it anyway.
    Biscuits and blu92in99 like this.
  20. Apr 24, 2018 at 2:31 PM
    #520
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Is that a problem? Hitting the support while flexing? Didn’t consider this.
