CSI Fridge/Freezer Mega Thread
Discussion in 'Non-automotive Group Buys' started by Mike's Custom Toys, Jul 26, 2018.
  1. Aug 28, 2018 at 2:42 PM
    #201
    DaMaDo
    DaMaDo Well-Known Member
    Northern AL
    2018 White TRD Pro
    How does the amp draw compare to the ARB? I'm thinking of putting in a solar power bank in my bed and want to calculate my daily charge requirements.
  2. Aug 28, 2018 at 2:45 PM
    #202
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    From what I heard it is drawing around 2 AMPs. Don't quote me on that though. I am going to be installing a Tonneau...unfortunately this might be too high to fit underneath.
  3. Aug 28, 2018 at 2:51 PM
    #203
    Mike's Custom Toys
    Mike's Custom Toys [OP] Well-Known Member Vendor
    Grants Pass, OR
    It varies but less than two.
  4. Aug 29, 2018 at 11:13 AM
    #204
    roy326
    roy326 Well-Known Member
    Roy
    Southern California
    2020 Tundra/V8 4Rnner/GX460. I do miss my tacoma
    Just sent in a paypal!
  5. Aug 29, 2018 at 11:37 AM
    #205
    Mike's Custom Toys
    Grants Pass, OR
    Got it. Fridge will go out today.
  6. Aug 29, 2018 at 11:42 AM
    #206
    Mike's Custom Toys
    Grants Pass, OR
    Back Order Covers will start shipping Tomorrow. Current order covers will ship Friday. Yes we finally are getting some in.
    sd1uh8as, medic2230 and roguegs like this.
  7. Aug 29, 2018 at 12:18 PM
    #207
    medic2230
    Murph
    Bama! Roll Tide
    :woot:
  8. Aug 30, 2018 at 9:32 PM
    #208
    roy326
    Roy
    Southern California
    On stock battery, how long can this be plugged in before it starts to drain my battery to the point where I can’t start my car ? (Just a ballpark idea please)
  9. Aug 30, 2018 at 10:21 PM
    #209
    roguegs
    Angelo
    V8 T4R
    It all depends on how often you drive your truck. I would think a fresh battery you can run this a a day or two from a full charge.
  10. Aug 31, 2018 at 7:08 AM
    #210
    Mike's Custom Toys
    Grants Pass, OR
    There is voltage protection settings on the fridge to allow you to always be able to start your car.
  11. Aug 31, 2018 at 10:18 AM
    #211
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    with my truck fridge, stock battery lasted me usually at least a day when the truck hasnt been started AND voltage protection set to high cutoff. Things that will make a difference is:
    is the fridge already cold (has it been running and youre just trying to keep temps steady)?
    did you just add room temperature items into the fridge?
    how hot is it outside?
    I've had the fridge turn off after 6-8 hours with 90+ degree temps outside but also had it run for well over 24 hours in the winter.
  12. Sep 6, 2018 at 8:31 AM
    #212
    Mike's Custom Toys
    Grants Pass, OR
    We also now carry the full tembo tusk line and they have an awesome slide with cutting board set up.
  13. Sep 11, 2018 at 9:21 AM
    #213
    Mike's Custom Toys
    Grants Pass, OR
    Still have plenty of these left
  14. Sep 11, 2018 at 9:22 AM
    #214
    Mike's Custom Toys
    Grants Pass, OR
  15. Sep 18, 2018 at 8:22 AM
    #215
    Mike's Custom Toys
    Grants Pass, OR
    Anyone get out and use their Fridge this last weekend?
  16. Oct 1, 2018 at 8:40 PM
    #216
    Mattynokes
    Mattynokes Well-Known Member
    Madison, WI
    18' BLACK Off Road DCSB
    Prinsu Toprac TRD Beadlocks Century Shell
    What’s your price for this slide set up and a fridge?
    medic2230 likes this.
  17. Oct 2, 2018 at 8:37 AM
    #217
    Mike's Custom Toys
    Grants Pass, OR
    The slide is $375 and the optional cutting board slide is another $275 plus fridge $459.95 = $1,109.95 shipped to your door. All of the slide options make my fridge look very reasonable, but then again with a fridge priced so low now people can afford slides.
    Mattynokes likes this.
  18. Oct 2, 2018 at 8:55 AM
    #218
    Mattynokes
    Madison, WI
    Do you know the weight of the fridge itself?
  19. Oct 2, 2018 at 9:07 AM
    #219
    Mike's Custom Toys
    Grants Pass, OR
    Just under 40 lbs
  20. Oct 5, 2018 at 12:30 PM
    #220
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Can I get a PDF copy of the manual? I misplaced mine and now I'm periodically getting 'Err 1' when plugged into an always on 12v socket. Power cycling makes it go away sometimes. Just trying to figure out what's up
