Cupholder Insert - Fits Yeti, Hydroflask, Travel Mugs and more
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by rns0504, Sep 23, 2019.
  1. Mar 5, 2020 at 4:25 AM
    #161
    rns0504
    rns0504 [OP] Well-Known Member
    DeBary FL
    2015 Tacoma TRD Off Road
    'Stock-But-Capable' - I have four other 4x4s to mod
    Hey Austin, send me a PM and I will get you taken care of brother!
  2. Mar 5, 2020 at 9:41 AM
    #162
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Hope you're still making these. Money is sent! Thanks been looking for one of these for a while.
  3. Mar 5, 2020 at 10:59 AM
    #163
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
  4. Mar 5, 2020 at 2:49 PM
    #164
    Northbound_Taco
    09 Off road build
    Same day shipping also? Awesome service! Thanks Ryan
  5. Mar 5, 2020 at 3:24 PM
    #165
    93ipc14
    93ipc14 Member
    Tom
    2007 Speedway Blue PreRunner DCLB SR5 TRD Sport
    Hi Ryan,
    My wife has this huge hydro flask that she would like to fit in the cup holder. Hope you can help. Tom
  6. Mar 6, 2020 at 7:15 AM
    #166
    rns0504
    DeBary FL
    No problem man! Same say is the norm except when I'm on the road, and even then I have my fiance try and take care of them for me! Let me know your thoughts once installed!
  7. Mar 6, 2020 at 7:24 AM
    #167
    rns0504
    DeBary FL
    The orange is very... orange! I ran 2 of these, let me know if someone wants the other!
  8. Mar 6, 2020 at 7:29 AM
    #168
    rns0504
    DeBary FL
    Hey Tom,
    Yes the hydroflask is right at 3.6" To slide in and out the hole needs to be at least lets say 3.65". I've been playing with this for a while and made a few prototypes.
    The biggest problem is that by the time I get the hole big enough, there is almost no material left around the edges, and I think it is also "ugly". See the picture from Solidworks attached, especially the 3 areas where I just run out of material completely and it cuts down to nothing. This is about the minimum size to fit a hydroflask. In addition, I'm just a bit concerned about the bottle hitting the three (or 6) black tabs inside the console, which the original inserts align to (and my product uses as well).
    I have a list of people interested, so I just made a few changes and shortened the depth of the insert a bit. I'll run a prototype this weekend and post the results and see how it goes, and then reach out to the hydroflask folks and see if they think the "compromises" that have to be made to make this fit are considered acceptable.
    Thanks for the interest and I will update soon!
  9. Mar 6, 2020 at 6:11 PM
    #169
    93ipc14
    93ipc14 Member
    Tom
    Hi Ryan,
    Based on your image and the need for stability, we are convinced to try one of your 'scratch+dent' products first. Is that option still available?
  10. Mar 7, 2020 at 5:30 AM
    #170
    g8rnbft
    g8rnbft Member
    Blair
    2009 Gray Tacoma TRD, leather, sunroof, Bluetooth, 2" lift
    I will take orange if available!
  11. Mar 9, 2020 at 6:20 PM
    #171
    Babybluetaco
    Austin
    09 5 lug
    Happy happy customer!!! Wasn’t happy with the fit of my first scratch and dent insert so me and the seller started talking. Mine seemed to come out really easy and get stuck to the bottom of a cup at times. So the seller went above and beyond and printed me a brand new insert with smaller gaps in the bottom so it slides down into the cup holder snuggly! Fits like a glove nice and tight just how I wanted it. Stand up guy who stands behind his product.
    SanDiegoMatt likes this.
  12. Mar 12, 2020 at 7:23 AM
    #172
    VA_Taco
    VA_Taco Well-Known Member
    Chino
    Virginia
    2012 TRD Sport 4x4
    6" w/35's
    Payment sent!
  13. Mar 13, 2020 at 1:18 AM
    #173
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Used 3in to 4in pvc adapter and glued on 4in pvc pipe for depth. Should work with OP"s inserts .Only thing is it sits high . It will fit in front cup holder as its the same as the one I put in back . But draw back is its big .
    If OP can design one that works would be much better because with the adapter flask sits about 3in higher
    NOTE
    This does not fit in stock cup holder
  14. Mar 13, 2020 at 6:24 AM
    #174
    rns0504
    DeBary FL
    That thing is sick man! Great work!
    hemitruk[QUOTED] likes this.
  15. Mar 13, 2020 at 6:39 AM
    #175
    rns0504
    DeBary FL
    Alright, I did some more work on the Hydroflask. Video explains it best.
    Summary is that my insert will do nothing to "hold" the hydroflask and will simply be there for appearance purposes. Not sure its feasable to do Hydro on both sides or just one, havent tried. I can make a version with Hydro hole on left or right, or maybe both? Going to run another prototype to thicken up the edges, mostly for cosmetic purposes and I can get some out to the folks interested.
    @93ipc14
    @E-Paz 732NJ
    @dee_wreck
    @treyfive
    @DailyBreadBaker
    @moscowpyro
  16. Mar 13, 2020 at 6:40 AM
    #176
    rns0504
    DeBary FL
    Glad to help man! I made those changes to all new parts moving forward. Thanks for the suggestions!
    Babybluetaco[QUOTED] likes this.
  17. Mar 13, 2020 at 7:00 AM
    #177
    93ipc14
    93ipc14 Member
    Tom
    Great video! It does explain a lot! You are right, it just needs to surround the flask and not let it tip and possibly jump out. The tabs in the tray bottom (on that side) will help to hold the flask instead of the insert. Great work! Just let me know when I can order one!!
    E-Paz 732NJ and hemitruk like this.
  18. Mar 13, 2020 at 10:17 AM
    #178
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Perfect. . Like that it sits down to bottom and its factory looking . :thumbsup:
    Now you got a hydroflask you tried it ? Love mine .
    E-Paz 732NJ likes this.
  19. Mar 15, 2020 at 7:52 AM
    #179
    E-Paz 732NJ
    E-Paz 732NJ Well-Known Member
    Eric
    NJ
    2015 Tacoma TRD-OR
    Nice work! I’d def be interested.
  20. Mar 19, 2020 at 10:28 PM
    #180
    Echodawg
    Echodawg Well-Known Member
    Fremont, CA
    2014 TRD OR DCSB
    Stuff and Things!
    I was going to order one but want to make sure you're still making them with everything going on nowadays.
