CSI Fridge/Freezer Mega Thread
Discussion in 'Non-automotive Group Buys' started by Mike's Custom Toys, Jul 26, 2018.
  1. Aug 13, 2018 at 9:49 AM
    #141
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    can someone clarify the hi/med/low setting on the back? I'm a newb and just want to make sure. I know its the battery protection levels.
  2. Aug 13, 2018 at 9:51 AM
    #142
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Read the manual. It explains it and gives you the voltage levels it’ll cut out at and kick back in at.
  3. Aug 13, 2018 at 9:57 AM
    #143
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Did you have issues with it getting hot mounted like this? I just took mine out for a 3 day trip and didn’t realize I had one side of the ventilation blocked and it began to get quite hot (not the internal compartment, the electronics that run it). I moved it off then seat about an inch an a half and problem solved. I hope I didn’t hurt anything when I did this. Just a heads up so you don’t have the same issue.
    Aside from the operator error the fridge worked awesome. Thrilled with the purchase, SO much nicer than a cooler.
  4. Aug 13, 2018 at 9:57 AM
    #144
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    How do I order?
  5. Aug 13, 2018 at 10:00 AM
    #145
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Nope. Mine was fine. I just made sure to put something between the cooler and the seat to give it an air gap.
    avw4x4[QUOTED] likes this.
  6. Aug 13, 2018 at 10:03 AM
    #146
    AsianAnts
    AnT
    I did. Just so i'm understanding it correctly in plain terms. If i put it on LOW that means the fridge will use use more battery, cutting off power until it reaches a low 10.2v.
    and High setting is just basically more battery protection....
  7. Aug 13, 2018 at 10:27 AM
    #147
    Mike's Custom Toys
    Mike's Custom Toys [OP] Well-Known Member Vendor
    Grants Pass, OR
    Yes you got it.
  8. Aug 13, 2018 at 10:31 AM
    #148
    Mike's Custom Toys
    Grants Pass, OR
    I will get you one
  9. Aug 13, 2018 at 10:33 AM
    #149
    Mike's Custom Toys
    Grants Pass, OR
    PM sent. We take paypal or credit card.
  10. Aug 13, 2018 at 5:32 PM
    #150
    rkntoy
    rkntoy Well-Known Member
    Bend, OR
    Anyone played with this enough to know this? Heading off on a multi-day trip and would rather not experiment. Thanks...
  11. Aug 13, 2018 at 5:37 PM
    #151
    avw4x4
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Deeper spot is colder, it’s lined in metal where the cooling lines presumably are. In most fridges they call the shallow bit the dairy compartment; where you would put items you don’t want to freeze.
    I had mine set to 35 and ended up with some slushy beers, 39 seems about perfect!
  12. Aug 13, 2018 at 5:39 PM
    #152
    Mike's Custom Toys
    Grants Pass, OR
    The deeper spot gets a little frosty on contact if you are using the basket the temps are very close
  13. Aug 13, 2018 at 5:40 PM
    #153
    Mike's Custom Toys
    Grants Pass, OR
    Eco mode also drops the temps a little lower to run the compressor less as well
  14. Aug 14, 2018 at 10:07 AM
    #154
    Mike's Custom Toys
    Grants Pass, OR
    We also want pictures when you get back
  15. Aug 14, 2018 at 12:05 PM
    #155
    medic2230
    Murph
    Bama! Roll Tide
    Got mine a day early! :woot:
    20 minutes it went from 85 to 39 :eek:
    Impressive!
    Looks really nice Mike! Can’t wait to get it in the truck and give it a go this weekend.
    Kheiron likes this.
  16. Aug 14, 2018 at 12:56 PM
    #156
    Mike's Custom Toys
    Grants Pass, OR
    So glad it came early
    medic2230 likes this.
  17. Aug 14, 2018 at 9:59 PM
    #157
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    2015 MGM DCLB TRD Sport 4x4
    Not an overbrander.
    Temporarily mounted in the backseat for this weekend's trip:
  18. Aug 15, 2018 at 7:13 AM
    #158
    Mike's Custom Toys
    Grants Pass, OR
  19. Aug 15, 2018 at 11:14 PM
    #159
    Tombiology70
    Tombiology70 Well-Known Member
    San Diego
    2008 4Runner V8 Limited (Formerly 2017 Tacoma)
    Kids are loving having cold water in the garage but it's time to start using it on the road so how is everyone powering their fridges in the truck?
    tcjacado likes this.
  20. Aug 16, 2018 at 12:06 AM
    #160
    medic2230
    Murph
    Bama! Roll Tide
    I’m running a always on wire to a 12v plug either under the drivers seat or in the back of the center console to power mine.
    Tombiology70[QUOTED] likes this.
