CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Mar 20, 2018 at 10:52 AM
    #121
    ThomasMore66
    Dallas/Fort Worth & Durango
    Bought!
    loginfailed and GT7 like this.
  2. Mar 20, 2018 at 10:55 AM
    #122
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Well done ThomasMore66! Added to the list.
    GT7 likes this.
  3. Mar 20, 2018 at 11:02 AM
    #123
    ThomasMore66
    Thanks to all of you for helping me spend my money. Just when I thought I was done with this truck...
  4. Mar 20, 2018 at 11:04 AM
    #124
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah me too. This....now a throttle body. :spending:
    Fuck it!!!
    loginfailed, Roostfactor[OP] and GT7 like this.
  5. Mar 20, 2018 at 11:07 AM
    #125
    Roostfactor
    TX panhandle
    Well there is your problem!? Don't ever think you are done and you won't disappoint yourself!:rofl:
  6. Mar 20, 2018 at 11:08 AM
    #126
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im undecided about the throttle body. I probably will because its the last thing left at this point
    Roostfactor[OP] and jojotoo like this.
  7. Mar 20, 2018 at 11:10 AM
    #127
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    At some point I’ll have to throw in a high performance clutch....if I can can get a too good to pass up deal...I’d get a big brake kit too.
    Roostfactor[OP] and loginfailed like this.
  8. Mar 20, 2018 at 11:18 AM
    #128
    ThomasMore66
    Ok, I know this isn't the thread for this, but how much performance increase is there?
  9. Mar 20, 2018 at 11:19 AM
    #129
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Ive said this too many times ..
    loginfailed and Roostfactor[OP] like this.
  10. Mar 20, 2018 at 11:25 AM
    #130
    ThomasMore66
  11. Mar 20, 2018 at 11:29 AM
    #131
    Roostfactor
    TX panhandle
    With my 76mm I definitely notice better throttle response and more top end power. I have also opened up the sc inlet though to match the size of the tb adapter.
  12. Mar 20, 2018 at 11:31 AM
    #132
    Roostfactor
    TX panhandle
  13. Mar 20, 2018 at 11:33 AM
    #133
    ThomasMore66
    So I missed something in this thread...adapter...
  14. Mar 20, 2018 at 11:35 AM
    #134
    ThomasMore66
  15. Mar 20, 2018 at 11:43 AM
    #135
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    So this urd kit is needed to use the moto thermostat??
  16. Mar 20, 2018 at 11:49 AM
    #136
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    Anyone have a standard engine temp under load in 90+ degree weather? My ultragauge read 195.8 today for a Breidenbach minute after a Hill then dropped back to 192-194 ac on full blast. Just checking if my fan clutch or something Is failing. I’m super obsessive about engine temps :/
  17. Mar 20, 2018 at 12:00 PM
    #137
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Do you know what degree thermo comes when the s/c is installed? Or is it the stock thermo?
  18. Mar 20, 2018 at 12:00 PM
    #138
    GT7
    Grant
    Phoenix
    2013 DCLB
    Stock
  19. Mar 20, 2018 at 12:01 PM
    #139
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    What temp is it?
  20. Mar 20, 2018 at 12:06 PM
    #140
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just noticed a little better throttle response off idle. The rest is purely butt dyno which can be pretty innacurate. I did no port matching of any kind. I just bolted it on there. One day when I get bored, I’ll go back and attempt to port match the adapter, the 7th and the SC inlet to match the throttle body.
    Roostfactor[OP] likes this.
