CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Apr 24, 2018 at 2:38 PM
    #521
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Gotcha.
    Just know that bending the cooler line bracket isn’t much of an issue. Don’t even need tools. You can do it with your bare hands. My 13 year old daughter could do it.
    Looking at the FJ radiator in my Tacoma, I don’t see anywhere that the radiator is going to hit the radiator support. :notsure:
  2. Apr 24, 2018 at 2:39 PM
    #522
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @Roostfactor
  3. Apr 24, 2018 at 2:41 PM
    #523
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    My front crossmember has been rebuilt. The bracket for the lines isn’t even there anymore. Should truly be bolt in for me.
    I can understand the appeal of a rad that is 100% specific for the Taco though. I mean, most aren’t running a bunch of boost like we are.
  4. Apr 24, 2018 at 3:36 PM
    #524
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I get that bending the lines is easy to do but it also makes for another point of failure if the lines get kinked/stressed.
    Tim I have seen your RAD support and I don't think you for one have anything to worry about however most people have not reinforced their trucks there like you have my friend, Lol.
    The RAD support does flex A LOT (just look at those bushings) and that may be the reason the Taco RAD is shorter. I don't know. I just don't want to be the one that finds out!
    Guys, keep in mind I'm not saying any of this stuff to stir any pot or anything. I personally would just prefer to have the RAD made specific to fit our trucks so that way I know there won't be any surprises down the road and if you would like one made specific too then please contact them and let them know. When I called they told me straight out they made the FJ because people were calling and asking for them and if we want the same things for our truck, to have people call them.
  5. Apr 24, 2018 at 3:37 PM
    #525
    ThomasMore66
    Dallas/Fort Worth & Durango
    Too late to go back now. Too many mods.
  6. Apr 24, 2018 at 6:49 PM
    #526
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I think if the radiator support flexes that much you would have cracks in the body like 12TRDTacoma. A lot of people have now gone to urethane body mount bushings to get rid the flex. Myself, I am not concerned since I am not an extreme off roader with the truck.
    I can understand your concern but it really is not a big deal to bend the lines. You sound pretty knowledgeable so I'm sure if you needed more clearance between the radiator and lines you could relocate or re-route them.
    Glueman and loginfailed[QUOTED] like this.
  7. Apr 24, 2018 at 6:52 PM
    #527
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I haven't wheeled my truck at all except that one time at the Whataburger drive-thru. But I did buy the urethane mounts because the speed bumps at the mall and stuff. Haven't put them on yet, though.
    Biscuits, Bebop, Glueman and 5 others like this.
  8. Apr 24, 2018 at 8:05 PM
    #528
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Lol....awesome
  9. Apr 25, 2018 at 11:11 AM
    #529
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    When’s the next whataburger wheeling meet up?
    loginfailed[QUOTED] and jojotoo like this.
  10. Apr 25, 2018 at 11:59 AM
    #530
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ditto!
    There is a Coffee and Cars on May 5. Memorial City Mall. 8-10 A.M.
  11. Apr 25, 2018 at 12:00 PM
    #531
    Bebop
    Nick
    Nah, too many mustangs on the loose
    loginfailed and StuckinOhio like this.
  12. Apr 25, 2018 at 12:51 PM
    #532
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    May 5th at @Roostfactor house.
    Won’t be in town for coffee and cars. I think that weekend is toyota jamboree too. I guess I need to plan better :D
    Roostfactor[OP] and jojotoo like this.
  13. Apr 25, 2018 at 12:59 PM
    #533
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Got my fj shroud and resi today!!!
  14. Apr 25, 2018 at 1:28 PM
    #534
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Damn it.... I miss me some Whataburger. It's always on the list of stops when I'm back in Texas.
  15. Apr 25, 2018 at 4:26 PM
    #535
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Get her dun!
  16. Apr 25, 2018 at 4:28 PM
    #536
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah...it’ll be a minute but I will
    loginfailed[QUOTED] likes this.
  17. Apr 25, 2018 at 5:48 PM
    #537
    ThomasMore66
    There's no Whataburger in Utah?! WTF?!
  18. Apr 25, 2018 at 6:35 PM
    #538
    Roostfactor
    TX panhandle
    1, 2 , 3, 4,............60. Done yet?
    oni06 and loginfailed[QUOTED] like this.
  19. Apr 25, 2018 at 6:38 PM
    #539
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Na, not yet
    loginfailed and Roostfactor[OP] like this.
  20. Apr 25, 2018 at 6:39 PM
    #540
    Roostfactor
    TX panhandle
    Man, I'd take the road trip down to meet all you southern folk but I'll be busy all weekend working on someone's truck!
    Awww who am I kidding, I love welding so much I should be paying @loginfailed for the priviledge to work on such a fine piece of machinery!:rofl:
