CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Sep 9, 2018 at 12:58 PM
    #1001
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  2. Sep 9, 2018 at 12:59 PM
    #1002
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Yessir! I swapped the gasket that comes with it with the one I removed but yes its plug and play.
  3. Sep 9, 2018 at 1:26 PM
    #1003
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Awesome
  4. Sep 9, 2018 at 4:20 PM
    #1004
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mishimoto has 155* one that fits many of the Toyota 4 cylinder engines, but not sure they’re the same size.
  5. Sep 9, 2018 at 4:35 PM
    #1005
    Roostfactor
    TX panhandle
    I dont think I would try that cold. You will get a cel below 168°.
    Keep in mind @HolyHandGrenade, normally fan keep thing cool while stopped and slow speeds. Airflow keeps things cool at high speeds. The thermostat will open at a certain temp and once fully open relies on radiator to provide cool coolant. The larger radiator is larger and more efficient than stock but if you dont have airflow to transfer the radiator heat then you will still have high temps.
    Everything blocking airflow restricts the radiators capacity to cool. Intercooler, condenser, horns, bumpers, winches, etc. The more you have obstructing airflow the hotter your truck will potentially run.
  6. Sep 9, 2018 at 4:43 PM
    #1006
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Resistors ;)
  7. Sep 9, 2018 at 4:44 PM
    #1007
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Everything I've read is that, in general, cooling systems should run in the 180-190 degree mark for optimal performance, wear, and efficiency. Any lower and you get inconsistent cylinder and ring wear (especially on the cylinder, usually number one, that first receives the coolant from the radiator) and your oil doesn't get warm enough to boil off contaminants (water), again increasing wear. No bearing, especially not plain bearings play well with water.
    I would be pretty happy if my truck ran at 185 all day. Problem is, my 2014 DCLB doesn't but a lower temp thermostat is only going to mask, not truly fix, the problem. Only a more efficient/bigger radiator will do that.
    As per the jiggle valve, the 5VZ-FE runs the jiggle at 6 o'clock. At 12 0'clock, I saw 15 degree coolant increases in my 2000 Tacoma. Since the 1GR-FE thermostat comes preinstalled in a housing, I didn't even check it when I installed that and a new water pump in my wife's 06 last week. Hmmmm...
  8. Sep 9, 2018 at 4:46 PM
    #1008
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If a 160 thermo gets you to 185, then a 155 could get you to 180.
  9. Sep 9, 2018 at 4:47 PM
    #1009
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Your overall coolant with be at 180, but cylinder number 1 is gonna get hit with 160 degree coolant and on a long enough timeline that might be a problem
    12TRDTacoma and Roostfactor[OP] like this.
  10. Sep 9, 2018 at 4:58 PM
    #1010
    Roostfactor
    TX panhandle
    I can understand that but wouldnt it basically be the same in the dead of winter going down the freeway radiator outlet temp may be 50° then stock thermostat opens at 180° you will still have a similar temp difference between thermostat and the temp sensor after cylinders 5 and 6 as you would with a colder thermostat.
    Oil will get plenty hot enough at 175° to remove moisture.
    Good intelligent conversation though, I love it!
    samiam likes this.
  11. Sep 9, 2018 at 4:59 PM
    #1011
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don’t see that as a problem. I’m sure all of my other mods will kill this engine long before what you’re suggesting will.
    Torspd and Roostfactor[OP] like this.
  12. Sep 9, 2018 at 5:00 PM
    #1012
    Roostfactor
    TX panhandle
    Probably true, then we build it stronger!
    loginfailed[QUOTED] likes this.
  13. Sep 9, 2018 at 5:00 PM
    #1013
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Seems Gadget, before he formed the URD site, had a really good article on this that I'm trying to find. I will keep looking and edit post here.
  14. Sep 9, 2018 at 5:02 PM
    #1014
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  15. Sep 9, 2018 at 5:03 PM
    #1015
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    05Taco4x4 likes this.
  16. Sep 9, 2018 at 5:04 PM
    #1016
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Here's a start before the flaming really starts:
    http://www.tuneruniversity.com/blog/2012/04/low-temp-thermostats-whats-the-advantage/
    Clif Notes:
    The biggest misunderstanding about thermostats is that people believe they make the engine run cooler. They don't necessarily do that. The cooling system and load on the engine determines how hot the engine gets, the thermostat fully open will still be the mercy of the coolant system's ability to remove heat.
    . Most engine wear occurs when the engine is cold, once it's warmed up there is very little wear in a healthy engine. Thus, we definitely want to run a thermostat to allow the engine to warm up as quickly as possible until it reaches our desired and designed operating temperature.
    So what then would a low temperature thermostat accomplish? Not much.
    Around town and in the pits, you warm up faster than no thermostat at all, but you will take a while to warm up from 160 to 180 for example. You will get there however, especially on warm days, the only difference is you're trying to cool the car off as it's trying to warm up. As a mater of fact, if you sit there at idle, the temp will go up until the radiator fans kick on since radiators are poor cooling devices without air flow. In other words, sitting still, the thermostat opening temperature doesn't matter much at all.
  17. Sep 9, 2018 at 5:04 PM
    #1017
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thou shalt not mod
    Stryker420 and Roostfactor[OP] like this.
  18. Sep 9, 2018 at 5:07 PM
    #1018
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    ...without doing some careful research first
    Roostfactor[OP] likes this.
  19. Sep 9, 2018 at 5:08 PM
    #1019
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  20. Sep 9, 2018 at 5:08 PM
    #1020
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
