CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Jul 12, 2018 at 5:46 AM
    #821
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Considering that yours is a '17, we don't even know if it is a matching part for upgrade.
    Until someone does that leg work....
    ...the envy of more of this^^^
  2. Jul 18, 2018 at 8:25 PM
    #822
    ThomasMore66
    Dallas/Fort Worth & Durango
    Yesterday the truck thermometer indicated 106-108 on I-635 in Dallas. Real ambient was a couple of degrees less, but I bet it was that hot on the concrete. 80-85 mph, in and out of boost, coolant was 194 like a rock. Tomorrow is supposed to be hotter. I’ll see how it goes.
  3. Jul 18, 2018 at 8:37 PM
    #823
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It was 112 through Lake Havasu a couple weeks ago. I was going uphill in a headwind for at least 5 minutes and boost was a constant 3 to 5psi. My intercooler pre/post temps were 200 pre and 140 post. That's 140° going into the engine.
    My coolant temp never went above 190 with my 160° thermostat.
    5thGearPinned likes this.
  4. Jul 18, 2018 at 8:41 PM
    #824
    ThomasMore66
    Yeah, I got the 170. Kinda wish I’d gone 160, but winter is coming...maybe.
  5. Jul 18, 2018 at 9:11 PM
    #825
    Roostfactor
    TX panhandle
    What sucks is you have to buy separate since URD only provides a 170.
    The 160 still worked like a champ at 8°F.
    5thGearPinned and Torspd like this.
  6. Jul 20, 2018 at 2:14 PM
    #826
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Just an FYI for y'all...
    I spoke to Demi at CSF today.
    She told me that the #7076 radiators should be available August ninth or 10th. She also advised that they will likely sell out very quickly and to get one on order with a CSF distributor as soon as possible. She wouldn't provide any pricing info. No info on the Tacoma specific radiator either.
    Roostfactor[OP] likes this.
  7. Jul 23, 2018 at 10:36 PM
    #827
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    140 into the engine is crazy. You got the ucon. What about the 7th injector? Curious how much gasoline would cool if any.. Better yet water/meth.
  8. Jul 23, 2018 at 10:47 PM
    #828
    Roostfactor
    TX panhandle
    I know man! I was very keen on listening for any knock or abnormal sounds. No issues.
    I dont have 7th or meth. I am very curious how much difference each would have but then I also wonder how much thermal shock there is when people sc's are heat soaked like sitting at idle the accelerate causing the meth to flow. That is a very quick temp change going on internally.
  9. Jul 23, 2018 at 11:12 PM
    #829
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This mod is on my TODO list. I'm going to be wheeling up a mountain at slow speeds in steep climbs in 100+ degree dusty heat this weekend on a 2 day trip. I'll monitor temps with an Ultra Gauge, but I already know they are not going to be happy.
  10. Jul 23, 2018 at 11:23 PM
    #830
    Roostfactor
    TX panhandle
    It will help but keep in mind that at really slow speeds the fan is the primary factor and s you speed up the radiator is.
    crashnburn80[QUOTED] likes this.
  11. Jul 24, 2018 at 12:00 AM
    #831
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yeah, I've built earlier Toyota trucks with similar custom radiators and switched out to electric fans for that reason, off road in high heat. Performed great in those specific scenarios but not a big fan of the aftermarket electric fans in general.
  12. Jul 24, 2018 at 5:58 AM
    #832
    Roostfactor
    TX panhandle
    I hear ya. I will be trying my luck with one in the future though. I'm going to use a mid 90's t-bird fan. It's an 18' fan like the stock clutch fan. You can always modify the clutch fan too to pull more air an idle and lower rpm.
  13. Jul 24, 2018 at 6:45 AM
    #833
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    18ft is a big ass fan :p
  14. Jul 24, 2018 at 6:48 AM
    #834
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Jul 24, 2018 at 8:48 AM
    #835
    Roostfactor
    TX panhandle
    5thGearPinned and 05Taco4x4 like this.
  16. Jul 24, 2018 at 8:53 AM
    #836
    Sandman614
    Tim
    '06 SR5 Off Road
    :eek: How much HP does that bad boy add?
  17. Jul 24, 2018 at 8:57 AM
    #837
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    -200
    05Taco4x4 likes this.
  18. Jul 24, 2018 at 9:00 AM
    #838
    Sandman614
    Tim
    '06 SR5 Off Road
    No stickers!
  19. Jul 24, 2018 at 9:27 AM
    #839
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :rofl:
  20. Jul 24, 2018 at 10:30 AM
    #840
    Roostfactor
    TX panhandle
    We actually measure propeller torque output. This is a C-130 propeller and max torque we are allowed is 19,600 in lbs of torque.
    llibrm likes this.
