CSI Fridge/Freezer Mega Thread
Discussion in 'Non-automotive Group Buys' started by Mike's Custom Toys, Jul 26, 2018.
  1. May 17, 2020 at 8:29 AM
    #641
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    So mine runs 24/7 and it's getting warmer over here. I went outside today and it was blinking er1 and the temp on it was 58 degrees. Everything inside is still cold, and I have the cover on. Thoughts on what you all do during the hotter times of year. It's on Eco and when the temp up or down are pressed it's states 32 degrees.
  2. May 17, 2020 at 11:34 AM
    #642
    Mike's Custom Toys
    Mike's Custom Toys [OP] Well-Known Member Vendor
    Grants Pass, OR
    ER 1 is a voltage protection error. Check the settings, connections, possibly turn off and back on.
  3. May 17, 2020 at 11:38 AM
    #643
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thanks Mike that's exactly what I did
    Newlife likes this.
  4. May 21, 2020 at 3:02 PM
    #644
    PK930
    PK930 4Runner, but y’all seem cooler
    Texas
    ‘12 4Runner
    Not sure if its the same with you Taco guys, but the wiring for the rear 12v port on in SR5 T4R wasn't thick enough. It'd run for like 30 minutes then trop the ER1.
    I suspected it was the factory wiring so I ran a 10g all the way back and used a power-panel-thingie-ma-jig. The only other time it tripped an error was after 3.5 days of the truck not running.
    sbl23 likes this.
  5. May 27, 2020 at 9:21 AM
    #645
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Anyone attached their cover to the lid? If so, what did you use ? I’m thinking two strips of Velcro would do but was curious if anyone has done anything similar.
  6. May 27, 2020 at 10:13 AM
    #646
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    What's the current price on this?
  7. May 27, 2020 at 10:18 AM
    #647
    GoJo
    GoJo Well-Known Member
    Utah
    Worth it! :D
    I just picked mine up a bit ago for $459.95
  8. May 27, 2020 at 10:18 AM
    #648
    GoJo
    Utah
    I haven't... yet. First trip out that was something that I realized needs to happen.
    Newlife[QUOTED] likes this.
  9. May 27, 2020 at 10:28 AM
    #649
    CayucosTacoma
    2004 Double Cab 4x4
    Right on. Birthday is coming up soon, might need to get a present for myself lol
  10. May 27, 2020 at 10:36 AM
    #650
    GoJo
    Utah
    I wouldn't hesitate. I took it out for the first time 2 weekends ago, and all I could say was "I should have done this so much sooner". I had it in my 'shopping cart' per se, for months... should have done it years ago haha!
    Paired it with a Jackery 500 and 100w Renogy solar panel set up, game changer!
  11. May 27, 2020 at 10:50 AM
    #651
    Mike's Custom Toys
    Grants Pass, OR
    Unfortunately due to covid19 we are currently out of stock. We have Two new dual zone models coming in that will start shipping June 22nd that are available for pre-order.
    W53 with cover $480 Free Shipping
    #W53
    Black Ice Refrigerator / Freezer 63 Quart
    The all new CSI® 63 Quart Black Ice Fridge/Freezer runs off of your vehicle’s 12V/24V accessory outlet for both cooling and freezing on the go. Dual zone digital LCD controls let you dial in the temperatures you want, whether you want to keep your popsicles frozen and your drinks ice cold, or remove the partition and go all in with your beverage of choice. The two included removable baskets help keep everything organized and make for easy loading and unloading and a removable drain plug makes quick work of post trip cleanup. Low power consumption and built in battery protection ensures your vehicle’s battery will always have the reserves needed to get you on the road again and a built in USB charging port helps keep your devices charged, too. An AC power supply is also included to pre-cool before your big trip or just have the convenience of cold treats in your shop.
    • LCD controls with 2 individually adjustable zones of cooling/freezing
    • 100% CFC and HFC free insulation for great performance and low energy use
    • Power supply and 110V cord included
    • CSI downloadable app for smart phone control
    • Removable partition w/sensor automatically changes to single zone when removed
    • Removable baskets included
    • Rear wheels & extendable handle for mobility
    • USB charging port, 5.1V/2.1A
    • Drain plug for easy clean out
    • High/low compressor mode for energy saving or max cooling
    • 3 levels of adjustable battery protection to eliminate discharged batteries
    • Built in LED lighting
    • Available accessories: insulation cover (#W54), vehicle mount w/slide (#W57), portable battery (#W59)
    • Dimensions: 28.46" x 17.51" x 23.54"
    W55 with cover $580
    #W55
    Black Ice Refrigerator / Freezer 84 Quart
    The all new CSI® 84 Quart Black Ice Fridge/Freezer runs off of your vehicle’s 12V/24V accessory outlet for both cooling and freezing on the go. Eat the ice cream first only because you want to, not because you have to with dual zone digital controls that let you dial in the temperatures you want to keep cold foods cold and frozen items frozen. The efficient operation, built in adjustable battery protection and high capacity ensure your supplies will last the duration of your trip, however long your adventure. Four built in LED lights help you find what you’re looking for and a removable basket is included to help keep you organized. An AC power supply is also included to pre-cool before your big trip or just have the convenience of cold treats in your shop.
    • Digital controls w/2 individually adjustable zones of cooling/freezing
    • Brushed stainless outer finish
    • Dual lids with secure latching
    • Removable wire basket included
    • Anti-rattle spring loaded handles
    • Available accessories: insulation cover (#W56), vehicle mount w/slide (#W58), portable battery (#W59)
    • Dimensions: 36" x 22.09" x 17.91"
    Both of these units work with the CSI Black Ice App for temperature adjustment and monitoring. Both units have slides available and work with W59 portable battery.
  12. May 27, 2020 at 11:13 AM
    #652
    Mike's Custom Toys
    Grants Pass, OR
  13. May 27, 2020 at 11:28 AM
    #653
    PK930
    Texas
    ‘12 4Runner
    I've been waiting to see if when you'd announce those -- that's a great price! Hmm...
  14. May 27, 2020 at 11:50 AM
    #654
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    You have to be shitting me. Ughhh classifieds here I come to sell the one I just got.
    GoJo likes this.
  15. May 27, 2020 at 1:51 PM
    #655
    chad_chinchilla
    chad_chinchilla Well-Known Member
    Nick
    Toms River
    2017 TRD O/R
    Oooo, I literally came to buy a fridge and I see the 83 qt announced for only $580?? Sold! See you in June I guess lol
    Tom mike likes this.
  16. May 27, 2020 at 2:19 PM
    #656
    chad_chinchilla
    Nick
    Toms River
    2017 TRD O/R
    This is the 63 dual correct?
  17. May 27, 2020 at 2:26 PM
    #657
    Mike's Custom Toys
    Grants Pass, OR
    Yes the 63 is dual or you can remove the divider and be a single.
    Lord Helmet and uploadadventure like this.
  18. May 27, 2020 at 2:28 PM
    #658
    Tom mike
    Tom mike Well-Known Member
    Tom
    2016 tacoma trd sport
    Is this the 83 or 63?
  19. May 27, 2020 at 2:32 PM
    #659
    Bigdaddy4760
    Maner
    Poolville Texas
    How do we pre-order? I did not see it on your website.
    Beretta4x4 likes this.
  20. May 27, 2020 at 3:15 PM
    #660
    PK930
    Texas
    ‘12 4Runner
    Probably do that too -- or run two fridges. One for beer, one for more beer.
