CSI Fridge/Freezer Mega Thread
Discussion in 'Non-automotive Group Buys' started by Mike's Custom Toys, Jul 26, 2018.
  1. Jul 26, 2018 at 10:17 AM
    Mike's Custom Toys
    Mike's Custom Toys [OP] Well-Known Member Vendor
    Grants Pass, OR
    The original W52 is not available. However here is the new Dual Zone Fridge.
    W53 with cover $530 Free Shipping
    #W53
    Black Ice Refrigerator / Freezer 63 Quart
    The all new CSI® 63 Quart Black Ice Fridge/Freezer runs off of your vehicle’s 12V/24V accessory outlet for both cooling and freezing on the go. Dual zone digital LCD controls let you dial in the temperatures you want, whether you want to keep your popsicles frozen and your drinks ice cold, or remove the partition and go all in with your beverage of choice. The two included removable baskets help keep everything organized and make for easy loading and unloading and a removable drain plug makes quick work of post trip cleanup. Low power consumption and built in battery protection ensures your vehicle’s battery will always have the reserves needed to get you on the road again and a built in USB charging port helps keep your devices charged, too. An AC power supply is also included to pre-cool before your big trip or just have the convenience of cold treats in your shop.
    • LCD controls with 2 individually adjustable zones of cooling/freezing
    • 100% CFC and HFC free insulation for great performance and low energy use
    • Power supply and 110V cord included
    • CSI downloadable app for smart phone control
    • Removable partition w/sensor automatically changes to single zone when removed
    • Removable baskets included
    • Rear wheels & extendable handle for mobility
    • USB charging port, 5.1V/2.1A
    • Drain plug for easy clean out
    • High/low compressor mode for energy saving or max cooling
    • 3 levels of adjustable battery protection to eliminate discharged batteries
    • Built in LED lighting
    • Available accessories: insulation cover (#W54), vehicle mount w/slide (#W57), portable battery (#W59)
    • Dimensions: 28.46" x 17.51" x 23.54"
    #W59
    Portable Battery Pack
    • Allows portable refrigerator/freezer operation without power source
    • Two USB charging ports - 5.1V / 2.1A
    • Can operate refrigerator/freezer while charging
    • Hours of operation from a single charge
    • Fits all CSI Black Ice refrigerator/freezers
    • Dimensions: 6.1" x 3.5" x 3.1"
    This battery pack works with all csi fridges the 52,63,84. Provides 4-8 hrs run time depending on the different fridge settings, models and ambient temp. The battery pack can be used alone or best as a pass through. When used as a pass through it keeps the fridge running when you shut off the car and keeps all your settings and food cold. It also prevents any compressor startup draws that sometimes affect modern charging systems. Toyota's are pretty safe but some of the Gladiator crowd have run into check engine light problems with low rpm charging when running a fridge. This is an awesome product for those who don't have a hot all the time plug.
    $225
    W60 with battery pack $650
    CSI’s Black Ice 100QT Dual Zone Refrigerator/Freezer is built to handle those extended weekend getaways, constructed with advanced technology that is designed to keep your goods either chilled or frozen regardless of the outdoor temperatures. Features an internal compressor that eliminates the need for ice, convenient DC and AC connectors, and a backup battery compartment for when power is not available. Rugged heavy duty wheels and a telescoping handle make transport a breeze and the reversible and removable doors allow easy versatility to have the set up that suits you best. Add in the optional W58 Sliding Vehicle Mount (sold separately) for even further versatility. Dual zones let you control your chilled or frozen goods, and with enough room for up to 150 cans. Bluetooth connectivity allows you to change or monitor the temperatures from your phone without even having to get up out of your camping chair, making it the perfect companion for those gourmet campfire dinners or evening beverages.
    • 100 Quart, dual zone
    • Dual compartments with individual temperature control
    • Heavy duty compressor for superior cooling performance
    • Three stage battery protection system prevents vehicle battery drain
    • Shockproof and durable design
    • Removable wire storage baskets included
    • Interior drain plugs for easy cleanup
    • Digital display control panel and interior LED light
    • CSI Black Ice Refrigerator/Freezer mobile app available for Android or iPhone
    • Heavy duty wheels and telescoping handle
    • Reversible / removable Refrigerator door design
    • Compatible with CSI’s Sliding Vehicle Mount (Part #W58)
    • 12/24VDC, 100-240VAC Power supply included
    • Detachable battery (Part # W61) for operation when power is not available
    • Zone capacity 59 Quarts and 41 Quarts
    • Dimensions: 35.25” D x 22.5” W x 18” Height
    We also have slides available as well
    $275 for the large
    $250 for the small
  2. Jul 26, 2018 at 10:24 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    How would you rate the volume of the fridge with the compressor running? What is the current draw from the 12v outlet?
