CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Feb 19, 2019 at 7:16 AM
    #1261
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Well I’m assuming you mean between the new fj shroud or or the 09 4 runner shroud? Only difference I saw was the newer one has the backing plates with nuts installed already. The 09 runner shroud you have to install them yourself. Super easy though.
    kasnerd[QUOTED] likes this.
  2. Feb 19, 2019 at 7:24 AM
    #1262
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    is what I meant, the fj just fits and the other you have to wrestle with.
    would like to thank all the info posted on here. this is a great mod and the install is well 'flushed' out. heh
    dnpbakon[QUOTED] likes this.
  3. Feb 19, 2019 at 7:32 AM
    #1263
    dnpbakon
    Kevin
    It was definitely a bitch to get in. I basically installed the fan and shroud then dropped the rad in. It’s a tight fit. Even with the transmission cooler lines going through the bottom.
  4. Feb 19, 2019 at 7:36 AM
    #1264
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    if you had to do it again, what would you do differently? I'd image having the bumper and other bs out of the way would be ideal.
  5. Feb 19, 2019 at 7:40 AM
    #1265
    dnpbakon
    Kevin
    No the bumper and stuff it’s not in the way all. It wasn’t a hard install at all to be honest. It’s pretty straight forward. Only thing that gave me trouble was the URD thermostat upgrade. The way it sits in the supplied CNC adaptor plate, make it hard to hold when getting it in the water neck.
  6. Feb 19, 2019 at 8:15 AM
    #1266
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    groovy. appreciate the help. getting ready to do this, summer will be here sooner than later.
  7. Feb 19, 2019 at 8:22 AM
    #1267
    dnpbakon
    Kevin
    Yea man I knocked it out before summer time for that reason haha. Don’t be afraid of the cooler lines below the radiator. I bent them about a half inch or less. Have me about 1/4 inch maybe more clearance in all diractions from the shroud and radiator. And the thermostat again. Is a little trick. Grinding down the arms was not but. I don’t have a stud pulled so I went with the double but method to remove the studs and it worked out.
  8. Feb 19, 2019 at 12:55 PM
    #1268
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What are those grommets that I see your AC lines PSA through and electrical wiring? My truck doesn't have those. Just holes in the sheet metal
  9. Feb 19, 2019 at 1:04 PM
    #1269
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    You went with the 2010+ shroud, vice the 16711-31200, and I was curious if you noticed any differences.
  10. Feb 19, 2019 at 1:05 PM
    #1270
    dnpbakon
    Kevin
    Again basically all I could see is the one you ordered had the anchor nuts built in. Mine I had to order them separately haha
  11. Feb 19, 2019 at 1:09 PM
    #1271
    05Taco4x4
    2TR-FE Enthusiast
    I had to order those too. They look the same in the IPB, I was curious
    dnpbakon likes this.
  12. Feb 19, 2019 at 1:16 PM
    #1272
    dnpbakon
    Kevin
    Oo man. Well then I have no clue haha
    05Taco4x4[QUOTED] likes this.
  13. Feb 19, 2019 at 1:17 PM
    #1273
    05Taco4x4
    2TR-FE Enthusiast
    haha me too, it's probably stated somewhere in these 60 pages but I'm not looking
  14. Feb 19, 2019 at 1:19 PM
    #1274
    dnpbakon
    Kevin
    Me either . I will say that thermostat was a bitch to get in.
  15. Feb 20, 2019 at 4:11 AM
    #1275
    dnpbakon
    Kevin
    Hey guys. So after 2 days of driving the truck. And it’s bled right. I hold a solid 186.8-190.4. Sounds great but I supposedly received the 160 thermostat I’m convinced they sent me the 170 now after comparing these temps to all you guys. Any input?
    Info- I’m a 2015 trd sport 4x4 double cab with a leer topper. 285/75/16 st Maxx with f5. King lift and sos sliders. Not supercharged and I’m automatic.
    loginfailed likes this.
  16. Feb 20, 2019 at 5:48 AM
    #1276
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What does the invoice say about the Tstat?
  17. Feb 20, 2019 at 5:51 AM
    #1277
    dnpbakon
    Kevin
    Invoice said it’s a 160 degree thermostat. But based on my temps I can’t see that being possible? I honestly didn’t look st the thermostat before putting it in. And it was be a bummer to have to drain the coolant again just to verify.
  18. Feb 20, 2019 at 6:17 AM
    #1278
    NLMOOmar
    NLMOOmar Well-Known Member
    13 DCSB TRD OFFROAD SC
    Shrockwork Sliders, ICON (C/0, Tube UCA and 2.0 Rear), Dakars, US OFFROAD winch mount bumper. 2014 Nav Radio, SOS rear bumper and shackle flip, Pelfreybilt Skids. BAMF Bar mount and CMC, SCS-F5, Magnuson SC
    I have the 170deg and the new radiator with the FJ shroud and I run 195-200 since install in November it looks like I am 100+ miles South of you I do have SC , lightbar behind grill, 4 Cadillac horns and hidden winch bumper which blocks plenty of airflow. Pre CSF I was running 195-208 so the true test will be this summer although last weekend it was 92F while I was down in S. FL and it never went above 200F. I know it not apples and oranges but it gives you a comparison in somewhat close ambient geography. My source for the coolant temp is my ultra gauge Bluetooth.
  19. Feb 20, 2019 at 6:43 AM
    #1279
    dnpbakon
    Kevin
    Thanks for the response man! Yea that only solidifies my assumption that they sent me a 170 thermostat. Unless my 160 is faulty. I’m jax it’s about 65 degrees now and I was at 188.6-190.4 that whole time even doing 86mph for about 25min.
    All check seem good. Overflow resevoir remains at full. Coolant level in radiator is full. Coolant is clean. Engine oil is clean. So no chance of mixture. Ran heat cycle. Heater full blast for 10 min. And ac in full blast for 10min. So In my mind operational checks pass.
  20. Feb 20, 2019 at 10:54 AM
    #1280
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Roostfactor , seems similar to when you had the 170.
