Cup Holder Switch Panel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drunknsloth, Jun 11, 2012.
  1. Jun 18, 2012 at 9:33 PM
    #41
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Best bet for that many switches would be a secondary fuse block. Does it have to be wired to the ignition?
  2. Jun 18, 2012 at 10:53 PM
    #42
    Drunknsloth
    Drunknsloth [OP] Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Yep I recommend a secondary fuse block and use relays between the block and your switch to set it to be hot when you turn on the ignition. Maybe tie the relay to an add-a-fuse on the internal fuse block (probably the radio or illumination)
  3. Jun 18, 2012 at 11:14 PM
    #43
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    This^ Unless there is no reason for it to be wired to the ignition. I wired a secondary fuse block directly off the battery so its always hot, unless I throw the lever on the breaker. I did it that way so I can use my bed lights and under hood lights without the ignition on.
    Something like this...
  4. Jun 19, 2012 at 3:37 AM
    #44
    knine00
    knine00 Well-Known Member
    Hudsonville, Mi
    12 PreRunner DC TRD Sport
    Stock for now
    The plain was to wire them into the ignition bc the switches have lights that i want to illuminate when i turn the key. So each switch would need two relays? One for the fuse block and one for then lights being added?
  5. Jun 19, 2012 at 3:38 AM
    #45
    knine00
    Hudsonville, Mi
    Stock for now
  6. Jun 19, 2012 at 7:18 AM
    #46
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Only one relay. Power to close the relay and allow power to the secondary fuse block would need to be tied to the ignition. Everything else could be run directly from the secondary fuse block.
    Although since it would be used to close the circuit in a large gauge wire, a solenoid might be better then a relay.
  7. Jun 19, 2012 at 7:20 AM
    #47
    knine00
    Hudsonville, Mi
    Stock for now
    So power from the battery to a relay then to the sec. Fuse block. The an add a circuit from the truck fuse block to the sec. Fuse block?
  8. Jun 19, 2012 at 9:34 AM
    #48
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    Sort of, I'm on a phone so this will be crude. but it would look something like this
    Battery-------relay 1-------secondary fuse block.
    Then an add a circuit in an ignition powered fuse slot or tapping into an ignition powered wire to relay 1.
    So relay 1 has three wires on it. One battery in, one battery out, and one ignition in. when power from the ignition goes to the relay it closes the circuit from the battery to the fuse block providing power to it.
    This would make the entire secondary fuse block hot with the ignition. So anything you run off of the block would also only be hot with the ignition.
    Or you could do the same thing on each switch power wire. Which would be more work, but you don't need as big of relays.
    If you decide to go the route of making the whole fuse block wired to the ignition I would think a solenoid would be better then a relay, but it works the same way essentially.
  9. Jun 19, 2012 at 10:29 AM
    #49
    knine00
    Hudsonville, Mi
    Stock for now
    I like and understand the first one. What kind or relay is required for this and what gague wire from batter to relay and relay to sec. Fuse bloc?
  10. Jun 19, 2012 at 10:41 AM
    #50
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    I used four gauge wire and a hundred amp circuit breaker. So after the breaker and before the fuse block is where I would put the relay/ solenoid. Id recommend a solenoid. Though I'm not sure how they are rated. But you want it to be rated no higher then 80% of the current the wire can handle. If it were me I would try for a hundred amp capable solenoid but something that doesn't require much to close the circuit. Sorry I can't be more help. I know how they work just not how they are rated. Hopefully someone else will chime in. Or you could start a thread asking about it. Might get more info that way.
  11. Jun 19, 2012 at 11:33 AM
    #51
    knine00
    Hudsonville, Mi
    Stock for now
    It makes sense i just need to figure out where to start.
  12. Jun 19, 2012 at 11:45 AM
    #52
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Great looking switch panels everyone!
    Mods should make this a sticky and re name it "custom switch panels"
  13. Jun 19, 2012 at 12:34 PM
    #53
    Large
    Large Red
    Add a fuse with a 12v ignition source, run it to a 100 amp senoid. When the ignition is turned to the 'on' position the solenoid closes the circuit giving power from the battery to the accessory or in your case an aux fuse panel. A 100 amp solenoid has 3 prongs, 2 are big 1 is small obviously the small one is for the 12v ignition and the 2 bigger prongs are for battery in / accessory out.
  14. Dec 5, 2012 at 4:47 AM
    #54
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Sub'd for later, sweet mod man!
  15. Dec 5, 2012 at 4:54 AM
    #55
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    where did everyone buy their panels?
  16. Dec 5, 2012 at 10:19 AM
    #56
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Where do you get the OEM switches? How much??? :eek:
  17. Dec 5, 2012 at 10:51 AM
    #57
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    The blanks are under accessories and the switches are all over. But right here...........http://www.otrattw.com/
  18. Dec 5, 2012 at 11:46 PM
    #58
    Drunknsloth
    Retribution
    South West
    :thumbsup:
    What this guy said:
    I would recommend asking http://www.tacomaworld.com/forum/ca...298-camelback-toyota-discount-tw-members.html
  19. Jan 22, 2013 at 6:15 AM
    #59
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    Sub'd for later
    Plan on trying this soon picked up a blue sea 12 circuit fuse box and a 100amp breaker and the six switch holder from OTRATTW.
  20. Jan 22, 2013 at 12:01 PM
    #60
    Drunknsloth
    Retribution
    South West
    Let me know if you have questions
