CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Jul 24, 2018 at 3:24 PM
    #841
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I remember reading somewhere a while ago that the stock plastic fan actually does a very good job of moving air compared to some aftermarket fans. Is there a CFM figure for the stock fan?
  2. Jul 24, 2018 at 4:03 PM
    #842
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Not that I know of. The problem with a clutch fan is even fully locked up it is limited by engine idle rpm. It can move crazy amounts of air when you increase engine rpm depending on if and how you mod it.
  3. Jul 24, 2018 at 5:27 PM
    #843
    ThomasMore66
    Dallas/Fort Worth & Durango
    Drive faster.
  4. Jul 24, 2018 at 6:00 PM
    #844
    weldo
    Pittsburgh, pa
    I wonder if you can change pulley sizes for more fan speed at idle. Then you'd have to worry about it over spinning at higher engine speed... Maybe a magnetic clutch like the A/C pump? Doesn't it disengage at like 3000 rpm to keep the compressor safe?
  5. Jul 24, 2018 at 8:19 PM
    #845
    Roostfactor
    TX panhandle
    That I dont know.
  6. Jul 24, 2018 at 8:20 PM
    #846
    Roostfactor
    TX panhandle
    Then get out of my way old man.
  7. Jul 25, 2018 at 9:53 AM
    #847
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    https://www.tacomaworld.com/threads/our-ac-system-sucks.556361/page-19#post-18198665
    I've actually been quietly working on this idea. Keep an eye on that thread.
  8. Jul 25, 2018 at 10:02 AM
    #848
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yes the clutch fan will work better than electric
    However I am looking into a spal 11” pusher for the front instead ofmy Chinese crap fan lol
  9. Jul 25, 2018 at 10:08 AM
    #849
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You'll like the Spal.
  10. Jul 25, 2018 at 10:17 AM
    #850
    anthony250f
    Anthony
    San Diego, CA
    The one I’m looking at puts out 962 cfm
    The one I have now says 1750 but there is NO WAY lol
    You think the single spal pusher will make a difference or should I go 11” spal and a 9” on the drivers side ?
  11. Jul 25, 2018 at 1:11 PM
    #851
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Repost from another thread.
    “Any of you guys track your trans fluid temp with an Ultragauge/Scangauge?
    I noticed coming back from Tucson my trans temp for a short period of time was hovering around 226F before settling at 212F with an ambient temp of about 115 F.
    Are any of you guys running larger radiators, extra electric radiator fans or larger than the regular OEM tow package trans coolers?”
    Didn’t really get much input in the AZ thread so just throwing this in here.
    What kind of cost for the radiator & install would I be looking at to have a shop do this (ballpark)?
  12. Jul 25, 2018 at 1:18 PM
    #852
    Roostfactor
    TX panhandle
    The radiator is $350 and you can do the install yourself if you are remotely handy. I have a Tru Cool 1142 that I am going to be installing below the condenser and I will be removing the factory external cooler.
    TACOVRD likes this.
  13. Jul 25, 2018 at 1:34 PM
    #853
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I’ve installed all my own UCA / suspension and such.
    Never messed with brake lines or coolant lines yet - should this be doable without too much grief for me?
  14. Jul 25, 2018 at 1:38 PM
    #854
    anthony250f
    Anthony
    San Diego, CA
    I have a aftermarket trans cooler and it has never been over 200. Usually stays around 160-170 degrees
  15. Jul 25, 2018 at 3:37 PM
    #855
    Roostfactor
    TX panhandle
    It's really super easy. Even easier if you get an FJ shroud and reservoir tank.
    Drain coolant
    Unbolt fan but dont remove
    Unhook trans cooler line clamp from shroud
    Reposition lines outside of clamp
    Unbolt shroud
    Push upper part of shroud toward engine with one hand and grab fan with the other
    Pull fan just off threads and lift shroud up. You will have to move it side to side a bit to clear coolant hoses
    Remove fan
    Remove shroud
    Disconnect coolant lines from rad
    Disconnect trans cooler lines from rad (only a little will come out
    Remove two lower rad bolts
    Loosen two upper rad bolts
    Hold rad while removing the remaining two bolts
    Lift out rad
    See page one for shroud modification if re-using shroud
    Install in reverse order
    Fill coolant
    Check trans servicing
    Bam
    HandOfGod and TACOVRD[QUOTED] like this.
  16. Jul 25, 2018 at 8:16 PM
    #856
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I'm also from AZ, with a similar truck as you. Using scangauge. I got rid of the factory trans cooler and installed a B&M 70264. It has made some improvement but not as much as I was thinking it would, only 3-6 degrees cooler than with the factory cooler. Now I usually see 180 on the highway in 110 degree weather. With the factory cooler was seeing 185.
    212 seems a little bit higher than expected. What was your water temp? Were you towing and how fast were you driving?
    Roostfactor[OP] likes this.
  17. Jul 25, 2018 at 8:23 PM
    #857
    anthony250f
    Anthony
    San Diego, CA
    Why didn’t you keep the factory cooler? I have been thinking about ditching th factory cooler for a much larger single cooler
    185 is a great temp for the trans. That is not too hot.
  18. Jul 25, 2018 at 9:28 PM
    #858
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    Engine temp read out between 190-200, trans temp between about 205-212. Not towing anything. Truck has extra weight with front and rear steel plate bumpers, steel skids, sliders, bed rack. Rims are SCS F5 alloys and tires are 265-75R16 in C-load to keep rotational mass down.
    Truck has 66k miles on it, transmission was just drained and filled by Toyota earlier this year. Coolant is full, looks ok, but I've never done a radiator flush I don't think.....cruising speed was between 70-80 mph
  19. Jul 25, 2018 at 9:30 PM
    #859
    TACOVRD
    TW Addict
    AZ/WA
    Workin' on it....
    I wish mine was running at 185 F!!!!
  20. Jul 25, 2018 at 9:42 PM
    #860
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Is that temp consistent across a broad ambient range? Probably past time for a flush. You dont want to wait for obvious symptoms like a boil over to let you know. At that point you're already doing harm. If it doesn't help then it lets you know that temp is normal but if it does then you should consider a more frequent flush schedule. My last truck I bought used at 35k and should have flushed it right away, would have saved me a bunch not much later.
    TACOVRD[QUOTED] likes this.
