Cummins Tacoma!
Discussion in 'Performance and Tuning' started by 2.7taco, Jul 9, 2017.
  1. Aug 2, 2017 at 12:33 PM
    #41
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Toyota has their own diesels why run a Cummins? Id love to have a
    Toyota 1DZ-II in a Tacoma or tundra
  2. Aug 2, 2017 at 12:38 PM
    #42
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    im hoping for the day someone successfully swaps a 6bt without the front end breaking apart. now that's a swap Ill dump my life savings into
  3. Aug 2, 2017 at 12:40 PM
    #43
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    The only people that like 4bt swapped tacos are people who masturbate to pictures of diesel trucks. These people have never owned a diesel truck, never driven a diesel truck, and have never even sat in a diesel truck. They claim to love it simply because it is diesel in a Tacoma and have absolutely no idea what it is all about.
    These same people don't realize that diesel in a mid size truck is stupid and has no benefits.
  4. Aug 2, 2017 at 12:44 PM
    #44
    coopcooper
    alberta canada
    the 4bta that most people use. not just the 4bt. its makes over 400tq and nearly 200hp. sure it weighs nearly 800 pounds but it does work.
  5. Aug 2, 2017 at 12:50 PM
    #45
    Ihatetacomas
    Ihatetacomas Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    A 4.0L Toyota engine that produces around 230 torque vs a 2.8L diesel that produces 280...
  6. Aug 4, 2017 at 8:07 PM
    #46
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    So I don't see how an increase in fuel efficiency as well as a sight increase in driveability with a modern light weight diesel is stupid.
    Please explain.
    Also I'm not talking about the 4BT or 4BTA. We are talking a modern 500 pound 2.8 liter engine providing more bottom end torque I'm the same weight and size package.
  7. Aug 4, 2017 at 8:10 PM
    #47
    2.7taco
    Texas
    4BT is out of the question strictly dimensionally speaking. The engine is too tall to mount properly without significant modification to the frame and suspension.
  8. Aug 4, 2017 at 8:11 PM
    #48
    2.7taco
    Texas
    A bit under powered also this is an industrial engine not suited for daily driving.
  9. Aug 4, 2017 at 8:22 PM
    #49
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Increase in fuel efficiency is offset by the higher cost of diesel. It's a wash. A tiny but more torque yes but not enough to make much of a difference, plus less horsepower which will make it feel like a slug. Ever driven a diesel tacoma overseas? It sucks. Now add the premium you will have add to get the motor on an already 35k truck, plus the high cost in maintenance, mix in the lower dependability due to choked down emissions standard and you come up with a stupid idea. People only want this to look cool, and if that is the reason I'm all for it. They just need to look inside themselves and admit it. Other wise it's pointless.
  10. Aug 4, 2017 at 8:43 PM
    #50
    2.7taco
    Texas
    Well that contradicts everything this post is about.
    Modern diesels are much more efficient than their gasoline counterparts. I am making a direct comparison to the 2.7 in my truck which produces 151 horsepower and 190 pounds of torque. The 2.8 Cummins has more torque in a useable RPM range vs the 2TR-FE. The emissions choking them down comment is also not valid. My example is my other truck which is a 2015 Ram 2500 diesel that produces the same fuel efficiency as my Tacoma with the 2TR-FE.
    On the topic of fuel costs that will depend on where you live. Here in Texas (specifically where I live) the average diesel price is about 2.25 cents and regular unleaded is 2.15 the difference is 2.10 in added cost for 21 gallons of fuel. Now if you couple that with the possibly of 25 MPG or better (Cummins test bed is a Jeep 4x4 that achieves 30 MPG) the fuel costs are greatly curbed because you go further on the same amount of fuel. My 2TR-FE averages 19-20 MPG which after burning 15 gallons of gasoline is about 300 miles which cost 32.25. With a diesel yielding 25 MPG the same 15 gallons would yield 375 miles at a cost of 33.75. Cost per mile for diesel is .09 cents compare to gasoline .107 cents per mile. So put simply cheaper to drive. Cost of maintenance is not much different considering HDEO can be pushed much further than 5000 miles before an oil change. My oil change cost for the Tacoma is 35 dollars which is changed every 5000 miles. The average with a modern diesel is 7500 miles before changing the oil and a gallon of 15W-40 cost around 13 dollars and oil filter between 9-15 dollars. The 2.8 ISF holds about 1.3 gallons of oil.
    Bottom line a diesel would be a much more viable option compared to the 2TR-FE for highway driving and off road crawling.
  11. Aug 4, 2017 at 11:40 PM
    #51
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Yeah of course that little 4 cylinder is garbage. You know what would be way cheaper and a better option? Get the taco with the v6
  12. Aug 5, 2017 at 6:09 AM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Turbo every engine! The world is a better place, and everybody makes more torque. :curls::muscleflexing::humble::yes:
