CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Apr 18, 2019 at 10:57 AM
    #1381
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I should have posted a link to the main NST site, but running out to the truck with the old parts confirms my two installed NST pulleys are the same size as the old parts.
    EDIT: link changed to the 1GR-FE OEM size page in my previous post
  2. Apr 18, 2019 at 11:04 AM
    #1382
    Midnight Blue
    Midnight Blue Well-Known Member
    Ben
    SoCal
    PreRunner, TRD Sport
    Morimoto projector retrofit w/ Profile halo DTRL, Morimoto LED fog lights, full custom stereo
    Ah, excellent, no worries then!
    DesertRatliff[QUOTED] likes this.
  3. Apr 27, 2019 at 7:22 PM
    #1383
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Installed mine yesterday, very nice. Thanks everyone for figuring this out.
  4. May 2, 2019 at 10:20 AM
    #1384
    STAGE 2
    STAGE 2 Well-Known Member
    Heads up guys. I called CSF yesterday and they confirmed that they are shipping a direct drop in Tacoma specific hipo radiator late May early June. FYI for those of you like me who want to avoid cutting swapping or bending.
  5. May 2, 2019 at 10:27 AM
    #1385
    Midnight Blue
    Ben
    SoCal
    Really?! Cool news. I was fully willing to swap the FJ shroud etc on but I'd happily take a taco specific radiator instead.
    Stryker420 likes this.
  6. May 2, 2019 at 10:27 AM
    #1386
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    CSF. They do it right. This is fantastic news.
    HeavyThumbs and Norton like this.
  7. May 2, 2019 at 10:31 AM
    #1387
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Honestly I’d rather have the FJ version now that I’ve done the install. The bending is extremely minor and the shroud is dirt cheap. The result is a cooler not only deeper but larger in frontal surface area than stock. It wouldn’t make sense to me to pay the same cost, minus the $100 or so for a shroud and coolant take, for a smaller radiator that isn’t significantly easier to install and will very likely not perform as well.
    Stryker420 and crashnburn80 like this.
  8. May 2, 2019 at 10:35 AM
    #1388
    Midnight Blue
    Ben
    SoCal
    While the extra inch or 2 in overall radiator height does made a difference in terms of frontal surface area and coolant capacity, the real difference in the system is being a much thicker 2 core. "Losing" that extra inch or 2 won't amount to very much in terms of cooling capabilities.
    Stryker420 and mightytacoman like this.
  9. May 2, 2019 at 10:39 AM
    #1389
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I’d be curious to test that. The bottom 2” is completely clear of the AC, transmission, and supercharger radiator so it breaths the coolest air. Also on a truck with a plate bumper and winch the bottom 6” of the radiator gets the cleanest air flow in terms of where the holes line up with exposed radiator. To me, that clean fresh flow is worth it I think but I’m not going to claim to have any data to back that up.
  10. May 2, 2019 at 10:47 AM
    #1390
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    either way is a lot better than plastic rad that was probably carpet and 2 liter bottles before it was repurposed for one of most important components for an internal combustion besides the actual combustion part.
  11. May 2, 2019 at 10:47 AM
    #1391
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    and too each his own. I’m not saying installing a Tacoma specific version is wrong. I’m saying as someone who was really hesitant to buy the FJ version, after doing the install, I wouldn’t wait for the Tacoma version. There is zero difficult effort required to install the FJ version with the FJ shroud and tank. It was one of the easiest mods I’ve installed and the bending is nothing. Plus IMHO I can see advantages after install of having the bigger version in terms of surface area and capacity available.
    2WD likes this.
  12. May 2, 2019 at 11:01 AM
    #1392
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Keep in mind the radiator was probably pop cans in its previous life :p. That being said I totally agree, plastic tanks left exposed to light with a plate bumper on probably don’t always hold up for the lifespan of a Tacoma.
    kasnerd[QUOTED] likes this.
  13. May 2, 2019 at 11:12 AM
    #1393
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    no doubt. we won't even get into the microwave, toasters and rusted scrap that frame is made out of. Japanese trucks made from Chinesium metals.
  14. May 2, 2019 at 11:22 AM
    #1394
    STAGE 2
    It will be interesting to see the difference. My bigger concern is down the road with other mods interfering with the FJ rad given it’s size. Regardless I would think that even if the FJ cools a measurable amount better than the Tacoma specific version, both are likely so much better than stock that as a practical matter it will make no difference.
  15. May 2, 2019 at 12:05 PM
    #1395
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    When you're boosted though every little bit of cooling head room can help! Last year the stock setup began to fail me miserably. Hence why I pulled the trigger on a CSF 7076 and a URD thermostat mod this spring before temperatures come up. I think if your Tacoma is stock your comment is true but if you’ve begun significantly changing your stock powertrain there maybe value to 2 more inches, dirty comment intended lol.
    BillDaCat8 likes this.
  16. May 2, 2019 at 12:36 PM
    #1396
    STAGE 2
    Yeah... you supercharged guys may need it. Unless it’s a diesel I like my trucks NA. For trucks without I don’t see their being much of a difference.
  17. May 2, 2019 at 12:46 PM
    #1397
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Awesome
  18. May 2, 2019 at 5:20 PM
    #1398
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    About time! They told me last year they were going to be released starting at the beginning of the year. Besides it only makes sense, they probably sell 20 - 25 Tacoma's to every 1 4runner
    Norton likes this.
  19. May 5, 2019 at 1:07 PM
    #1399
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Anyone notice the radiator cap is higher pressure than stock? Stock one won’t fit on the CSF radiator.
  20. May 5, 2019 at 1:13 PM
    #1400
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    That looks like the larger size Japanese cap. You can run to the parts store and get ones off another vehicle that are like 16. I want to say Nissan Maxima or something like that. Yota and Honda use the smaller ones. If your local parts store will let you dig around that would be your best bet if it concerns you.
