Cummins swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gator81, Nov 21, 2018.
  1. Nov 26, 2018 at 9:35 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    You'll get that out of a 4BTA with a 5speed not to mention less weight. Keep in mind - If you live in an area with emissions testing, converting to an oil burner is a challenge at best.
  2. Nov 26, 2018 at 9:56 AM
    Gator81
    Gator81 [OP] Member
    Kyle
    2006 Tacoma SR5
    Lift, wheels/tires, audio system
    There are no emissions in Tennessee. Im leaning more towards the 4bt, was just tossing around the idea of a body swap. If I go with the 4bt, just need to figure out which transmission and transfer case to use. Will more than likely go with a SAS as well.
  3. Nov 26, 2018 at 10:42 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I vote for Tac-O-Rama!!!
    Good luck w the build OP! Take lotsa pics (and detailed notes & parts list) and post ‘em up here.
