CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Sep 17, 2019 at 4:18 PM
    #1601
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    180f. You can get a 170. I already have it but it only dropped my temps a few degrees.
  2. Sep 17, 2019 at 4:43 PM
    #1602
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Only the 160.
    jp_flynavy and henryp like this.
  3. Sep 17, 2019 at 5:01 PM
    #1603
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    Is that something I can get at a drop in or URD kit only?
  4. Sep 17, 2019 at 5:05 PM
    #1604
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
  5. Sep 17, 2019 at 5:15 PM
    #1605
    jp_flynavy
    2015 Tacoma DCLB
  6. Sep 17, 2019 at 5:58 PM
    #1606
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I need to redo mine. Will be giving it a shot, while trying to clean up a leak, and consolidate it into just one part.
  7. Sep 17, 2019 at 6:32 PM
    #1607
    jp_flynavy
    2015 Tacoma DCLB
    It’s leaking? How are the temps looking?
  8. Sep 17, 2019 at 7:00 PM
    #1608
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have a different setup. Not related to any discussed here. Don't worry.
    henryp and jp_flynavy[QUOTED] like this.
  9. Sep 18, 2019 at 6:13 AM
    #1609
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Havn’t had time to install it yet, but I know some others in the supercharged thread are running it.
    jp_flynavy[QUOTED] likes this.
  10. Oct 6, 2019 at 11:42 AM
    #1610
    jp_flynavy
    2015 Tacoma DCLB
    After installing the cfs radiator, my temps only dropped a few degrees. I knew that the factory thermostat was probably the bottle neck in my quest for 185* running temps.
    After dropping in the mishimoto 160* t-stat/housing, now I am struggling getting past 174* operating temperature. It has been little cooler outside than usual, however, I think I was too aggressive stepping down 20* in thermostat opening temperatures.
    Anyone else running into this issue?
    Norton and Kolunatic like this.
  11. Oct 6, 2019 at 12:17 PM
    #1611
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Not yet
    I’m still hoarding parts
  12. Oct 6, 2019 at 2:30 PM
    #1612
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That's not a bad thing. That's where it works. Just watch if during the winter times. If it has a difficult time reaching over 168°, then you will want to get a 170° thermostat.
    jetfishn, Kolunatic and Norton like this.
  13. Oct 6, 2019 at 5:30 PM
    #1613
    jp_flynavy
    2015 Tacoma DCLB
    My worry now is that even the 174* was reached for a brief moment on the hwy cruising at 80, revving close to 3k (4.88 on 35s), is not going to allow for the oil to properly warm up.
    I am not sure if mishimoto offers a 170* t-stat. The 160* was a good option because it came in the same OEM housing and was very easy to install and the price is great.
    Kolunatic likes this.
  14. Oct 6, 2019 at 7:01 PM
    #1614
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The oil will get to temp just fine.
    jp_flynavy likes this.
  15. Oct 6, 2019 at 10:51 PM
    #1615
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    From those who have the new drop in version, where is the best place to buy these? Any warranty provided that anybody knows of, whether it be through the vendor or CSF itself?
  16. Oct 15, 2019 at 6:42 AM
    #1616
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
  17. Oct 15, 2019 at 6:48 AM
    #1617
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    JustDSM[QUOTED] likes this.
  18. Oct 15, 2019 at 6:48 AM
    #1618
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well would you look at that!
    JustDSM likes this.
  19. Oct 15, 2019 at 6:50 AM
    #1619
    JustDSM
    Justin
    Ogden, UT
    Just look at it!!
    DocME and Torspd[QUOTED] like this.
  20. Oct 15, 2019 at 6:56 AM
    #1620
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    How does it compare to the csf?
    JustDSM likes this.
