CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Apr 2, 2019 at 6:52 AM
    #1341
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Got my CSF radiator and HPS hoses ordered. Now looking to order the FJ shroud and coolant overflow tank. Perusing the thread and reading above posts, I'm still wondering if it's worth spending a few extra bucks on the Toyota parts or if the other vendors provide decent quality at a discount. Any additional thoughts on that?
  2. Apr 2, 2019 at 9:24 AM
    #1342
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    got mine from ebay..
    it was $38 for the coolant tank and $36 for the Shroud.
    DesertRatliff[QUOTED] likes this.
  3. Apr 2, 2019 at 10:31 AM
    #1343
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I just got the fan shroud from rock auto. Way cheaper $$, while quality-wise I cannot tell a difference from my stock Toyota one.
  4. Apr 2, 2019 at 10:35 AM
    #1344
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I got my shroud from RockAuto and tank from PartsGeek.....quality on both is AT LEAST as good as OEM.
    DesertRatliff likes this.
  5. Apr 2, 2019 at 10:40 AM
    #1345
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I did the OEM thing. Not to down grade the other stuff, I’m sure it’s more than adequate to do the job. It was just my ocd kicking in and wanting to keep Toyota parts on if I could.
  6. Apr 8, 2019 at 7:40 AM
    #1346
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    I am on the fence with this radiator. Although, I am about reducing engine temps, not sure if I want to go as low as 175, as I've read here. Isn't optimal temp for the 4.0 close to 185*?
  7. Apr 8, 2019 at 7:46 AM
    #1347
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Mine stays between 185ish to 190.....
  8. Apr 8, 2019 at 7:54 AM
    #1348
    User Name01
    Bolbi Stroganovsky
    Mine stays at 186 on the highway and goes up to 190 in the city with OEM thermostat and no boost.
  9. Apr 8, 2019 at 7:59 AM
    #1349
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Plz remind us again what thermostats you guys are running and if you're boosted or not. Thanks.
    My CSF is ready to go in as soon as the backordered HPS hoses get here but thinking of just running the OEM t-stat as I'm not boosted; only want the extra cooling capacity to keep the truck at 185-190 on the hill up to the house and for slow, hot desert wheeling. The durability of an all-aluminum radiator is the added bonus.
  10. Apr 8, 2019 at 8:35 AM
    #1350
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    170 T-stat
    Supercharged
    I do not tow
    I do not beat on my truck but do have some fun.
    Stays between 185-190
  11. Apr 8, 2019 at 12:35 PM
    #1351
    henryp
    Henry
    Montana
    Stock t-stat
    Supercharged
    No towing
    Live at ~5000’ above sea level
    190-195 unless temp above 80, then goes higher. That’s with a leaking water pump
    Installing CSF radiator, water pump and 170 thermostat at the moment.
  12. Apr 8, 2019 at 3:13 PM
    #1352
    henryp
    Henry
    Montana
    170 thermostat
    CSF radiator
    Supercharged
    175-185 in town. 194 Max pushing it on the highway uphill. Once I got to speed limit it stayed at 187-188. Definitely worth the investment. Instant drop of about 10 degrees compared to stock radiator/thermostat.
  13. Apr 8, 2019 at 3:42 PM
    #1353
    henryp
    Henry
    Montana
    I’ve been trying to search through the thread, how much trans fluid is lost with removing old radiator?
    jp_flynavy likes this.
  14. Apr 8, 2019 at 4:27 PM
    #1354
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    How did I miss this?!:annoyed::spending:
    05Taco4x4 and BassAckwards like this.
  15. Apr 8, 2019 at 4:34 PM
    #1355
    ThomasMore66
    Dallas/Fort Worth & Durango
    Same. Don’t tempt fate when you’re already in this deep.
    JuanitoBonito[QUOTED] likes this.
  16. Apr 10, 2019 at 6:53 PM
    #1356
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    When doing the csf with fj parts do I reuse any weather stripping and fasteners? Or is there anything i MUST buy? Cant remember if it was only for cowboying the stock shroud.
  17. Apr 10, 2019 at 8:13 PM
    #1357
    henryp
    Henry
    Montana
    I used 4M “small D” weather strip on the sides of the FJ fan shroud. Fits like a glove. Here are the fasteners I used (part numbers buried in thread, but the nut/bolt combo was 90179-06185):
  18. Apr 10, 2019 at 8:14 PM
    #1358
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Thanks. My shroud came bare.
  19. Apr 10, 2019 at 8:14 PM
    #1359
    henryp
    Henry
    Montana
    I did use the cheapo FJ rockauto fan shroud. Suppose to be same fit
  20. Apr 10, 2019 at 8:18 PM
    #1360
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I went Ebay. Same, cheaper than 200 for oem.
