CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Nov 25, 2019 at 4:08 PM
    #1641
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks buddy, appreciate it!:fistbump:
  2. Nov 25, 2019 at 4:12 PM
    #1642
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is the brand that almost everyone uses, when transitioning to a 160°. Good quality.
  3. Nov 25, 2019 at 4:28 PM
    #1643
    BassAckwards
    Thank you sir, it seems that Motorad manufactures them and then they're rebranded. This was a Duralast when i ordered it from Autozone
    Kolunatic, 05Taco4x4 and buyobuyo like this.
  4. Nov 25, 2019 at 4:45 PM
    #1644
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Absolutely correct.
    Kolunatic, 05Taco4x4 and BassAckwards like this.
  5. Dec 1, 2019 at 8:20 AM
    #1645
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    URD has the CSF Tacoma specific one for $449 on sale........
    edit.....also, the fj one for $349!!!! That’s a deal fellas
    lilgerber and Kolunatic like this.
  6. Dec 23, 2019 at 1:02 PM
    #1646
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Anyone have opinions on which electric fan to run? Been looking into the flexalite one. Model 678
  7. Dec 23, 2019 at 1:26 PM
    #1647
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  8. Dec 23, 2019 at 3:51 PM
    #1648
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. Dec 23, 2019 at 5:46 PM
    #1649
    mightytacoman
    Kel
    4.5L 1grfe
    Alright so then piecing together a spal set up. I'll need a programmable controller and the fan itself. Can the factory shroud and tank be reused? Anyone know the size of the factory fan? 16"?
  10. Jan 2, 2020 at 10:16 PM
    #1650
    Charger92
    Charger92 Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    So wanting to do the aluminum rad along with a 170 degrees thermostat, is URD the only place to get the stat from? And is the only way with a conversation kit from URD?
  11. Jan 2, 2020 at 10:23 PM
    #1651
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I ironically did get my stat through URD. I did not look elsewhere, not to say you can’t find one somewhere else.
  12. Jan 3, 2020 at 7:43 AM
    #1652
    hualampeter
    hualampeter Well-Known Member
    Peter
    Chester, MD
    TRD Off Road
    Fox 3" Lift, Total Chaos UCA, and Wheelers Bumps.
    Any update on this?
  13. Jan 3, 2020 at 5:56 PM
    #1653
    oni06
    oni06 Well-Known Member
    I got busy and never followed up on it.
  14. Jan 3, 2020 at 9:50 PM
    #1654
    Charger92
    So a person definitely has to buy a conversation kit to put a 170° thermostat correct?
    That would suck if that's the case since a thermostat normally is pretty inexpensive.
    hualampeter likes this.
  15. Jan 3, 2020 at 9:57 PM
    #1655
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I was shopping for what I needed in one place and they had an item I needed. That’s how I looked at it.....
  16. Jan 3, 2020 at 10:13 PM
    #1656
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
  17. Jan 3, 2020 at 11:06 PM
    #1657
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    The
    you could also run the mishimoto 160. It’s for a 4runner bolts right in. my plan is the CSF and the mishimoto 160. I have both just need to install.
    Hawk373 likes this.
  18. Jan 3, 2020 at 11:07 PM
    #1658
    nudavinci64
    Robert
  19. Jan 4, 2020 at 7:34 AM
    #1659
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    My Mishimoto arrives today.
  20. Jan 4, 2020 at 8:01 AM
    #1660
    mightytacoman
    Kel
    4.5L 1grfe
    When will you get around to installing it? curious to see if you get better results over the 160 Motorad one.