    What experience do you guys have in this market segment?
    I'm potentially interested, that's a great price, just doing homework
    0uTkAsT likes this.
  3. Jul 26, 2018 at 10:42 AM
    Mike's Custom Toys
    Grants Pass, OR
    Current draw is intermittent between .7-2.5 amp hours. On eco mode in bag out of direct sunlight 90 deg day we saw 1.25 amp hour draw across a 8 hr period.
    We are not the manufacturer we build Toyota's all day. We wanted to have a certain amount of camping gear for our new website and hooked up as a distributor for these. That being said ARB discontinued the use of this design and that opened the door for the factory to market it on its own and here we are.
    mcharfauros and FishinCrzy like this.
  4. Jul 26, 2018 at 10:51 AM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Appears to be another variant of the indelB / Truckfridge models. Good value for a danfoss compressor. Current draw/noise/reliability is going to be about the safe as their other models as they all run off the same compressor.
    I've had a 31qt model for several years now and it's worked well. Wouldn't install it in an open truck bed.
    cruiserguy, SR-71A and 0uTkAsT like this.
  5. Jul 26, 2018 at 10:56 AM
    Mike's Custom Toys
    Grants Pass, OR
    Warranty is one year. We have ours in the truck bed and will let you know when it brakes
  6. Jul 26, 2018 at 11:18 AM
    Mrguitarguy01
    Mrguitarguy01 Well-Known Member
    Why?
  7. Jul 26, 2018 at 11:19 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    If I got in on this thing right now would I get the cover?
    If so, in AF
    Tantaco37 likes this.
  8. Jul 26, 2018 at 11:20 AM
    Mike's Custom Toys
    Grants Pass, OR
    Yes, I will post all free cover members in the op
  9. Jul 26, 2018 at 11:21 AM
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I had an issue with the voltage cut-off switch that required taking it slightly apart. Wire connections within the vented area where the compressor lives are not weatherproof on mine. Additionally, wouldn't want all the dust and grime that comes with driving off road getting in there.
    cruiserguy likes this.
  10. Jul 26, 2018 at 11:24 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Do you think the 52 quart is small enough to fit in the backseat of a doublecab? I have a topper on the way, but it's still several months out, but I have an empty backseat all the time
  11. Jul 26, 2018 at 11:41 AM
    Mike's Custom Toys
    Grants Pass, OR
    Yes it will fit
  12. Jul 26, 2018 at 11:43 AM
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Alright, I'll be the guinea pig. Put me on the list!
  13. Jul 26, 2018 at 11:53 AM
    Mike's Custom Toys
    Grants Pass, OR
    We can sell you an ARB 10810602 63 qt for $1416 with free shipping. let me know
    0uTkAsT[QUOTED] likes this.
  14. Jul 26, 2018 at 12:34 PM
    Mike's Custom Toys
    Grants Pass, OR
    On it. Pm sent
  15. Jul 26, 2018 at 4:47 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  16. Jul 26, 2018 at 5:06 PM
    1BDTACO
    1BDTACO Well-Known Member
    Joe
    North Dakota
    2017 Tacoma TRD OR
    OME Medium Lift, Fx Pro wheels, Falken at3 285/70/17
    Send me that pm i want one :thumbsup:
  17. Jul 26, 2018 at 5:09 PM
    Mike's Custom Toys
    Grants Pass, OR
    PM sent
  18. Jul 26, 2018 at 5:57 PM
    TWTaco
    TWTaco Well-Known Member
    Dave
    I would be having in my bed as well, How well will this hold up to off road dust dirt , maybe some wet weather? Very interested!
  19. Jul 26, 2018 at 6:17 PM
    Mike's Custom Toys
    Grants Pass, OR
    They have held up great. I would blow it out every once and a while. I have yet to subject one to anything other than rain. I have yet to submerge one.....maybe I should for the next video
  20. Jul 26, 2018 at 6:19 PM
    TWTaco
    Dave
    Is there a slide mount set up available?
