CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. May 4, 2018 at 10:43 PM
    #621
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Yes it does! Why do you think @ThomasMore66 is such a smart ass?!
    Such an open ended comment....so many ways to interpret the "incident" as intended I'm sure.
    loginfailed[QUOTED] likes this.
  2. May 4, 2018 at 10:45 PM
    #622
    Roostfactor
    TX panhandle
    @loginfailed, go to sleep, we have WORK in the morning!:welder:
    loginfailed and oni06 like this.
  3. May 4, 2018 at 10:47 PM
    #623
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    At 1am, I can make a lot more noise than your dog can.
  4. May 4, 2018 at 10:49 PM
    #624
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I was sleeping good till somebody texted me. :D
  5. May 5, 2018 at 6:41 AM
    #625
    ThomasMore66
    Dallas/Fort Worth & Durango
    People up late here last night.
  6. May 5, 2018 at 8:41 AM
    #626
    Roostfactor
    TX panhandle
    True, and up early. You coming out Tomas or chillin.
  7. May 5, 2018 at 11:36 AM
    #627
    ThomasMore66
    Quasi chillin. Got my Throttle body installed. Time for more PT.
  8. May 5, 2018 at 3:07 PM
    #628
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    So I took the truck for a stress test today. The Starbucks line gets pretty crazy as yall know, and before my princess would start to heat up with the ac on in 90+ F weather. Well. Today it was around 97 F and the engine never got above 194, trans moved up to around 185. When driving the trans heats up on inital acceleration, the max I saw was 199, then it would cool back down to the low 180s mid 170s. Also a few miles before getting home I turn my A/C off to prevent moisture in the evaporator core. Engine temp went from 194 back to 185. This is with the stock 180 degree thermostat.
    I am so stoked with this radiator. I 100% recommend getting the weather stripping too. I used the fj shroud with the thicker weather stripping that is linked in this thread (comes with two sizes). It works perfect on the bottom and sides. On the top the lip of the shroud sits a little higher than the rad, so it doesnt seal really. I may add another layer to remedy this.
    I will say I was surprised at the condition of my oem rad. The inner part closer to the fan had a lot of bent fins, and the top seems to be bent in two spots. Seemed pretty strange to me. Glad that hunk of crap is out of there. All I need to do is clean my engine bay as there is coolant everywhere. Things got a little crazy last night you could say.
  9. May 5, 2018 at 3:14 PM
    #629
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Damn good review, to hear. :thumbsup:
  10. May 5, 2018 at 5:05 PM
    #630
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    97* out today and my truck got to 206 just driving through some mountain roads.
    This is in my future for sure.
  11. May 5, 2018 at 6:30 PM
    #631
    ThomasMore66
    97?! Wtf, it’s May.
    Roostfactor[OP] likes this.
  12. May 5, 2018 at 6:38 PM
    #632
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Its been 100 here a couple times so far
  13. May 5, 2018 at 7:20 PM
    #633
    ThomasMore66
    Supposed to be 90 next week. I hate summer. We actually had a Spring this year in Dallas. I don’t want it to end.
  14. May 5, 2018 at 8:02 PM
    #634
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    California lol. It was 62 on Wednesday, 97 on Saturday. All over the damn place out here.
    Roostfactor[OP] and jojotoo like this.
  15. May 6, 2018 at 6:15 AM
    #635
    Roostfactor
    TX panhandle
    Yes, very nice review @Murphinator. Thanks for sharing. It's always nice to see actual data vs someone saying its "better" with nothing to back up the claim.
  16. May 20, 2018 at 5:41 PM
    #636
    Yo'ta
    Yo'ta Well-Known Member
    Does anyone know if these radiators are still in stock?
    I checked URD and there is no way to add to the shopping cart
    JL
  17. May 20, 2018 at 5:54 PM
    #637
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Nope. Gadget said he would put up a link when he has them.
    If you want to pre-order it, Order it from Pure FJ.
    Gadget wouldn’t let me pre-order it, so I went elsewhere. He actually acted like I was bothering him by calling to ask about it.
  18. May 20, 2018 at 6:02 PM
    #638
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  19. May 20, 2018 at 6:03 PM
    #639
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Never had a problem with my calls when I was ordering the other 9k worth of parts.
    Lord Helmet likes this.
  20. May 20, 2018 at 6:06 PM
    #640
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah right!!!! But heaven forbid you need a question answered lol
