CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Apr 28, 2018 at 8:49 PM
    #601
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You're not the only person to have told me that this week.
  2. Apr 28, 2018 at 8:50 PM
    #602
    Biscuits
    Must resist making Subway/Jered jokes...
  3. Apr 28, 2018 at 8:58 PM
    #603
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Just have another one of your fancy bottomless glasses of primo distilleryness and the shell will break!
    Biscuits[QUOTED] likes this.
  4. Apr 28, 2018 at 9:12 PM
    #604
    Biscuits
  5. Apr 28, 2018 at 9:17 PM
    #605
    ThomasMore66
    Dallas/Fort Worth & Durango
  6. Apr 28, 2018 at 9:24 PM
    #606
    Biscuits
  7. Apr 28, 2018 at 9:36 PM
    #607
    Roostfactor
    TX panhandle
  8. Apr 28, 2018 at 9:56 PM
    #608
    Biscuits
    Different strokes for different folks, my friend. Nothing to do with taste. Ain't nothing wrong with that.
  9. Apr 28, 2018 at 9:56 PM
    #609
    ThomasMore66
    Kinda got a dark theme going there Edge Lord.
    Roostfactor[OP] likes this.
  10. Apr 28, 2018 at 11:19 PM
    #610
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Like.
  11. May 4, 2018 at 8:41 PM
    #611
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Installing my stuff right now. Almost have everything back in. Only problem I ran into is the passengerside shroud mount didn’t line up right with the rad. I just cranked it in there, but it was definitely not going in straight. I was beyond the point of return. Also just broke the lower radiator hose clamp trying to slide it over the lip on the bottom of the rad. :pout:
  12. May 4, 2018 at 8:45 PM
    #612
    Roostfactor
    TX panhandle
    Tacoma shroud or FJ?
    If it was the Tacoma shroud I have pics on the first post of how I re-drilled the upper shroud holes.
    Was is the stock clamp? They are spring loaded, dont know how it would break?
  13. May 4, 2018 at 9:24 PM
    #613
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Fj shroud, sorry forgot to mention.
    So you know how there is two prongs on the clamp. It was stuck on the lip of the rad and when i tried to squeeze them one end went snap. I just out a hose clamp on the side closer to the rad of it since I couldn’t get it off.
    loginfailed likes this.
  14. May 4, 2018 at 10:01 PM
    #614
    Roostfactor
    TX panhandle
    Understood. All good now Murph?
    Murphinator[QUOTED] likes this.
  15. May 4, 2018 at 10:21 PM
    #615
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Just took it for a test drive. I can tell I am really going to like this radiator :D
    Bled the cooling system for 30 mins. I will add some trans fluid tomorrow maybe. It drives fine and I didn’t lose too much. I figure it wouldn’t hurt to top it off still.
    I added the weather stripping to all 4 sides. The top piece I could double up on or place lower, but everywhere else fits snug.
    As far as the trans hard line brackets, I could not bend the brackets by hand. I just grabbed the hard line and pulled them down a smidge. Easy enough.
    Thanks again to John and Dwayne for doing the leg work on making this install as easy as possible!
  16. May 4, 2018 at 10:24 PM
    #616
    Roostfactor
    TX panhandle
    Yeah buddy! Enjoy!
  17. May 4, 2018 at 10:25 PM
    #617
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The lower clamp on mine was a little fussy also.
  18. May 4, 2018 at 10:30 PM
    #618
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yeah, I think my set of pliers may have been a little overkill. Especially since I managed to break it :p
    As far as the shroud bolt goes, I think all the long distance shipping it went through got the best of that one mount. No biggie tho I made it work. 10/10 would do again.
  19. May 4, 2018 at 10:34 PM
    #619
    Roostfactor
    TX panhandle
    Like its owner? :boink:
    loginfailed[QUOTED] likes this.
  20. May 4, 2018 at 10:37 PM
    #620
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It’s getting worse with age. The new neighbors that moved in behind me probably think I’m an asshole. But their dog doesn’t bark as much since the incident. :D
