Curious. How much does your modified truck weigh?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wile, Sep 9, 2015.
  1. Sep 9, 2015 at 8:51 PM
    Wile
    Wile [OP] Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    As I build my truck, I've been tracking the weight I've been adding. I'm closing in on the GVWR of 5500lbs. I'm swapping the rear leafs to Allpro Expeditions and and the fronts have 700# springs. Have any of you weighed your truck or have estimates? Pics of your build would be helpful along with its weight.
  2. Oct 10, 2015 at 9:22 PM
    Wile
    Tim
    New Mexico
    Just had my truck weighed. 5020 pounds.
    Edit: No one was in the car when it was weighed.
  3. Oct 11, 2015 at 12:54 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Not a lot of mods, bunch of tools. 4950 lbs when at the scrap yard. Thought my truck was getting heavy even before adding all the rest of the lift and stuff. Guess not to bad.
  4. Oct 11, 2015 at 6:54 AM
    Pigpen
    Dan
    Northwest Montana
    Now you have me thinking... I ran it across a scale awhile back and it was either 4550 or 5440. Shit. Might make a detour to the scale today. Not much extra weight in mods other than topper and winch with steel rope, but lots of tools and extras. Tires must add a fair amount - load E 33s. And the wood sleeping platform. And...
    100' of 3/8" cable with attachments on each end, 2 - 2"x20' tow straps, 20' of heavy chain, 3 large shackles, 3 logging rated pulleys, my Warn X8000i on a removable cradle, shovel, pulaski, 3lb hammer, crow bar, come along, 4 way lug wrench, extra automotive fluids, Husky 550 XP (72d bar) with extra fluids, a sled and cross country skis (in winter), various lengths of rope, and a small plastic bottle of whiskey. The small stuff is in a milk crate, and everything fits under my sleeping platform. I also have a 60" all cast hi lift which nests beside the platform, and the off road base and lift mate.
    This doesn't include the 2 sets of tire chains, socket set, wrench set, random tools box, retired climbing rope, rain gear, bottle jack (in addition to OEM jack), road flares, PB Blaster, window cleaner, roll of shop towels, and toilet paper that fits in my tool box/ dog bed where my access cab seats used to be. Then I shove a bunch of other stuff behind the front seats. This includes: framing hammer, wire fence tool, gallon of water (currently frozen:D), rifle scabbard (currently unoccupied), CB (because it's huge and old. I'll mount a newer smaller one eventually), and magnetic base antenna.
    I won't bother to mention what I manage to stuff into my center console and glove box...
    Yes, it all lives there and this is my daily driver. Dead critters are seasonal items :)
    taczilla likes this.
  5. Oct 11, 2015 at 6:57 AM
    Wile
    Tim
    New Mexico
    My E rated 33" weight 58 pounds each.
  6. Oct 11, 2015 at 7:03 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Shit, now I need to go weigh mine.
  7. Oct 11, 2015 at 7:12 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I'm at 5300 with 1/4 tank of gas and just my spare in the bed. I usually carry around a tool box as well. Can check out my build for specs.
  8. Oct 11, 2015 at 7:13 AM
    travis.diller
    travis.diller Well-Known Member
    Travis
    Kitsap Peninsula
    2003 Taco prerunner 4x4
    fully armored, 4.88, 33 skinnies, tundra brakes, a REAL cold air intake.
    That is unsprung weight and doesn't count against you in the GVWR. Your suspension also ups your rating.
  9. Oct 11, 2015 at 7:15 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Suspension doesn't change any rating of the truck. It simply allows it to handle the recommended weight better.
  10. Oct 11, 2015 at 7:15 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I was at 4400 pounds. Truck only, no gear. Front bumper with winch.
  11. Oct 11, 2015 at 7:25 AM
    Wile
    Tim
    New Mexico
    Here is my "Onboard" inventory:
    - All-Pro APEX Aluminum Plate Front Bumper
    - All-Pro Aluminum Skid Plate
    - All-Pro APEX Steel rock sliders
    - All-Pro Rear Bumper with Swing-out Tire Carrier.
    - All-Pro Rear Expo Rear Leafs
    - Icon Stage 6 suspension system with #700 coils in front, 1.5" inch AAL and billet aluminum UCAs
    - 5x Cooper Discovery ST MAXX 255/85/R16
    - 5x Black FJ Trail Team wheels
    - Warn 9.5 XP-S performance winch with synthetic rope
    - Rigid Industries DOT/SAE Fog Lights
    - Rigid Industries 20" RDS LED Curved Lightbar
    - Rigid Industries D2 Flushmount Reverse Lights
    - Recovery gear (snatchblock, tree strap, "D" ring shackle)
    - Tool bag (crescent wrenches, pliers, socket set, etc.)
    - Center console vault
    - Jumper cables
    - 2 empty NATO gas cans (add 60 pounds when full)
  12. Oct 11, 2015 at 7:36 AM
    Wile
    Tim
    New Mexico
    Does that include you?
  13. Oct 11, 2015 at 7:40 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I don't believe so. I stepped off the scale to pay a bill. I get weighed when I have to go to the dump to throw stuff out.
    I have added a winch since the last time I went, plus more recovery gear, tool box and stuff. Not unheard of to get these trucks to 6000lbs. I don't even have much shit in the bed like a cab or a rack.
  14. Oct 11, 2015 at 7:47 AM
    Wile
    Tim
    New Mexico
    Yeah, 6000lbs was my guess on some of the larger trucks builds I've seen on TacoWorld. I'd like to keep mine below GVWR with the bed unloaded atleast. If I can control my habit of adding/buying stuff. :anonymous:
  15. Oct 11, 2015 at 8:58 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I'm in the same boat as you. However I think if I regear it will make everything a little happier. Get some power back, less stress on tranny etc.
    I still have some more armour to add on too. This site is the devil for buying stuff lol
  16. Oct 11, 2015 at 6:26 PM
    Wile
    Tim
    New Mexico
    That makes sense. My truck weights 5020 with a similar winch and front bumper plus 140# rocksliders, 350# rear bumper, 80# spare and 50# in tools and gear.
  17. Oct 11, 2015 at 6:37 PM
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    5600lbs without any extra gear yet. ( Camping gear, extra parts, etc )
    Might be a bit more now that I have the LT in. Was going to get it weighed again this week.
  18. Oct 12, 2015 at 7:26 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Was that with your tube bumpers on or the plate bumpers?
    sytfu510[QUOTED] likes this.
  19. Oct 12, 2015 at 11:06 AM
    sytfu510
    Alex
    Bay Area
    That was with the plate. I should be a little lighter now.
  20. Oct 12, 2015 at 11:52 AM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    I have been trying to lighten my truck for better fuel economy.
    Gs anyone got a good source for helium? I think I know how to reduce my un-sprung weight... :rolleyes:
