CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Mar 16, 2018 at 6:02 PM
    #41
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    :goingcrazy: if only I didn't just replace with oem :frusty:. Oh well on the next one I'll be doing this for sure. Nice find o.p:fistbump:
    loginfailed and Roostfactor[OP] like this.
  2. Mar 16, 2018 at 6:22 PM
    #42
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Due to the inherent design of all vehicle cooling systems, increasing cooling efficiency will do nothing for lowering the coolant temps until the system exceeds its capabilities. A thermostat is not like an open and shut valve so it's not like it's either fully open or fully closed. It progressively opens with an increase in temp. Once it is fully open you are relying on the rest of the cooling system (radiator) to regulate coolant temperature. By having a much more efficient radiator, and one that is all aluminum with out plastic end caps or orings to fail the cooling system has much greater capacity to keep the temperature where Toyota (and the thermostat) intended.
    If I lived in a cold climate I would only get this as a replacement WHEN the stock one fails. It will fail in time.
    For those that live in the warm climates and off road especially in deep sand where speeds are slow, torque converter is never locked, and really high constant load on the engine, this will be the cats meow!
    mr.trd and loginfailed like this.
  3. Mar 16, 2018 at 6:33 PM
    #43
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'll let you know. I ordered an FJ/T4R shroud and recovery tank. Mostly to try and do an e-fan conversion, but before I do any hacking, I want to see how far off the shroud ends up from the clutch fan.
  4. Mar 16, 2018 at 6:35 PM
    #44
    Roostfactor
    TX panhandle
    Quite possibly! I would think all you have to do is bend/move the tranny cooler lines a bit more to compensate for the bottom of the FJ shroud (there is plenty of room). I'm not sure though as I haven't tried it. I think the coolant reservoir is in a different spot on the FJ as well.
    Try it out and post your results! That's what this forum is for, to find new things and improve on others findings!
    Great idea!
    loginfailed, IronPeak and GT7 like this.
  5. Mar 16, 2018 at 6:38 PM
    #45
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    AR15xAR10 likes this.
  6. Mar 16, 2018 at 6:40 PM
    #46
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Good stuff
  7. Mar 16, 2018 at 6:41 PM
    #47
    Roostfactor
    TX panhandle
    Well of course you did you "One upper"! :thumbsup:
    Just kidding man, let us know what you find.
  8. Mar 16, 2018 at 6:42 PM
    #48
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Haha, it probably won't work, LOL
  9. Mar 16, 2018 at 6:44 PM
    #49
    Roostfactor
    TX panhandle
    I have faith in your abilities....I have seen your work! :transformer:
    loginfailed[QUOTED] likes this.
  10. Mar 16, 2018 at 6:44 PM
    #50
    Lord Helmet
    Nick
    '24 X3 M40i
  11. Mar 16, 2018 at 7:03 PM
    #51
    Roostfactor
    TX panhandle
    Anyone that actually orders one please post it so I can track it. I am not making any money on this but I am hoping with enough sales that @Gadget URD will hook me up with a one time discount for sending business his way.
    jojotoo, loginfailed and Lord Helmet like this.
  12. Mar 16, 2018 at 7:10 PM
    #52
    Lord Helmet
    Nick
    '24 X3 M40i
    It's on my hit list :thumbsup:
  13. Mar 16, 2018 at 7:16 PM
    #53
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Stop fucking spending my money for me Randy
    loginfailed, Slashaar, Toy4me and 3 others like this.
  14. Mar 16, 2018 at 7:17 PM
    #54
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    <3
  15. Mar 16, 2018 at 8:00 PM
    #55
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I’ll be all over one of these when my OE radiator fails. Hopefully CSF will have developed a Tacoma specific radiator by then.
    I have one of these in my other vehicle. It definitely helped out during extreme use at the track. Build quality is pretty decent. Not Ron Davis level, but, plenty adequate; And likely a third of the cost.
    33B3444A-BD6F-48B2-AE4D-5499AE0EE105.jpg 25671C25-0DF6-468A-A14D-76DE5007C85D.jpg
    llibrm, Roostfactor[OP], GT7 and 2 others like this.
  16. Mar 16, 2018 at 8:39 PM
    #56
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Nice job on the research man!!
  17. Mar 16, 2018 at 8:47 PM
    #57
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Being in Arizona....noted for future reference.
  18. Mar 16, 2018 at 9:14 PM
    #58
    Roostfactor
    TX panhandle
    Thanks buddy!
  19. Mar 16, 2018 at 9:14 PM
    #59
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
  20. Mar 16, 2018 at 9:16 PM
    #60
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    I love a good radiator. When the time time comes....thanks @Roostfactor for the info provided.
