CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Jun 2, 2018 at 9:15 AM
    #721
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Anyways. It’s june so these should be back on stock soon!!
    Roostfactor[OP] and Murphinator like this.
  2. Jun 2, 2018 at 9:35 AM
    #722
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have dual spal fans. They flow a lot of air. As well as a HUGE radiator. Sitting in hot traffic for extended periods of time, my temps still creep.
    My engine has ductile iron sleeves, a turbo, and exhaust tubing which needs more wrap. All of those components really tax the coolant system. With the old grill that I used to have, it restricted more flow than it allowed. With the factory radiator, I HAD to remove the grill to even get enough flow while moving. My Spal fans weren't applicable with the factor radiator setup. Even in N/A trim, with a 160º t-stat, my engine's temps would be around ~212ºF+.
    Swap in the larger radiator, I have only seen 202, in bumper to bumper traffic, ~100º ambient, with all of the turbo goodies on. Including a 3.5" thick intercooler infront of the radiator.
  3. Jun 2, 2018 at 9:56 AM
    #723
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am looking forward to what parts you use/how it all works.
    loginfailed[QUOTED] likes this.
  4. Jun 2, 2018 at 10:04 AM
    #724
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Yes. This was @loginfailed idea so I tried it. Fully drained the fan clutch and added one bottle 59cc of 10k fluid. Fan ran too hard all the time even when when not hot so I adjusted the temp on the fan clutch from 120 to 135 and removed about 10cc's of fluid. It's just about right now.
  5. Jun 2, 2018 at 10:16 AM
    #725
    ThomasMore66
    Dallas/Fort Worth & Durango
    I sit in traffic some everyday (60 mile round trip commute) in DFW. Even in mid/upper 90's on concrete highway with lots of reflective heat I haven't been over 190. I have the 170 thermostat because I do go to winter. Might be better with 160.
    Roostfactor[OP] likes this.
  6. Jun 2, 2018 at 10:36 AM
    #726
    Roostfactor
    TX panhandle
    It's a fluid coupling so it will never fully lock up.
  7. Jun 2, 2018 at 10:39 AM
    #727
    anthony250f
    Anthony
    San Diego, CA
    I think I may try the 10k fluid while I wait for these radiators to comeback in stock. I would that should help
  8. Jun 2, 2018 at 10:43 AM
    #728
    anthony250f
    Anthony
    San Diego, CA
    Does the stock fan clutch come on at 120? I thought it was more like 180-190
  9. Jun 2, 2018 at 10:45 AM
    #729
    Roostfactor
    TX panhandle
    Should be about 125°. Do a google search for fan clutch mod. People have been doing it a long time.
    loginfailed likes this.
  10. Jun 2, 2018 at 11:10 AM
    #730
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Your Ron Davis radiator is what started me toward e-fans.
    Still haven’t settled on exactly which fan controller to use yet. Also I want to get the shroud mostly done before deciding on which fans to use. I want to go as big as I can fit. Of course the shroud build is hinging on me getting a TIG. The TIG I want is out of stock until the end of this month
    The one I opened up and tested was set at about 125*.
  11. Jun 2, 2018 at 6:10 PM
    #731
    bendilzerian
    bendilzerian Well-Known Member
    Houston
    2015 DCSB White TRD Sport PreXrunner
    Subb'd. Being in Houston, daily driving my truck (and driving like an animal), sitting in a lot of traffic, and wanting to go with a boosted option soon, I need to start looking into some cooling mods.
    loginfailed and Roostfactor[OP] like this.
  12. Jun 2, 2018 at 7:08 PM
    #732
    ThomasMore66
    Still think the fan option is overkill. Maybe if I 4wheeled in the heat, but heat sucks. #summersucks.
    mr.trd likes this.
  13. Jun 2, 2018 at 7:24 PM
    #733
    anthony250f
    Anthony
    San Diego, CA
    Totally. It’s always hot here lol
    Falldownhard likes this.
  14. Jun 2, 2018 at 7:26 PM
    #734
    Roostfactor
    TX panhandle
    In San Diego?
  15. Jun 2, 2018 at 7:27 PM
    #735
    anthony250f
    Anthony
    San Diego, CA
    I’m inland San Marcos. It’s not “that” hot lol but to me it is.
  16. Jun 2, 2018 at 9:12 PM
    #736
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Fuck you guys!!!.......try dead of winter Chicago and like a windchill of -40 below
  17. Jun 2, 2018 at 9:22 PM
    #737
    oni06
    oni06 Well-Known Member
    I have been to Chicago in the dead of winter.
    Fuck that.
  18. Jun 2, 2018 at 9:30 PM
    #738
    Roostfactor
    TX panhandle
    I've been deployed to places you guys would never want to see. To top it off temps of 125+.
    But, I hate being cold and wind is the worst so I think I'd take my situation over yours.
    12TRDTacoma likes this.
  19. Jun 2, 2018 at 9:37 PM
    #739
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I don’t mind heat....just hate humidity. Cold sucks but to me it’s somewhat tolerable when it’s not windy. The blustery wind we get here in combination with the cold can be brutal. I’m planning to relocate somewhere warmer with no humidity in a few years....I’m sick and tired of the cold.
  20. Jun 2, 2018 at 9:40 PM
    #740
    oni06
    Warm + Not dry as fuck = SoCal = $$$$$
    Warm + Dry as fuck = AZ = $ to $$$
