curing the taco lean
Discussion in 'Suspension' started by malander, Nov 10, 2010.
  1. Nov 10, 2010 at 5:27 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I've searched around and can't seem to find any threads on this but heres the deal, I lifted my truck with billys set at 0 and ome 883 coils after about 2 weeks i noticed about 3/4" lean to the driver side so i got a .5" top plate spacer to fix it, it looked good for a while but about a month later it still has about .5" of lean. What I'm asking since i dont have adjustables is can you switch the sides of the coilovers to even out their wear on the coils with the uneven distribution of weight and possibly cure the lean?
  2. Nov 10, 2010 at 5:29 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I believe so.
  3. Nov 10, 2010 at 5:37 PM
    malander
    max
    01 limited trd 4x4
    i may have to end up trying it then if no one already has
  4. Nov 10, 2010 at 5:40 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Go on a diet, that may help.
    Coils are not side specific
  5. Nov 10, 2010 at 5:51 PM
    malander
    max
    01 limited trd 4x4
    lol i eat 6-8000 calories a day and weigh 165
    oh and i know they arent side specific just wonderin if itll cure the lean
  6. Nov 10, 2010 at 5:54 PM
    cummins6speed
    It should help to fix the problem if the springs are the same rate
  7. Nov 10, 2010 at 5:57 PM
    malander
    max
    01 limited trd 4x4
    Thanks for the advice, I'll talk to my shop about it
  8. Dec 18, 2012 at 11:03 AM
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I didn't want to start a new thread, but I didn't see anyone discuss the idea of adding a piece or two of 1/4" flat stock on top of the rear driver side leaf spring perch (actually attached to the bottom of the spring pack) in order to help correct the Taco lean. I have a piece of 2" x 1/4" flat stock cut into a 5" length with a 3/8" hole drilled in it (for the leaf spring centering pin) to act as a mini block spacer for the rear. I'll be under the truck removing the axle shims from each leaf pack, so I thought why not add the flat stock to the low side while I'm in there. Would this be a viable option, or is this a stupid and/or dangerous idea that will cause other issues?
  9. Dec 19, 2012 at 4:58 PM
    ae111black
    ae111black Well-Known Member
    Kimo
    Hilo Hawaii
    10 TRD off road doublecab 4x4 silver
    plenty
    I used 1/2" flat stock aluminum in the same manner (on both sides) and it worked out fine. If you look @ HD dodges and Med-HD trucks (peterbuilts ect) they do it all the time.
  10. Dec 19, 2012 at 5:02 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    fat chicks in the passenger seat. Might get some strange looks but it works to cure the taco lean.
  11. Dec 19, 2012 at 5:13 PM
    DR Da_da
    Northeast FL
    ae111black,
    Thanks for the feedback! I'm looking to use the flat stock on only one side (not both) in order to compensate for the lean. Do you think that will pose a problem since both leaf packs won't be the same?
    On a side note, I like your sig! Some friends of mine came back from a trip to Hawaii with HE>I shirts. Merry Christmas!
  12. Dec 19, 2012 at 5:44 PM
    DR Da_da
    Northeast FL
    So you speak from experience? :spy:
  13. Dec 19, 2012 at 6:55 PM
    macgyver
    Brad
    Canton, GA
    Nope. No fat chicks.
  14. Dec 19, 2012 at 10:14 PM
    ae111black
    Kimo
    Hilo Hawaii
    plenty
    I think it will work. Referring to he>i U a follower too?
  15. Dec 20, 2012 at 9:57 AM
    DR Da_da
    Northeast FL
    Thanks, and yes, sir! As a husband, father, and individual living in this day & age I can't imagine trying to live without Him. ". . . The old has gone, the new is here!"
  16. Dec 20, 2012 at 10:00 AM
    J88logue
    J88logue NorthWest Member
    Jonnie
    HWY 30
    02 D.C. TRD LIM. F.T.W.
    Clicko BUILDo
    I noticed alot of people use the 1/4 top plate on driver side for their lean.
    I don't have a lean, so why not use 1/4 oon each side for 3/4 more lift in the front :)
  17. Dec 20, 2012 at 7:18 PM
    ae111black
    Kimo
    Hilo Hawaii
    plenty
    Sweet dude! Merry CHRISTmas!
