CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Jan 4, 2020 at 8:09 AM
    #1661
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Unfortunately not today. Going out of town for an adventure. Maaaaaybe tomorrow. If not, then during the week. Also installing a new water pump. Only need a little over an hour, but I have to have that time.
  2. Jan 4, 2020 at 8:22 AM
    #1662
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Are they back in stock?
  3. Jan 4, 2020 at 9:43 AM
    #1663
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  4. Feb 11, 2020 at 5:44 PM
    #1664
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    So looking at urd's website I can't tell a difference between the Tacoma labeled radiator and the fj labeled one other than the fact the Tacoma one is $100 more. Can someone please explain why there is a price difference?
    Thank you in advance.
  5. Feb 11, 2020 at 5:47 PM
    #1665
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    the fj one you either have to buy an fj shroud and reservoir, or modify the Tacoma one.
    Tacoma radiator is direct bolt on
    Norton and TacoFMS[QUOTED] like this.
  6. Feb 11, 2020 at 5:50 PM
    #1666
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I don’t know the technical differences but the fj definitely works. That’s what we all used initially prior to the Tacoma model being released. Just make sure if you go fj to get the fj shroud and overflow tank. Otherwise you’ll have to do some trimming to the bottom of the Tacoma shroud to make it fit the fj radiator.
    Norton and TacoFMS like this.
  7. Feb 11, 2020 at 5:54 PM
    #1667
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The tacoma radiator is bolt in and 2 row. The FJ radiator is taller than the stock Tacoma radiator and 1 row.
    TacoFMS[QUOTED] likes this.
  8. Feb 11, 2020 at 5:55 PM
    #1668
    TacoFMS
    Justin
    Louisa County, VA
    Thank you both. I would assume they both give similar results? Just two ways to skin the same cat?? Seems if you save the money on a fj one then you spend that money on the replacement shroud and reservoir...
    henryp and JuanitoBonito[QUOTED] like this.
  9. Feb 11, 2020 at 5:58 PM
    #1669
    TacoFMS
    Justin
    Louisa County, VA
    Thank you Jeremy! URD has them both listed as 2 row. Hence my confusion.
  10. Feb 11, 2020 at 6:11 PM
    #1670
    anthony250f
    Anthony
    San Diego, CA
    I have heard the fj has a larger coolant capacity?
  11. Feb 11, 2020 at 6:40 PM
    #1671
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Unlikely, the entire thing being thicker even if it isn’t 2x, compared to the extra 2 inches at the bottom.
    I have an FJ and a tacoma csf sitting in the garage. I want to sell one of them, likely the fj one. If someone wants to buy, and they don’t care, I can fill both up with water to positively end the debate...
  12. Feb 11, 2020 at 6:41 PM
    #1672
    racebug68
    Travis
    Chandler, AZ
    Are there any side by side measurements or comparisons that people want of them before I put it up for sale?
    TacoFMS likes this.
  13. Feb 11, 2020 at 6:41 PM
    #1673
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Alls I can say is the fj setup in mine works like a charm...
    Norton, jojotoo and TacoFMS like this.
  14. Feb 12, 2020 at 4:39 AM
    #1674
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
    whatstcp and MY50cal like this.
  15. Feb 12, 2020 at 6:32 AM
    #1675
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Dang, the Tacoma radiator is $100 more expensive than the FJ/4-Runner one.
  16. Feb 12, 2020 at 2:23 PM
    #1676
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    But how much is the FJ shroud and tank?
    whatstcp likes this.
  17. Feb 12, 2020 at 2:28 PM
    #1677
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Just under $100 if you go aftermarket
  18. Feb 12, 2020 at 2:32 PM
    #1678
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Here is what I paid for all new OEM FJ parts with part numbers. You can save a fair amount going aftermarket. We did back to back installs with aftermarket and OEM shrouds and tanks, OEM was definitely better quality and fit, and the OEM shroud was easier to install, but at the end of the day it is just a plastic shroud and a plastic tank. To me it was worth the extra few dollars for OEM.
    16470-31130 Recovery Tank $59.50
    16711-31510 Fan Shroud $78.02
    CharlieVictor, Torspd and Norton like this.
  19. Feb 12, 2020 at 4:19 PM
    #1679
    Sandman614
    Tim
    '06 SR5 Off Road
    Looks like a wash
  20. Feb 13, 2020 at 6:22 AM
    #1680
    EdgemanVA
    Virginia Beach
    2008 X-Runner
    Several
    My thought is you are just buying the radiator, and if there isn't any significant difference between the two, why does the Taco radiator cost $100 more? Both are "drop in" radiators, requiring no modification, and the FJ shroud and tank shouldn't even be a consideration of the price of this radiator.
    They look identical, the descriptions are identical, the parts that come with both are identical, yet one costs $100 more?
    It just doesn't pass the "logic" test.
