CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. May 26, 2018 at 12:38 PM
    #681
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Good stuff!
  2. May 26, 2018 at 2:56 PM
    #682
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  3. May 27, 2018 at 5:35 PM
    #683
    ThomasMore66
    Dallas/Fort Worth & Durango
    Now it’s so effing hot I don’t want to go out. I hate summer in Texas.
  4. May 27, 2018 at 5:54 PM
    #684
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    ......but your radiator will keep you cool man
    Roostfactor[OP] likes this.
  5. May 29, 2018 at 10:31 AM
    #685
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, Icon stage 3 rear leaf pack, Archive Garage Hammer Hangers w/ homemade spreader bar, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, 285/75R17 BFG A/T KO2's on Bronze Icon Alloy Compression's, 5th gen T4R budget big brake kit, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI full flat belly skids including gas tank,CBI Ditch Light brackets w/ Heretic Studio Quattro's, Heretic Studio's 30" Amber on the front, Heretic Studio 40" bar under the Front Runner Roof Rack, Expedition Essentials RAM mount, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, URD Ucon-EMS, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust w/ factory Tundra muffler behind URD equal length headers.
    I installed a factory 2003 cummins trans cooler in series with the factory cooler. Only problem I have is that it sites behind the top of my skid plate and FYRLYT on the passenger side. It is large but I still wish I had more airflow. On a good note, driving to my parents in MT this last weekend, my trans ran a steady 150 with the new gears, new tires, and two wind catches (mtn bikes) on the roof while doing 80mph which is 2800 rpm.
  6. May 29, 2018 at 3:58 PM
    #686
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Subbed for the future 2nd Gen Tacoma rad.
  7. May 29, 2018 at 7:16 PM
    #687
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Went wheeling today and I guess I’m STILL having overheating issues.....
    My buddy and I ran a trail and I got up to 217 while he was under 200, same truck and same set up
    I have replaced the fan clutch, t stat, coolant, water pump.
    Is this radiator the answer? Doesn’t make sense...
  8. May 29, 2018 at 7:30 PM
    #688
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    With the 160 t-stat
  9. May 29, 2018 at 7:31 PM
    #689
    anthony250f
    Anthony
    San Diego, CA
    It’s odd that my buddy was wheeling the same trail and never got over 200. It was 98 degrees out too. I’ll look into the 160 t stat
    Has the Tacoma version came out yet ?
  10. May 29, 2018 at 8:03 PM
    #690
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    No not until later this year I believe.
  11. May 29, 2018 at 8:17 PM
    #691
    Roostfactor
    TX panhandle
    The fj/4runner radiator is larger. 70% more capacity than stock. Its NOT hard to install.
    It is larger and should be more efficient than the stock one so it may help with temps.
    Were yours and your buddies a/c on the same setting? That can make a big difference in engine temps, especially at slow speeds.
    Did you get a new oem "pink" fan clutch?
    Do you have your old one still?
    If so you can put higher viscosity silicone fluid in it to make the fan work harder.
    12TRDTacoma and loginfailed like this.
  12. May 29, 2018 at 8:17 PM
    #692
    anthony250f
    Anthony
    San Diego, CA
    I still feel like my truck shouldn’t be running this hot though. Others run the same set up and don’t overheat lol
  13. May 29, 2018 at 8:20 PM
    #693
    anthony250f
    Anthony
    San Diego, CA
    His ac was off and mine was on full blast. We weren’t going too slow probably around 15-20 mph in 2hi the entire time. My trans temp never went over 200
    I did put in a brand new pink Aisin clutch. I had a Hayden but never installed it. The temps were hanging around 206...then climbed up to 213....then went all the way up to 217 which is pretty much exactly what it’s done in the past. Then it likely would have skyrocketed to 230+ (needle in red)
    I tested it later with ac off and there was only a 2 degree difference (going down hill more though instead of up)
    The previous owner also had overheating issues with this truck as well. It was at the dealer more than once for running too hot in hot outside weather....Which is why I replaced every part except the radiator as it looked fine
  14. May 29, 2018 at 8:45 PM
    #694
    Roostfactor
    TX panhandle
    The a/c condenser creates a lot of heat that gets sucked right through the radiator which heats it up of course.
    Since the truck has a history though it could be many things.
    Restriction in radiator
    Restriction in radiator in or out lines
    Restriction in return line (the one that goes all the way through the v"
    Fan clutch not engaging enough
    When I was stock, I saw 205°F in a 45 minute stopped traffic situation. A/c was on and it was 95° outside. The clutch fan just doesnt move enough air at low rpm. I have since replaced my clutch fan fluid to 10k cst and it works much better. You can find it at Tower Hobbies. Make sure you put in the same amount you take out.
    anthony250f[QUOTED] likes this.
  15. May 29, 2018 at 8:54 PM
    #695
    ThomasMore66
    Back on post 680, I had the aircon on high. Driven it some more in the heat and it stays cool. I never turn the air off. Hit the 635 Express tollway this afternoon, 80-100 mph in mid 90’s heat. No issues. It’s a 190 degF truck in the heat.
    anthony250f likes this.
  16. May 29, 2018 at 9:04 PM
    #696
    anthony250f
    Anthony
    San Diego, CA
    It only overheats if you are actually driving it. It sat idle for about 30 mins with ac on (dogs in car) and never got over 200, and this was in the same 98 degree outside temp. I would be shocked if two fan clutches were not running correctly. Is it difficult to do the fluid swap in the fan clutch ?
  17. May 29, 2018 at 9:05 PM
    #697
    anthony250f
    Anthony
    San Diego, CA
    My ac actually really blows and it isn’t even very cold anyways
  18. May 29, 2018 at 10:06 PM
    #698
    Roostfactor
    TX panhandle
    No it's not bad. Do a google search. @loginfailed experimented with the fluid in his and turned me on to the idea.
    There is less heat generated when parked due to no transmission load and torque converter slip.
    It's not necessarily that the fan clutches are defective. It means they are not effective enough for the conditions. Thicker fluid will drive the fan harder but will decrease gas mileage.
    The next time your truck is hot put it in park and rev the truck a little with your head out the door. You should be able to hear the fan.
    Does it blow cold on the highway?
    If it blows cold on the highway but much warmer when going slow or parked could mean low fan clutch lockup.
  19. May 29, 2018 at 10:16 PM
    #699
    anthony250f
    Anthony
    San Diego, CA
    It’s the same on the highway.i checked my fan resistance against my buddies and it was the same. The AC compressor is going out. The bearing makes noise when the clutch engages. I already hve a new compressor on hand. When the truck was at the dealer they replaced the thermostat once, and the other time it looks like they did nothing.
  20. May 29, 2018 at 10:22 PM
    #700
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My money is on the radiator being clogged up @anthony250f like I mentioned to you a while ago on IG. Just replace it with this CSF rad and I'll bet you that your overheating issues will no longer be a relevance in this conversation.
    I had a 3000GT that would overheat only with the AC on. I replaced the radiator with a dual core design, all of the overheating issues ceased to exist. Likely a slight clog in the rad which only improved in the lack of overheating once the single core was switched out with a dual core design.
